Greetings, I have been successfully using several different LCD modules from several different manufacturers. Of course, I ran into an issue. I have an existing circuit using a 16F676 that seems fine with a Densitron 8*2 display as well as a Powertip 8*2 display. I have a 16F684 circuit that works properly with the densitron display, but the powertip display seems to be putting garbage to line one only. If I have the program only clear the display, the display seems to be cleared, but it displays the first character of line one as a block with a flashing underline cursor in position 2. I have tried extending command us and data us as well as extending power up pauses. PBP 2.47 . Any clues? Thanks,Scott
