PIC18F8722 and LCD
Results 1 to 2 of 2
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default PIC18F8722 and LCD
    I'm using:
    1. PIC18F8722 at 40MHz (HSPLL setting with a 10 MHz Xtal.
    2. PBP.
    3. Standard LCD
    4. All pins outputs and A/D off - all pins are digital.
    1. The LCD works fine on all the ports (with 8 pins) but not on PORTH.
    2. PORTH has other uses, apart from I/O: External memory, ECCP1 and ECCP2 but these are 'OFF' by default - and I've set the SFRs to confirm this.
    3. But still no luck with PORTH?
    4. Running other programs i.e LED flashing shows that the PINS of PORTH are working as outputs OK.
    Any ideas? I guess that I'm not setting some SFR?
    Regards Bill Legge
    Nov 2007
    Default Pic18f8722
    I have been digging around the PBP complier and have found:
    In the file '18F8722.BAS' there are the lines:
    PORTH VAR BYTE EXT
    @PORTH EQU PORTC
    Is this the cause of the problem?
    Regards Bill Legge
  1. LCD Reset Problem
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 24th February 2009, 09:55
