Hallo
hier die überarbeitung
meine Probleme sind die vielen @..... noch vieleicht hat noch einer eine idee wo ich noch etwas umschreiben kann.
Vielen dank an alle im voraus.
;Files Assignment
symbol A_X1 = PORTA.1 ; A_X1 to PORTA.1
symbol A_X2 = PORTA.0 ; A_X1 to PORTA.0
symbol A_X3 = PORTA.7 ; A_X1 to PORTA.7
symbol A_X4 = PORTA.6 ; A_X1 to PORTA.6
symbol A_X5 = PORTA.5 ; A_X1 to PORTA.5
symbol A_X6 = PORTA.4 ; A_X1 to PORTA.4
symbol A_X7 = PORTA.3 ; A_X1 to PORTA.3
symbol A_X8 = PORTA.2 ; A_X1 to PORTA.2
bit0 var R_DATEN.0 ;ist bit0 von R_DATEN
bit1 var R_DATEN.1 ;ist bit1 von R_DATEN
bit2 var R_DATEN.2 ;ist bit2 von R_DATEN
bit3 var R_DATEN.3 ;ist bit3 von R_DATEN
bit4 var R_DATEN.4 ;ist bit4 von R_DATEN
bit5 var R_DATEN.5 ;ist bit5 von R_DATEN
bit6 var R_DATEN.6 ;ist bit6 von R_DATEN
bit7 var R_DATEN.7 ;ist bit7 von R_DATEN
symbol B_CLK = PORTB.0 ; B_CLK to PORTB.0
symbol B_OUT = PORTB.1 ; B_OUT to PORTB.1
symbol B_LED = PORTB.2 ; B_LED to PORTB.2
symbol B_IN = PORTB.6 ; B_IN to PORTB.6
symbol B_PS = PORTB.7 ; B_PS to PORTB.7
symbol F_PS_RDY = PORTB.1 ; F_PS_RDY to PORTB.1
R_DATEN var BYTE
R_OLD var BYTE
R_Flag var BYTE
R_DATEN equ 20h ; fuer Speichern der Daten und Schieben
R_CNT1 equ 22h ; counter 1
R_CNT2 equ 23h ; counter 2
R_FLASH equ 24h ; for flashing LED
R_OLD equ 25h ; Register for old values
R_FLAG equ 26h ; Register for flags
F_PS_RDY equ d'1' ; Ready-Flag
W_TEMP equ h'40' ; saving W-Register
STATUS_TEMP equ h'41' ; saving Status-Register
B_PS equ d'7' ; Port B, PS-Eingang
B_OUT equ d'1' ;Output ; Port B, Data-OUT
B_IN equ d'6' ; Port B, Data-IN
A_LED equ d'2' ;Output ; Port A, LED-Ansteuerung
B_CLK equ d'0' ; Port B, Clock
endasm
goto start
; Interupt Service Routine ISR
@ org 0004h ; Interupt Vector
; ----- Saving STATUS and W ----------------------
@ movwf W_TEMP ; W-Register Retten
@ swapf STATUS,W ; Status-Reg. -> w
@ movwf STATUS_TEMP ; Status-Reg. Retten
; ----- IR IB0-Change (negative Edge) ------------
@ btfss INTCON,INTF
goto ir_2
@ bcf INTCON,INTF ; clear IR-Flag
@ btfss R_DATEN,0 ; sofort Ausgabe des
@ bsf PORTB,B_OUT ; .. Bits #0 von
@ btfsc R_DATEN,0 ; .. R-Daten an
@ bcf PORTB,B_OUT ; .. DATA_OUT (invertiert)
If B_CLK <>1 then
B_LED =0
toggle B_LED
If B_PS =0 then gosub lesen
@ btfss PORTB,B_IN ; Bit am Eingang
@ bsf STATUS,C ; .. DATA-IN zum
@ btfsc PORTB,B_IN ; .. Nachschieben in
@ bcf STATUS,C ; .. Schieberegister in C
@ rrf R_DATEN,F ; Daten nachschieben (invertiert)
; ab hier sind die Daten in R_DATEN aktualisiert und fertig für
; die nächste pos. Flanke von CLK (#0 kann dann sofort an DATA_OUT
; weitergegeben werden).
; ----- IR by Timer 0 (idle-state) ------------
ir_2:
@ btfss INTCON,T0IF
goto posret
@ bcf INTCON,T0IF ; clear IR-Flag
@ comf PORTA,W
@ movwf PORTA
; ----- Restore STATUS and W ---------------------
posret:
@ swapf STATUS_TEMP,W ; in w-Register
@ movwf STATUS ; w -> Status
@ SWAPF W_TEMP,F ; W_TEMP -> W, ohne..
@ SWAPF W_TEMP,W ; .. Z-Flag zu aendern
@ retfie
; Programm
@ org 0060h ; Position des Programms
start:
; Konfiguration PORTS
; bsf STATUS,RP0 ; -> BANK 1
; movlw B'11111111'
TRISB = %11000001
TRISA = %11111111
CMCON =%00000111
OPTION_REG =%10000111
T2CON =%01111101
INTCON =%11110000
PIE1 =%00000000
; Main Loop
loop:
CLEARWDT ; Watchdog-Timer loeschen
if B_PS =1 then goto loop2 ; if PS = 1
@ btfsc R_FLAG,F_PS_RDY ; and PS_RDY not set
goto loop
@ movf R_OLD,W ; .. the reload old values
@ movwf R_DATEN ;
@ bsf R_FLAG,F_PS_RDY ; .. set FLAG PS_RDY
goto loop
loop2:
@ bcf R_FLAG,F_PS_RDY ; if PS = LOW reset PS_RDY
goto loop
; Routine:lesen
lesen:
@ clrf R_DATEN
IF A_X8 =1 then
Bit0 =0
Else
;Bit0 =1
@ bsf R_DATEN,0
IF A_X7 =1 then
Bit1 =0
Else
;Bit1 =1
@ bsf R_DATEN,1
IF A_X6 =1 then
Bit2 =0
Else
;Bit2 =1
@ bsf R_DATEN,2
IF A_X5 =1 then
Bit3 =0
Else
;Bit3 =1
@ bsf R_DATEN,3
IF A_X4 =1 then
Bit4 =0
Else
;Bit4 =1
@ bsf R_DATEN,4
IF A_X3 =1 then
Bit5 =0
Else
;Bit5 =1
@ bsf R_DATEN,5
IF A_X2 =1 then
Bit6 =0
Else
;Bit6 =1
@ bsf R_DATEN,6
IF A_X1 =1 then
Bit7 =0
Else
;Bit7 =1
@ bsf R_DATEN,7
@ movf R_DATEN,W
@ movwf R_OLD
