16f628a porta.5 as input
Results 1 to 5 of 5
    Sep 2006
    Default 16f628a porta.5 as input
    HI ALL,
    Using portb as output : working well.
    Using porta.0 to 7 except porta.4 & 5 as input with pull-up resistor working well with 0v trigger, Can i use also a pull-up resistor to porta.4 &5? or do i need to use pull-down resistor then trigger with +5v input.. Looking for help before messing up my IC.( didn't try yet,)
    Thanks.
    Jun 2008
    Milwaukee, WI
    you should be able to wire the resistor as a pullup or pulldown depending on what your input signal is.
    Lightbulb
    Hi, Naga
    you can always use pullup or pulldown with inputs ...
    But take care to PORTA.4 and 5 ... They're not protected against voltage over VDD !!! ( see Datasheet p 33 ...)
    Sep 2006
    Thanks to all, Is there any way that can porta.5 be used as output?..Thanx again.
    Wink
    The only way is to use it as output is as an OPEN Collector output ...
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 19:51
  2. problem with input and output (18F452)
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 00:21
  3. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 21:31
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  5. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
