Power Up problem
Results 1 to 5 of 5
    Power up timer might help...
    Also, have you got a capacitor on the power lines between regulator and PIC?
    On your MCLR pin, you need a pullup resistor 4.7k and a cap to ground. Try 1uF~4.7uF. You want voltage to come up quickly and not linger below threshold for too long on the pin. At the same time you want to filter out voltage hiccups.
    Nick
    Hi Tobias,
    Power up timer enable and insert a short pause in the start up code of your PIC to allow the serial LCD time to stabilize, .01 µF at the PIC power pins and make sure the serial out line has the proper pull up / pull down resistors as required. Pull up for data TRUE, pull down for data INVERTED. This allows the port to idle in the correct state. Be sure to provide a pull up resistor on the MCLR if you have enabled it in your config statement.
    HTH
    JS
    Thanks guys I appreciate the input I will give it a go with the suggested changes when I get home on saturday.
  1. power problem (newbie here!)
    By clocks in forum General
    Last Post: - 2nd May 2009, 13:18
  2. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 19:30
  3. OT - power supply problem
    Last Post: - 2nd March 2006, 00:14
  4. Power up problem
    By Ken McDonald in forum General
    Last Post: - 28th December 2004, 17:06
  5. power up problem
    By rookieofbasic in forum General
    Last Post: - 2nd April 2004, 12:01
