I took my interrupt driven car to the gym this morning. It behaved about the same as my old HPWM design. When going slowly it just barely made the left turns at the corners. It did seem to go straight with less wiggle, but it still hit the wall occasionally.
It appears that the problem is reaction time. My delving into an interrupt driven system was motivated by the guess that randomly (in time) changing the HPWM command might be confusing the electronic speed control. On this account I detect little difference.
Another reason for regularly timed SONAR triggers was to take advantage of PID control. I have not coded that experiment. I am not convinced quicker reaction time will result.
I partially solved the TOGGLE problem by inserting the following code right after 'main:'. This system does not toggle control between PIC and RC, but it does stop (Brake) the car when the radio transmitter is turned ON. It is not a nice picture - a 75 year old man running around a gymnasium trying to tackle an out-of-control RC car.
The code samples channel3. This is the steering PWM signal from the car's radio receiver. There are pulses on that line as soon as the transmitter is activated.
switchtoPIC = 2
WHILE switchtoPIC >= 2
COUNT channel3, 65, switchtoPIC
WHEELS = Brake
WEND
I am not sure what to do now. The reaction time seems quick enough on the bench.
