Array values changing
Results 1 to 2 of 2
    Oct 2009
    Thumbs down Array values changing
    PBP 2.46
    18F4550
    I have this large array in which I load values from EEPROM. Everything loads in fine, and I have verified that the contents are correct. The array is defined as:
    Temp_Calib var byte[44]
    When I run the code below, the first two entries of the array change even though there is no read or write call to the Temp_Calib array. I know the value is changing here because of the debugs before and after the loop.
            debug " 0: Temp_Calib[0]: ",#Temp_Calib[0],10,13
            for j = 0 to 11
                ADCIN ad597, advalue[j]
            next j
            debug " 1: Temp_Calib[0]: ",#Temp_Calib[0],10,13
    Here is the output I see:
    0: Temp_Calib[0]: 10
    1: Temp_Calib[0]: 128
    What the f-? Am I out of ram?
    Oct 2009
    the other array is initialized here:
    AdValue var WORD[12]
    Edit: never mind ... I figured it out simply by typing it correctly in the forum. The loop in my program was going from 1 to 12 instead of 0 to 11.
    Last Post: - 14th June 2016, 07:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 08:02
  4. Reading Array values into variables
    Last Post: - 21st March 2005, 10:30
  5. Putting values into an array
    By Vince in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2003, 07:22
