Help with Schematic-Trying to make a MODEM
Results 1 to 4 of 4
    Post Help with Schematic-Trying to make a MODEM
    Hello, I am trying to build a MODEM to communicate with my PIC. Please note that the modem is in a shape of a module, I am designing a PCB for it. I do not understand few terms though they may be very basic but I do not want to make any mistake as it will an expensive one. I am attaching a snapshot from the datasheet explaining about the voltages on the pins which I am going to connect to my PIC. Could you please advise me if I can connect these pins directly to my PIC or there is some sort of circuit needed between them.
    Before you checkout the attachment please note that VDD_EXT=2.9V
    Many Thanks
    Post
    Could you please also tell me what VOL, VOH, VIH, VIL actually means and which ones are the one to look for next time I want to connect any device to my PIC. Thanks
    Bombay, India
    VOH and VOL are the voltages you get when the device sets its output to High or Low. VIH and VIL are the voltages the device expects to interpret the value as a 1 or a 0.
    For VDD_ext = 3V, you should ideally be using a PIC that can operate at 3V.
    Question
    Thanks for replying. My PIC will be running on 4V actually. Will it be able to accept data with those outputs of between Gnd & 2.73V ?
    If yes then I assume I can connect the module pins directly to the PIC without any amplifier circuit in between. Is that correct?
  1. Change On Interrupt, PIC16F884
    Last Post: - 14th November 2008, 18:25
  2. How come they make electronics hard as poss
    By George in forum Off Topic
    Last Post: - 14th July 2007, 00:54
  3. SEROUT2 to GSM Modem
    By tommyers in forum General
    Last Post: - 21st August 2006, 22:35
  4. Reading a Hex value from a Modem and showing it as Decimal..
    Last Post: - 16th March 2005, 18:58
  5. No Modem response
    By jimboho in forum mel PIC BASIC Pro
    Last Post: - 11th November 2004, 06:58
