Basic Stamp BS2 replacement?
Results 1 to 6 of 6
    Here's one:
    http://www.sourceboost.com/Products/.../Overview.html
    You should see one heck of an improvement. Try the turbo (40 mhz) PIC18F2520 version.
    Looks like they are out of stock though. I think I have seen others. Just can't find them now.
    Walter
    http://www.scalerobotics.com
    Basically, a BS2 is a PIC 16C57 ... with some peripherals as EEPROM, regulator, Brownout circuit ...
    The scheme and components list is available on Parallax site ...
    Sep 2007
    USA, CA
    Walter--thanks; I checked them out...unfortunately they've discontinued it. Apparently nobody wants them.
    Alain--I'm aware of that. I only want a couple, and I don't want to waste the time laying out a board if I can buy one finished.
    Quote Originally Posted by tenaja View Post
    That's too bad. It looked pretty cool. It looks like you might have to make one yourself, you could use their design: http://www.sourceboost.com/Products/...urbo_schem.pdf
    Or, you could get a pre-made Basic ATOM with a PIC16f876 and make a programming header on a breadboard to program it yourself, erasing the Atom basic from it. http://basicmicro.com/Product.aspx?p...8&CategoryID=1
  1. Loop with two motor and 2 sensors
  2. About the replacement of the indicator with BASIC.
    By apollo21 in forum mel PIC BASIC Pro
    Last Post: - 8th June 2008, 05:56
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  4. convert Basic Stamp2 (BS2) => Pic
    By bs2rdu in forum mel PIC BASIC Pro
    Last Post: - 15th September 2005, 20:55
  5. serial comm from Pic to STAMP
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 5th April 2004, 00:58
