Hserin parsing string...again?
Results 1 to 22 of 22
    Dec 2005
    Salt Lake City, Ut, USA
    Will this fly...nearest you can tell?
    'PIC 16F917
    'Clock setup
        Define OSC 20
    'Interrupt setups
        INTCON = %11000000      'Enable: Global interrupts, Peripheral interrupts
        PIE1 = %01110000        'Enable: ADC interrupt, Rx interrupt, Tx interrupt
    'Pin setups
        ANSEL = %10000000       'Analog input on E.2/AN7, all others digital
        TRISA = %11000000       'PortA: 0-5 = output, 6-7 = input
        TRISB = %11111111       'PortB: 0-7 = input (defaults)
        TRISC = %11011111       'PortC: 0-5&7 = input, 6 = output
        TRISD = %11111111       'PortD: 0-7 = input (defaults)
        TRISE = %00000100       'PortE: 0&1 = output, 2 = input, 3-7 = N/A
    'Vref setups
        VRCON = %10001111       'Enable Vref, set high range, set value (3.59 Vdc)
    'Usart setups
        SPBRG = %00011001       'Set 9600 baud w/20MHz clock
        TXSTA = %00100110       'Enable transmit, set BRGH high
        RCSTA = %10010000       'Enable Usart, enable receiver
    'ADC setups
        ADCON0 = %10011101      'Right justify (8 bit result in ADRESL), Select ch.7, enable ADC
        ADCON1 = %00100000      'Set ADC clock to 625kHz
    'LCD setup (16 x 2 lines)
        Define LCD_BITS 4       '4 data interface lines
        Define LCD_DREG PORTA   'LCD data port
        Define LCD_DBIT 0       'LCD data bits 0-4
        Define LCD_RSREG PORTA  'LCD register select port
        Define LCD_RSBIT 4      'LCD register select bit
        Define LCD_EREG PORTA   'LCD enable port
        Define LCD_EBIT 5       'LCD enable bit
    Ser_Cmd_Numb var byte
    Ser_Cmd_Val var byte
    THC_Enable_In var PORTC.0
    TTV_Val var byte
    HYS_Val var byte
    Torch_V_Now var byte
    Torch_Up var PORTE.0
    Torch_Dn var PORTE.1
    TTV_Val = 120
    HYS_Val = 0
    pause 1000                  'Pause for 1 second for LCD warmup
    LCDout $fe, 1, "---LCD WARMUP---"
    Lcdout $fe, $40, "----FINISHED----"
    pause 5000                 'Pause for 5 seconds for user viewing
    Start:
        IF THC_Enable_In = 0 then
            PIE1.6 = 0        'Turn off ADC interrupt
            PIE1.5 = 1        'Turn on Rx interrupt
            LCDout $fe, 1, "READY TO RECEIVE"
            Lcdout $fe, $40, "COMMAND:C###V###"
            If PIR1.5 = 1 Then Goto New_SerIn
            PAUSE 500
            GOTO START
            PIE1.6 = 1        'Turn on ADC interrupt
            PIE1.5 = 0        'Turn off Rx interrupt
            ADCON0.1 = 1    'Start ADC conversion
            if PIR1.6 = 1 THEN GOTO New_ADC
            LCDout $fe, 1, "TARGET VDC : ", dec TTV_Val
            Lcdout $fe, $40, "PLASMA VDC : ", dec Torch_V_Now
            select case Torch_V_Now
                case Torch_V_Now > TTV_Val + hys_val
                    high torch_dn
                    low torch_up
                case Torch_V_Now < TTV_Val - hys_val
                    high torch_up
                    low torch_dn
                case else
                    low torch_up
                    low torch_dn
            end select
    GOTO Start
    New_ADC:
        Torch_V_Now = ADRESL
        PIR1.6 = 0
    New_SerIn:
    '******Command structure is: C###V###
        PIE1 = %00000000                                                    'Disable interrupts
            hserin 100, start, [wait ("C"),dec3 Ser_Cmd_numb]
            hserin 100, start, [wait ("V"),dec3 Ser_Cmd_val]
            LCDout $fe, 1, "COMMAND RECEIVED"
            Lcdout $fe, $40, "-- C", dec Ser_Cmd_numb,"  V", dec Ser_Cmd_val, " --"
            pause 3000                                                  'Pause for 3 seconds for user viewing
            GOTO Chk_Cmd
        PIE1 = %01110000                                                    'Enable interrupts
    Chk_Cmd:
        select case Ser_Cmd_numb        '001 to 256
            case 1                      'Torch Target Voltage
                TTV_val = Ser_Cmd_Val
            case 2                     'Hysteresis Value
                HYS_Val = Ser_Cmd_Val
            Case else
                LCDout $fe, 1, " COMMAND NOT IN "
                Lcdout $fe, $40, " DEFINED SCOPE! "
        END SELECT
    Cut and shuffle as you will . Thanks guys.
    Chris
    Dec 2005
    Hello all,
    Weird, I'm responding to my own thread . Well, I cut and shuffled my previous code for the better...I hope! Here it is, for the critique...
    'PIC 16F76
    'Clock setup
        Define OSC 20
    'Interrupt setups
        PIE1 = %01000000        'Enable: ADC interrupt
    'ADC setups
        ADCON0 = %10000001      'ADC CLOCK = 625kHz, Select ch.0, enable ADC
    'Pin setups
        TRISA = %00000001       'PortA: 1-5 = output, 0 = input, 6-7 = N/A
        TRISC = %11111111       'PortC: 0-7 = input (defaults)
    'Usart setups
    'LCD setup (16 x 4 lines)
        DEFINE LCD_LINES 4
        Define LCD_DREG PORTB   'LCD data port
        Define LCD_DBIT 4       'LCD data bits 0-4
        Define LCD_RSREG PORTB  'LCD register select port
        Define LCD_RSBIT 3      'LCD register select bit
        Define LCD_EREG PORTB   'LCD enable port
        Define LCD_EBIT 0       'LCD enable bit
    Setup_YN var byte
    Torch_Lock_Val var byte
    CNT VAR BYTE
    CNT2 VAR BYTE
    Hyst_Val var byte
    First_Run var bit
    Torch_Lock_Val = 120
    Hyst_Val = 0
    first_run = 1
    low enable_in
    LCDout $fe, 1
    LCDout $fe, $03, "WELCOME TO THE"
    Lcdout $fe, $42, "DOUBLE DOWN IND."
    Lcdout $fe, $14, "TORCH HEIGHT CONTROL"
    Lcdout $fe, $54, "LCD WARMING UP"
        FOR CNT2 = 1 TO 5
            FOR CNT = 0 TO 4
                Lcdout $fe, $63 + CNT, "."
                PAUSE 400
                Lcdout $fe, $63 + CNT, $20
            NEXT CNT
        NEXT CNT2
    Start:
        IF Enable_In = 0 then
        '***** START MSG1 *****
            LCDout $fe, 1
            LCDout $fe, $03, "CONTROL IS IN"
            Lcdout $fe, $43, "STANDBY MODE."
            LCDout $fe, $15, "WOULD YOU LIKE TO"
            Lcdout $fe, $55, "RUN SETUP? (Y/N)"
            Lcdout $fe, $66
            LCDOUT $fe, $0F
        '***** END MSG1 *****
            HSERIN [Setup_YN]
                if setup_yn != "Y" then goto start
            Bad_Torch_Lock_Val:
        '***** START MSG2 *****
            LCDout $fe, 1
            LCDout $fe, $01, "ENTER A ", $22, "LOCK TO", $22
            Lcdout $fe, $40, "TORCH VOLTAGE VALUE:"
            LCDout $fe, $17, $22, "X", $22, " TO EXIT OR"
            Lcdout $fe, $56, "(000 - 256)  ___"
            Lcdout $fe, $63
            LCDOUT $fe, $0F
        '***** END MSG2 *****
            HSERIN [DEC Torch_Lock_Val]
            if (Torch_Lock_Val >= 0) and (Torch_Lock_Val <= 256) then goto Bad_Hyst_Val
            if Torch_Lock_Val = "X" then goto start
                '***** START ERR_MSG1 *****
                    LCDout $fe, 1
                    LCDout $fe, $02, "ONLY (000 - 256)"
                    Lcdout $fe, $40, "ALLOWED!"
                    LCDout $fe, $17, "PLEASE STANDBY"
                        FOR CNT = 0 TO 19
                            Lcdout $fe, $54 + CNT, "."
                            PAUSE 150
                        NEXT CNT
                '***** END ERR_MSG1 *****
                    GOTO Bad_Torch_Lock_Val
            Bad_Hyst_Val:
        '***** START MSG3 *****
            LCDout $fe, 1
            LCDout $fe, $01, "ENTER A HYSTERESIS"
            Lcdout $fe, $42, "+/- VOLTAGE VALUE:"
            Lcdout $fe, $58, "(0 - 5)    _"
            Lcdout $fe, $63
            LCDOUT $fe, $0F
        '***** END MSG3 *****
            HSERIN [DEC hyst_Val]
                if (hyst_Val >= 0) and (hyst_Val < 6) then
                '***** START MSG4 *****
                    LCDout $fe, 1
                    LCDout $fe, $03, "SETUP COMPLETE"
                    Lcdout $fe, $40, "TORCH LOCK VALUE=", Torch_Lock_Val
                    LCDout $fe, $15, "HYSTERESIS VALUE=", hyst_Val
                        FOR CNT = 0 TO 19
                            PAUSE 300
                        NEXT CNT
                '***** END MSG4 *****
                    goto start
                if hyst_Val = "X" then goto start
                '***** START ERR_MSG2 *****
                    LCDout $fe, 1
                    LCDout $fe, $04, "ONLY (0 - 5)"
                    Lcdout $fe, $46, "ALLOWED!"
                        FOR CNT = 0 TO 19
                            PAUSE 150
                        NEXT CNT
                '***** END ERR_MSG2 *****
                    GOTO Bad_Hyst_Val
                first_run = 1
            ADCON0.2 = 1                                'Start ADC conversion
            if PIR1.6 = 1 THEN GOTO New_ADC             'New ADC interrupt flag
            if first_run = 1 then
                LCDout $fe, 1
                Lcdout $fe, $01, "PLASMA VOLTAGE=", Torch_V_Now
                Lcdout $fe, $40, "--------------------"
                Lcdout $fe, $14, "TORCH LOCK VALUE=", Torch_Lock_Val
                LCDout $fe, $55, "HYSTERESIS VALUE=", hyst_Val
                FIRST_RUN = 0
                Lcdout $fe, $10, Torch_V_Now
                case Torch_V_Now > Torch_Lock_Val + hysT_val
                    high torch_dn
                    low torch_up
                case Torch_V_Now < Torch_Lock_Val - hysT_val
                    high torch_up
                    low torch_dn
                case else
                    low torch_up
                    low torch_dn
            end select
    GOTO Start
    New_ADC:
        Torch_V_Now = ADRES                             'Read ADC value into VAR
        PIR1.6 = 0                                      'Clear ADC interrupt flag
    Does that seem to eliminate the string parsing gig altogether? I think I'm so stuck in the thinking of no LCD... First time I've messed with 'em. I think it just saved me a load of brain fry... I dunno?
    Comments greatly appreciated!
    Thanks all,
    Chris
    Dec 2005
    Can one of you fine folks look this revised code over to see if you think it'll do the trick. I heavily commented it for sake of keeping my head straight Anyhow, any thought are helpful thoughts at this point.
    Thanks all,
    Chris
    'PIC 16F917
    'Clock setup
        Define OSC 20
    'Interrupt setups
        PIE1 = %01100000        'Enable: ADC interrupt, Receive interrupt
    'ADC setups
        ADCON0 = %10100001      'Rt justified, VRef + pin, Select ch.0, enable ADC
        ADCON1 = %00100000      'Fosc / 32
    'Pin setups
        ANSEL = %00000001       'Port A.0 = analog input
        TRISA = %11101001       'PortA: 1,2,4 = output, 0,3,5,6,7 = input
        TRISB = %11000000       'PortB: 0-5 = LCD output, 6,7 = ICSP input
        TRISE = %11111111       'PortE: 0-2 = input (defaults), 3-7 = N/A
    'Usart setups
        DEFINE LCD_LINES 4
        Define LCD_DREG PORTD   'LCD data port
        Define LCD_DBIT 4       'LCD data bits, pic starting pin 0 or 4
        Define LCD_RSREG PORTD  'LCD register select port
        Define LCD_RSBIT 2      'LCD register select bit
        Define LCD_EREG PORTD   'LCD enable port
        Define LCD_EBIT 3       'LCD enable bit
    'Variable setups
    RxFlag VAR PIR1.5
    RxInt var PIE1.5
    ADCFlag var PIR1.6
    ADCInt var PIE1.6
    ADCGo var ADCON0.2
    SerInStr var byte(25)
    X VAR BYTE ' Holds "$" start position
    Y VAR BYTE ' Holds "=" mid position
    Z VAR BYTE ' Holds "*" end position
    Index VAR BYTE ' Index pointer
    B0 VAR WORD
    B1 VAR WORD
    TorchLockVal var word
    CNT VAR BYTE
    CNT2 VAR BYTE
    TorchHystVal var byte
    FirstRun var bit
    TorchVNow var byte
    ControlIsTracking var PORTA.1
    TorchUp var PORTA.2
    TorchDn var PORTA.4
    EnableIn var PORTA.5
    InMotion var PORTE.1
    'Initial variable values
    TorchLockVal = 120
    TorchHystVal = 0
    firstrun = 1
    LCDout $fe, 1
    Lcdout $fe, $42, "DOUBLE D ENT."
        FOR CNT2 = 1 TO 5
            FOR CNT = 0 TO 4
                PAUSE 400
            NEXT CNT
        NEXT CNT2
    Start:
    'Enter here if no Toolpath is running AND THC is not enabled
        IF (EnableIn = 0) and (InMotion = 0) then
            RxInt = 1                               'Enable receive interrupt
            ADCInt = 0                              'Disable ADC interrupt
            LCDout $fe, 1
            LCDout $fe, $15, "READY TO RECEIVE"
            Lcdout $fe, $55, "A COMMAND"
            Lcdout $fe, $66
            LCDOUT $fe, $0F
        firstrun = 1
    'Enter here if Toolpath is running OR THC is enabled OR both
            RxInt = 0                                   'Disable receive interrupt
            ADCInt = 1                                  'Enable ADC interrupt
            ADCGo = 1                                   'Start ADC conversion
            if ADCFlag = 1 THEN GOTO NewADC             'New ADC interrupt flag
            if firstrun = 1 then                        'Write the entire message
                LCDout $fe, 1
                Lcdout $fe, $01, "PLASMA VOLTAGE=", TorchVNow
                Lcdout $fe, $14, "TORCH LOCK VALUE=", TorchLockVal
                LCDout $fe, $55, "HYSTERESIS VALUE=", TorchhystVal
                FIRSTRUN = 0
            ELSE                                        'Write just the changed values
                Lcdout $fe, $10, TorchVNow
            select case TorchVNow
                case TorchVNow > TorchLockVal + TorchhysTval 'Torch is too high, tell CNC to lower it
                    high torchdn
                    low torchup
                case TorchVNow < TorchLockVal - TorchhysTval 'Torch is too low, tell CNC to raise it
                    high torchup
                    low torchdn
                case else                               'Torch is locked on, we're good
                    low torchup
                    low torchdn
            end select
    GOTO Start
    'ADC interrupt routine-------------------------------------------------------
    NewADC:
        TorchVNow = ADRESL                            'Read ADC value into VAR
        ADCFlag = 0                                   'Clear ADC interrupt flag
    'Serial interrupt routine----------------------------------------------------
    SerialInt:
    'Command structure ex:
    '     $CommandWord=###*
    SerInStr = 0                                    'Clear the buffer
    hserin[str SerInStr\25\42]                      'Fill the buffer. Move on when "*" is found
    'Thanks to Bruce: www.rentron.com for the parsing routine
    Get_Start:                                      'X will hold the start "$" position
    FOR X = 0 TO 24                                 'Iterate through the entire buffer
    IF SerInStr[X] = "$" THEN Get_Mid               'We found it, move on to next find
    NEXT X
    GOTO Start                                      'Buffer is empty or improper Command string
    Get_Mid:                                        'Y will hold the end "=" position
    FOR Y = X+1 TO 24                               'Iterate through the buffer from last found to end
    IF SerInStr[Y] = "=" THEN Get_End                  'We found it, move on to next find
    NEXT Y
    Get_End:                                        'Z will hold the end "*" position
    FOR Z = Y+1 TO 24                               'Iterate through the buffer from last found to end
    IF SerInStr[Z] = "*" THEN ParseCommand             'We found it, now let's parse it
    NEXT Z
    Continued below... over 10000 characters... sorry
    Dec 2005
    ParseCommand:
    CmdLen var byte                                 'Declare byte var to hold "command word" string length
    cmdlen = y-x-1                                  'Calc string length by: "=" position - "$" position -1
    CmdWord var byte(cmdlen)                        'Declare byte array based on string length
    For Index = 0 to cmdlen-1
        CmdWord[index] = SerInStr[index+x+1]        'Fill byte array with "command word"
    next index
    ValLen var byte                                 'Declare byte var to hold "command value" string length
    ValLen = z-y-1                                  'Calc string length by: "*" position - "=" position -1
    CmdVal var byte(ValLen)                         'Declare byte array based on string length
    For Index = 0 to ValLen-1
        CmdVal[index] = (SerInStr[index+y+1]-"0")   'Fill byte array with "command value"
    next index
    if CmdWord = "SetTorchLockVal" then             'Compare variable "command word" with static string
    select case ValLen                              'Do math to get byte value based on "command value" length
        case 1
            TorchLockVal = CmdVal
        case 2
            TorchLockVal = (CmdVal[0] * 10) + CmdVal[1]
        case 3
            TorchLockVal = (CmdVal[0] * 100) + (CmdVal[1] * 10) + CmdVal[2]
        case else
            goto err_TorchLockVal
    end select
    if TorchLockVal > 255 then                     'If we're NOT 8 bit, bad news
                err_TorchLockVal:
                LCDout $fe, 1
                LCDout $fe, $02, "ONLY (000 - 255)"
                    FOR CNT = 0 TO 19
                        PAUSE 150
                    NEXT CNT
                SerInStr = 0                       'Flush the buffer
                TorchLockVal = 0                   'Flush the "Lock Value"
                GOTO Start                         'Start over
            ELSE                                   'We're 8 bit, good
                LCDout $fe, 1
                LCDout $fe, $01, "RECEIVED COMMAND:"
                Lcdout $fe, $42, CmdWord, "=",TorchLockVal
                LCDout $fe, $17, "TORCH LOCK VALUE"
                Lcdout $fe, $58, "SET TO: ", TorchLockVal
                PAUSE 5000                         '5 second view of LCD confirmation
    if CmdWord = "SetTorchHystVal" then
        TorchHystVal = CmdVal
            if TorchHystVal > 6 then
                LCDout $fe, 1
                    FOR CNT = 0 TO 19
                        PAUSE 150
                    NEXT CNT
                SerInStr = 0
                TorchHystVal = 0
                RxInt = 1
                GOTO Start
                LCDout $fe, 1
                Lcdout $fe, $42, CmdWord, "=",TorchHystVal
                LCDout $fe, $17, "TORCH HYST. VALUE"
                Lcdout $fe, $58, "SET TO: ", TorchHystVal
                SerInStr = 0
                PAUSE 5000
                GOTO Start
    Dec 2005
    Sorry guys for not compiling the above code before posting! Shame on me. I did fix all the errors with variables, with the exception of these:
    '^^^^^Bad data type^^^^^
    '^^^^^Bad expression^^^^^
    Any thoughts as to what I'm doing wrong? Probably a newbie mistake, I hope.
    Thanks again all,
    Chris
    cmdlen is a variable.
    Array sizes can't be changed at run-time.
    It must be a constant.
    ditto
    Do not pass GO, Do not collect $200.
    Do not attempt to compare strings. PBP doesn't have them.
    ditto
    Dec 2005
    Thanks DT,
    I kinda thought that was the deal... So I think I'm going to go with the "KISS" method and do something like my original thought:
    Command String...
    C###V###
    CmdWord VAR word
    CmdVal VAR word
    HSERIN(wait ("C"), DEC3 CmdWord)
    HSERIN(wait ("V"), DEC3 CmdVal)
    I think that will save me a load of code...I'll just have to write a command destruction manual so I know what command does what. Small price to pay, I think.
    On a programming note: Say I want to make sure the CmdWord and CmdVal vars are within a byte sized var. I declare them as words, so I can compare later in code.
    Would this be a simple way to do this...
    If CmdWord < 255 Then
    'We're good, do something with it
    Else
    'We are greater than 8 bit, bad command, start over
    EndIf
    Should I declare them as bytes right up front, and look for >255? What happens to the byte if say "500" is sent. Does it overflow to (500 - 255)... does the byte become "0" or "245". Hopefully that is not a way dumb question, just trying to not have to flash my chip a hundred times to change 1 line of code each time.
    Thanks for your input DT,
    Chris
  1. HSERIN for variable length string
    Last Post: - 19th February 2010, 06:58
  2. parsing string from hserin
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 19:42
  3. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  4. String Parsing
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 18:20
  5. serial string parsing
    By billybobbins in forum mel PIC BASIC Pro
    Last Post: - 8th September 2004, 22:34
