Rx validation of checksum
Results 1 to 3 of 3
    Default Rx validation of checksum
    CALC_Checksum1:
        Checksum1 = 0
        WORD_HOLD = 0
        for i = 3 to MAX_LEN
           Word_Hold = Word_Hold + tx_data1(i)
         next
         Checksum1 = WORD_HOLD.byte0 ^ $FF
    CALC_Checksum2:
        Checksum2 = 0
           Checksum2 = Checksum2 + tx_data1(i)
        next
        Checksum2 =  Checksum2 // 256
       'Checksum2 = -Checksum2
    the above routines i pieced together from other posts here to genereate a checksum for transimitted data packets.
    to validate on the received end, do i run the same routine and compare values to see if the checksums are equal?
    Yes you do.
    But instead of this double checksum i'd prefer the 16 bit CRC check. More reliable.
    Look here for the fast sub routine from the usual suspect:
    http://www.picbasic.co.uk/forum/showthread.php?t=11790
    Thanks Ioannis.
    Indeed, DT's looks quite fast. a handy routine i'll "borrow" into me tool box.
    btw, i would use [either or] of my sub-routines, not both at the same time.
    Cheers!
  1. NMEA CheckSum Routine
    By Tom Gonser in forum Code Examples
    Last Post: - 6th June 2015, 22:24
  2. 4 Bytes one button press
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 15th January 2010, 22:36
  3. Checksum
    Last Post: - 24th October 2009, 04:09
  4. Creating Checksum in PBP
    Last Post: - 16th March 2005, 04:49
  5. Checksum problem!
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2004, 07:21
