Problem with I2C EEPROM addressing
Results 1 to 15 of 15
    Sep 2006
    Florida, USA
    Default Problem with I2C EEPROM addressing
    Hello - I have a strange problem when trying to access an EEPROM at a certain address. I have a string of five 24LC256 EEPROMs all sharing the same clock and data line. On the first 4, I am storing the position of 4 servos with the position value converted to a byte-sized variable. On the last one, I am storing the state of a relay (1 or 0). The EEPROMs are addressed 000, 001, 010, 011 and 100. I have no problem reading and writing to the first 3 EEPROMs and the last one, but for some reason, I can not read or write to the 4th EEPROM (011). I have tried swapping EEPROMs around and have determined that there is something to do with that address. My code is pretty straight forward - record mode = read the positions of the 4 servos and relay convert to byte-size (servos) and store the data. Playback mode = read the data convert it to word-sized numbers (for servos) and send it out. The same code is used for all 4 servos. 1, 2 and 3 work fine, 4 just pegs out during playback. The servo #4, when under manual control, responds fine. Anyone have any idea what my problem could be? Attached is a drawing showing my EEPROM layout. I thought it might be a timing issue but why does it only affect #4 and not #5?
    PBP 2.5 and 877A PIC.
    Here are some code snipetts:
    Posit var word
    Posit1 var word
    Posit2 var word
    Posit3 var word
    Posit4 var word
    PVal var byte
    'EEPROM 1 will contain posit data for Servo 1
    EChip1W CON %10100000 'Write mode for EEPROM 1
    EChip1R CON %10100001 'Read mode for EEPROM 1
    'EEPROM 2 will contain posit data for Servo 2
    EChip2W CON %10100010 'Write mode for EEPROM 2
    EChip2R CON %10100011 'Read mode for EEPROM 2
    'EEPROM 3 will contain posit data for Servo 3
    EChip3W CON %10100100 'Write mode for EEPROM 3
    EChip3R CON %10100101 'Read mode for EEPROM 3
    'EEPROM 4 will contain posit data for Servo 4
    EChip4W CON %10100110 'Write mode for EEPROM 4
    EChip4R CON %10100111 'Read mode for EEPROM 4
    'EEPROM 5 will contain data for Relay
    EChip5W CON %10101000 'Write mode for EEPROM 5
    EChip5R CON %10101001 'Read mode for EEPROM 5
    Record Mode Code Snipett---
    gosub ReadPot1
    pulsout servo1, posit1
    pause 5
    gosub ReadPot2
    pulsout servo2, posit2
    pause 5
    gosub ReadPot3
    pulsout servo3, posit3
    pause 5
    gosub ReadPot4
    pulsout servo4, posit4
    pause 5
    if recordflag = 1 then 'store data
    posit = (posit1 * 23) / 100 'convert to a value < 255
    pval = posit 'put into a byte variable
    I2CWRITE DPIN, CPIN, EChip1W, Addr, [PVal] 'write it out
    posit = (posit2 * 23) / 100
    pval = posit
    I2CWRITE DPIN, CPIN, EChip2W, Addr, [PVal]
    posit = (posit3 * 23) / 100
    pval = posit
    I2CWRITE DPIN, CPIN, EChip3W, Addr, [PVal]
    posit = (posit4 * 23) / 100
    pval = posit
    I2CWRITE DPIN, CPIN, EChip4W, Addr, [PVal]
    if RelaySw = 1 then
    pval = 1
    pval = 0
    I2CWRITE DPIN, CPIN, EChip5W, Addr, [PVal]
    addr = addr + 1
    PlayBack Mode Code Snipett---
    high PlayLED
    read 16, Lastaddr.byte0
    read 17, lastaddr.byte1
    for addr = 1 to lastaddr
    i2cread dpin, cpin, echip1r, addr, [pval]
    posit = pval * 4 'multiply by 4.03 to convert back to word
    posit = posit + ((pval * 3) / 100)
    pause 5
    i2cread dpin, cpin, echip2r, addr, [pval]
    posit = pval * 4
    pause 5
    i2cread dpin, cpin, echip3r, addr, [pval]
    posit = pval * 4
    pause 5
    i2cread dpin, cpin, echip4r, addr, [pval]
    posit = pval * 4
    pause 5
    i2cread dpin, cpin, echip5r, addr, [pval]
    if pval = 0 then
    low Relay
    low RelayLED
    high Relay
    high RelayLED
    if SSRecBtn = 1 then
    low Relay
    low RelayLED
    low PlayLED
    goto Start
    next
    Short of a bad solder joint, I don't see anything wrong at a quick look.
    Swap out a few chips and see what happens. Double check your joints.
    Slow down the oscillator and see what happens.
    (And on a side note, post all your code if you can. I can see room for a bunch of improvements that can be made in your code, streamlining it and all. And I'm not talking about MY standard 'colon-ization' stuff )
    On the 24LC256, Pin1 (A0) is the low order bit. You have them reversed in the picture.
    Red is the actual addresses.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2794" />
    Sep 2006
    Florida, USA
    That was IT!!!! You guys are so awesome!!! Thanks! It works perfectly now... Funny how that one was the only one where it mattered that I had it backwards. I had the right addresses (except one) but they were not assigned to the EEPROMs that I thought they were...
    Thanks again!
    Aw crap! I poured over that schematic and missed it...
    Chalk another one up for DT...
    Cool
    Quote Originally Posted by skimask
    I poured over that schematic ...
    What a coincidence! &nbsp;I poured a beer while looking over that schematic.
    Maybe it helped?
    Sep 2009
    Default record servos
    [QUOTE = Atom058; 60240 Olá] - Eu tenho um problema estranho ao tentar acessar uma EEPROM em um determinado endereço. Eu tenho uma seqüência de cinco 24LC256 EEPROMs todos compartilhando o mesmo relógio e linha de dados. Na 4 primeiro, eu estou armazenando um POSIÇÃO DE 4 servos POSIÇÃO COM O valor convertido para um byte de tamanho variável. Na última, eu estou armazenando o estado de um relé (ou 1 0). O EEPROMs abordadas são 000, 001, 010, 011 e 100. Não tenho nenhum problema de leitura e escrita para os 3 primeiros EEPROMs ea última, mas por alguma razão, eu não consigo ler ou gravar uma EEPROM 4 (011). Tentei trocar EEPROMs ao redor e ter determinado que há alguma coisa ver um com esse endereço. Meu código é bastante simples - modo de gravação ler = as posições dos servos e revezamento 4 conversor para byte de tamanho (servos) os dados e Armazenar. Modo de reprodução = ler os dados converte-lo para uma palavra-de tamanho (número de servos) e enviá-lo para fora. O mesmo código é utilizado para todos os 4 servos. 1, 2 e funcionam bem 3, apenas 4 pinos para fora durante a reprodução. O servo # 4, quando sob o controle manual, responde muito bem. Alguém tem alguma idéia do que poderia ser meu problema? Em anexo é um desenho mostrando o layout do meu EEPROM. Eu pensei que poderia ser um problema de tempo, mas porque é que só afetam # 4 e # 5, não?
    * PBP PIC 2,5 e 877A.
    * Aqui estão alguns snipetts Código:
    **** Var palavra Posit
    **** Posit1 palavra Var
    **** Posit2 palavra Var
    **** Posit3 palavra Var
    **** Var palavra Posit4
    **** Var PVal byte
    **** "EEPROM 1 CONTERA Dados sobre POSIÇÃO Servo de 1
    ****% EChip1W CON 10100000 'modo de gravação para EEPROM 1
    **** EChip1R% CON 10100001 'modo de leitura para EEPROM 1
    **** "EEPROM 2 Irá Conter dados sobre POSIÇÃO de Servo 2
    ****% EChip2W CON 10100010 'modo de gravação para EEPROM 2
    **** EChip2R% CON 10100011 'modo de leitura para EEPROM 2
    **** "EEPROM 3 CONTERA Dados sobre POSIÇÃO de Servo 3
    ****% EChip3W CON 10100100 'modo de gravação para EEPROM 3
    **** EChip3R% CON 10100101 'modo de leitura para EEPROM 3
    **** "EEPROM 4 Contém dados sobre POSIÇÃO de Servo 4
    ****% EChip4W CON 10100110 'modo de gravação para EEPROM 4
    **** EChip4R% CON 10100111 'modo de leitura para EEPROM 4
    **** "EEPROM 5 Irá Conter dados para Relay
    ****% EChip5W CON 10101000 'modo de gravação para EEPROM 5
    **** EChip5R% CON 10101001 'modo de leitura para 5 EEPROM
    * Modo de Gravação Código Snipett ---
    **** Gosub ReadPot1
    **** PULSOUT servo1, posit1
    **** Pausa 5
    **** Gosub ReadPot2
    **** PULSOUT servo2, posit2
    **** Pausa 5
    **** Gosub ReadPot3
    **** PULSOUT servo3, posit3
    **** Pausa 5
    **** Gosub ReadPot4
    **** PULSOUT servo4, posit4
    **** Pausa 5
    **** Se recordflag = 1 then 'dados armazenam
    ******** Posicao = (posit1 * 23) / 100 'converter um valor para <255
    ******** Pval byte = posit 'colocar em uma variável
    ******** I2CWRITE DPIN, CPIN, EChip1W, Addr [PVal] 'write it out
    ******** Posicao = (posit2 * 23) / 100
    ******** Pval = posit
    ******** I2CWRITE DPIN, CPIN, EChip2W, Addr [PVal]
    ******** Posicao = (posit3 * 23) / 100
    ******** I2CWRITE DPIN, CPIN, EChip3W, Addr [PVal]
    ******** Posicao = (posit4 * 23) / 100
    ******** I2CWRITE DPIN, CPIN, EChip4W, Addr [PVal]
    ******** Se RelaySw = 1 then
    ************ Pval = 1
    ******** Diferente
    ************ Pval = 0
    ******** Endif
    ******** I2CWRITE DPIN, CPIN, EChip5W, Addr [PVal]
    ******** Addr = addr + 1
    **** Endif
    * Modo de Reprodução Código Snipett ---
    **** Alta PlayLED
    **** Ler 16, Lastaddr.byte0
    **** Ler 17, lastaddr.byte1
    **** Addr = 1 para um lastaddr
    ******** I2cread dpin, CPIN, echip1r, addr, [pval]
    ******** Posit = pval * 4 'multiplicar por 4,03 para converter de volta para o Word
    ******** POSIÇÃO = posicao + ((pval * 3) / 100)
    ******** PULSOUT servo1, postular
    ******** Pausa 5
    ******** I2cread dpin, CPIN, echip2r, addr, [pval]
    ******** PULSOUT servo2, postular
    ******** Pausa 5
    ******** I2cread dpin, CPIN, echip3r, addr, [pval]
    ******** PULSOUT servo3, postular
    ******** Pausa 5
    ******** I2cread dpin, CPIN, echip4r, addr, [pval]
    ******** PULSOUT servo4, postular
    ******** Pausa 5
    ******** I2cread dpin, CPIN, echip5r, addr, [pval]
    ******** Pval Se = 0 então
    ************ Baixo Relay
    ************ Baixa RelayLED
    ******** Diferente
    ************ Relé de alta
    ************ Alta RelayLED
    ******** Endif
    ******** Se SSRecBtn = 1 then
    ************ Baixa PlayLED
    ************ Pause 500
    ************ Goto Start
    ******** Endif
    **** Próxima QUOTE [/]
    Olá
    iria me ajudar
    que registram o movimento do servo-4
    Tenho um programa em PBASIC
    Eu quero converter para PICBASIC Pro
    ser capaz de me ajudar
    coloque bacalhau em um novo tópico
    pesquisar
    Talking What's the matter ???
    Nice translation of post #1 ... ( Brazilian ??? )
    But where is the problem ???
    remove the "stars" or what ???
    Sorry, but help needed for translation : Just French ,English, German and Italian spoken ... Castejano only under torture.
    Talking
    Tanslation :
    I have a program in PBASIC I want to convert it for PICBASIC
    This program ALREADY is a PicBasicPro program ...
    What are you looking for ???
    Miami, Florida USA
    Acetronics,
    I really hate to correct you on this one, but in Brazil they don't speak "Brazilian" they speak Portuguese.
    Wink
    hi, Robert
    My dictionnary makes notable difference between Brazilian Portuguese and European Portuguese ... ( 2 different files ...)
    Just like Urugayan and Argentinian Spanish ... "Spanish" also called " Castejano ", BTW. ... that Spanish tourists couldn't understand while I went there for Working :
    I had to translate from Spanish to English, my accompanist Engineer from English to Castejano and vice versa ... Humour !!!
    sooo ... where the truth, in this world of supra-culture ???
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. Another I2C Slave Routine Problem
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 06:50
  4. Problem with I2C (24c32 eeprom)
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 5th February 2008, 10:00
  5. I2C eeprom and DS1307 @40MHz problem
    By ius01 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2007, 08:41
