over the 800h "Boundary"
Results 1 to 3 of 3
    Oct 2003
    holland
    Default over the 800h "Boundary"
    I use the PIC16F648A for a "big program" and now I get the message :
    Warn C:\CDLITE\TEST.ASM 663 : [102] Code Crosses Boundary @ 800h
    I is a warning, I can see that.
    Is is compiling with further no faults.
    I did not test my programm yet, because I am waiting for the chips.
    Is this a problem or ??
    Mat, You should have no problem with this warning as it is just that, a warning. Be sure however that when you see this warning that if you are using the "BRANCH" statement you use the "BRANCHL" statement in its place. This is the branch long statement which will allow you to span memory bank boundrys.
    HTH,
    Dave Purola,N8NTA
    Oct 2003
    holland
    Thanks.
    When the chips are in I will programm them.
  1. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 22:29
  2. Code Crosses Boundary @ 800h
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2005, 08:17
