PICkit2 Problem
Results 1 to 4 of 4
Thread: PICkit2 Problem
    Hi Techbuilder,
    here is the datasheet for the PICKIT2. Your Schematic looks correct to me. What manner of problem are you experiencing ?
    http://www.modtronix.com/products/pr...tasheet.pdf#10
    Well I tried using it and it stated that vdd pin is invalid or something like that
    Are you powering the PIC with an independent power supply, or just the USB ? It will accept either, but not both together. There is a check box in the PICKit2 software to enable power from usb. Are there any loads on the 3 programming pins ? If so that will cause it to complain.
    Jul 2007
    Well I can't quite figure out using MPLAB Ide yet but I couldn't even get it to link an LED
    I tried micro code studio and then exported the hex fle and wrote it to the pic with the PICkit 2 os and still nothing.
    How do I set the fuses for the pic kit 2?
    I do not have it powered I am supplying my voltage from the Pickit 2
    I just program it with the pic it's self and I don't connect anything to it besides the PICkit2
    You need to set the fuses in code or in the *.inc
  1. Problem driving lcd from PIckit2 and 16F887
    By Davidmarks in forum mel PIC BASIC Pro
    Last Post: - 31st January 2010, 19:28
  2. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 21:17
  3. Help MCS with PICKIT2 programmer question
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 1st February 2008, 18:57
  4. USART Problem , but don't know where, in pc? or in PIC?
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
