PBP projects for R/C models
Results 1 to 40 of 772
    Aug 2010
    Maryland, USA
    Walter, I like your idea of the 18.5 ms plus servo out to make up the 20ms loop. I need just that for my project. I will want to use 1 timer to control the loop and the pulse, so that seems the best idea to me.
    -Bert
    Nov 2009
    Fitchburg, Mass
    Red face I've come to a screeching halt
    "Verification of Program Memory failed at address 0x00000000"
    I tried some old code that I KNOW loaded. Not today.
    I swapped out the PIC. That was not the problem. I reseated all the patch wires. That made no difference.
    I restarted the PICKIT2 programmer. That did not help.
    I tried with a PICKIT2 board - the one on which I ran the blinkys - no problem. It liked to load and blink.
    Where do I start?
    Ken
    Nov 2009
    Fitchburg, Mass
    Smile Fixed it!!
    It was a wire I had added to give the LOGIC TOOL more information. I do not understand why the PICKIT objected. But all is well.
    The interrupt driven system sort of works. We'll see more tomorrow.
    Thanks again for your help and support.
    Ken
    Nov 2009
    Fitchburg, Mass
    Default Works as good as before
    I've got the system working interrupt driven. I do not have proportional controls implemented - yet.
    On the bench the car seems as responsive as before. We'll see when I take it to the gym.
    One thing I have not figured. How, now, to I disable interrupts when the radio transmitter has been
    turned ON? At the very end of this code pack is my old WHILE loop that worked - in the day.
    symbol trigright = PORTB.0 ' Define output pin for Trigger pulse
    symbol trigfront = PORTB.1 ' Define output pin for Trigger pulse
    symbol trigleft  = PORTB.3 ' Define output pin for TRigger pulse
    symbol echoright = PORTC.6 ' Define input pin for Echo pulse
    symbol echofront = PORTC.5 ' Define input pin for Echo pulse
    symbol echoleft  = PORTC.7 ' Define input pin for Echo pulse
    SYMBOL channel3  = PORTC.4 ' Define input pin for Channel 3 PWM
    ' PORTC.0 'High is R/C.  Low is PIC control
    TRISC = %11110000
    DATA $C0,$0C 'his version's checksum goes here.
    define ADC_BITS 8
    TRISA.0 = 1 'PORTA.0 as analog input for POT
    ANSEL.0 = 1
    ADCON1 = %00000000  'left justified
    ' We use low eight bits.  0 -> 255.
    ADCON0 = %01000001  'divide 4Mhz clock by 8.
    OSCCON = %01100000 '4 Mhz
    LED1    VAR PORTD.4
    wsave VAR BYTE $70 SYSTEM
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    '5.0 mSec OR 200 Hz INTERRUPTS
    T1CON = %00000001         'Prescaler = 1:1, TMR1ON
    'PRELOAD 60543
    PreLoad     VAR WORD
    PreLoad =  60543
    TMR1L = PreLoad.LowByte
    TMR1H = PreLoad.HighByte
    '@ INT_ENABLE  TMR1_INT     ; enable Timer 1 interrupts
    WHEELS VAR WORD
    STEERING VAR WORD
    'The following may be a big part of the wall hugging probllem
    Potread var word
    Forward var word ' was fixed 122. Now sweeps 7 steps. See Checkpot
    HalfForward VAR WORD ' Potread/2 +x + 1. See Checkpot
    Back VAR WORD 'See Checkpot
    HalfBack VAR WORD 'See Checkpot
    Brake con 100 'Only used just before Main.
    Straight con 150 '?
    Right CON 130     '?
    HalfRight con 135 '?
    QuarterRight CON 140 '?
    Left con 170     '?
    HalfLeft con 165 '?
    QuarterLeft con 160 '?
    frontdanger var word
    stopreversing var word
    frontfree var word
    desiredtrack var word
    outertrack var word
    'some of the following are not used.
    CNT  VAR BYTE 'counts interrupts for TRIGGERS
    cnt = 0
    CNT2  var byte ' counts interrups for wheels and steering
    CNT2 = 0
    b0 VAR word
    rangeright var word
    rangeright = 100  'about 6 inches preset
    rangefront var word
    oldrangeright var word
    oldrangefront var word
    reversing VAR WORD
    reversing = 0
    switchtoPIC VAR WORD
    switchtoPIC = 1
    radiocontrol var word
    radiocontrol = 0
    steeringleft var word
    steeringleft = 0
    steeringright var word
    steeringright = 0
    Checkpot:
    ' I think Potread goes from 0 to 6.
    adcin PORTA.0, Potread
    Potread = Potread/37
    Forward = 160+Potread
    HalfForward = 155+(Potread/2)  'seems to work.
    Back = 140-Potread
    HalfBack = 145-(Potread/2)
    frontdanger = 210 + Potread*55 '210-540, 14-36 inches
    stopreversing = 180 + Potread*25 '180-330, 12-22 inches
    frontfree = 700 + Potread*60 '700-1060, 48-70 inches
    desiredtrack = 180 + Potread*20 '180-300, 12-20 inches
    outertrack = 360 + Potread*15 '360-450, 24-30 inches
    write 2, word Potread
    write 4, word frontdanger
    write 6, word stopreversing
    write 8, word frontfree
    write 10, WORD desiredtrack
    write 12, word outertrack
    low PORTC.0
    'hpwm 1,Straight,50
    STEERING = Straight
    'hpwm 2,Brake,50
    WHEELS = Brake
    'pause 4000 'Wait so I can put the car down and get out of the way.
    CheckIfInDanger:
    if rangefront < frontdanger then
    STEERING = Straight
    WHEELS = back
    reversing = 1
    goto reverseoutoftrouble
    ' loop till this is secured
    tryleftturn:
    if rangefront < frontfree then
    'something ahead - turn hard left.
    STEERING = left
    WHEELS = halfforward
      steeringleft = 1
     goto main 'loop till this is secured
    goingforward:
    STEERING = straight
    WHEELS = forward
    keepgoingforward: '----Compare to right wall
    if rangeright > outertrack then
      STEERING = quarterright
    if rangeright < desiredtrack and oldrangeright < rangeright then
      STEERING = STRAIGHT
    if rangeright > desiredtrack and oldrangeright > rangeright then
      STEERING = STRAIGHT
    if rangeright > desiredtrack and oldrangeright < rangeright then
      STEERING = QUARTERRIGHT
    if rangeright < desiredtrack and oldrangeright >= rangeright then
      STEERING = QUARTERLEFT
    reverseoutoftrouble:
    while rangefront < stopreversing
      STEERING = RIGHT
      WHEELS = RIGHT
    wend
    if rangeright > outertrack or rangeright < desiredtrack then
      STEERING = LEFT
      steeringleft = 1
      WHEELS = HALFFORWARD
    '***********INTERRUPT HANDLER************
    ToggleLED1:
    TMR1L = PreLoad.LowByte   ' Load the timer with preload value.
    TOGGLE LED1
    ' Trigger SONAR alternatively every 25 interrupts
    if CNT=25 then
     pulsr:
     oldrangeright = rangeright
    ' produce 10uS trigger pulse (must be minimum of 10uS)
     low trigright
     HIGH trigright
     high trigright
     high trigright
     LOW trigright
    'zero could be legal below
     pulsin echoright,1,rangeright 'measures the range in 10uS steps
    if CNT=50 then
     pulsf:
     oldrangefront = rangefront
     low trigfront
     hIGH trigfront
     high trigfront
     high trigfront
     LOW trigfront
     pulsin echofront,1,rangefront ' measures the range in 10uS steps
     CNT=0
     CNT=CNT+1
    if cnt2=4  then
    ' PWM pulses are between 1 and 2 millisec.
        low PORTC.1
        low PORTC.2
        pulsout PORTC.1,WHEELS
        PULSOUT PORTC.2,STEERING
        CNT2=0
    CNT2=CNT2+1
    @ INT_RETURN
    checkchannel3:
    'works with four AA batteries pack. Radio receiver puts pulses
    'on this line whenever the transmitter is turned ON.
     switchtoPIC = 2
     while switchtoPIC >= 2
        count channel3,65,switchtoPIC
        high portc.0
     wend
       low portc.0
    Aug 2010
    Maryland, USA
    that line turns the interupt on, or enables it. there must be a simular line like INT_DISABLE maybe to turn it off.
    turn it off when the while loop is true, or when under Tx control. then turn it back on when Tx control is over.
    -Bert
    Nov 2009
    Fitchburg, Mass
    Default That's what I tried.
    For some reason disabling interrupt during the WHILE loop did not work. I could have done
    something stupid.
    What I want to know is where is the list of "blocking" commands. I do not see such a list in
    my PBP book. For example, is COUNT a blocker?
    Here is what I coded immediately after main:
    checkchannel3:
    'worked with four AA batteries pack. Radio receiver puts pulses
    switchtoPIC = 2
    @ INT_DISABLE TMR1_INT
    high portc.0
    wend
    low portc.0
    Ken
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
