Clock with timer interrupt0
Results 1 to 7 of 7
    Sep 2005
    Campbell, CA
    If you are running from AC, You can get good accuracy by timing the 50 or 60Hz from the power transformer. If the AC goes away, you can turn on your
    timer interrupt.
    Just like the little alarm clocks with battery backup.
    Charles Linquist
    The comment about using the AC line frequency is pretty sharp - The Hammond Clock company used to sell AC powered clocks with synchronous motors, and they would make gifts of these clocks to operators of the power utilities. The power plant operators would then have an incentive to regulate the AC line frequency.
    I think in your case, you should look into a real-time clock IC. There are many of these to choose from, and you can interface to them using a variety of techniques. As has been stated in this thread, trying to use the counter in a PIC to keep accurate time in the long term is a waste of, um, time.
    Apr 2006
    New Hampshire USA
    Smile Search and Research
    Darrel Taylor's
    A better Search tool for the Forum
    http://www.picbasic.co.uk/forum/showthread.php?t=4751
    Finds:
    Paul Borgmeier's
    Easy and Accurate Clocks without RTC IC
    http://www.picbasic.co.uk/forum/showthread.php?t=2129
  1. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  3. clock and date without using real timer
    By eepro in forum Off Topic
    Last Post: - 21st September 2008, 03:38
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. Help with realtime clock and timer
    By geselaw in forum mel PIC BASIC Pro
    Last Post: - 8th October 2005, 10:56
