PBP projects for R/C models
Results 1 to 40 of 772
    Aug 2010
    Maryland, USA
    heres my 2 cents. I think I read somewhere in this thread you are driving the steering/drives with actual relays. First thing to do I think is trade them in for H-bridges. Then you will be able to get much higher switching speeds.
    next, see if you can get the steering to become semi proportional or at least slower by pulsing the control. I am guessing it is a solinoid and not a motor for the steering. These take time to move fully, so if you can release the signal before the wheels have turned all the way, it will become at least stepped. the springs will smooth out the signals to make it appear proportional.
    Now I am sure you can do the same with the drive. Once you have H-bridges in there, you can PWM it
    -Bert
    Nov 2009
    Fitchburg, Mass
    Default You are correct...
    cmcmachineguy,
    You are correct. My TOYs use DPDT relays (6msec contact. 4msec release - so they say) driven by SN7407's I have been trying to avoid more electronics. I had hoped to have middle school students build the cars using solderless protoboards and to keep the cost down.... I may need to teach-the-teachers first. They did not major in Science, Technology, Engineering or Math in Ed School. Hmmmm.... In Massachusetts that means hooking up with a local college to give a course which teachers take for "professional development points".
    I did find that the TOY steering servos are slow to return to zero. A 50milsec kick to the opposite end gets them started. If I could figure a way to control the kick steer, that would be ideal. It is so spectacular.
    I am having a difficult time PIC controlling the MODEL car at cruising speed. This is no where near how fast I can make the car go around the track using the R/C, my eyesight and my coordination.
    I took it to the gym today with proportional SONAR thresholds implemented. BIG IMPROVEMENT but still it occasionally hit the wall. Don't know why yet......
    Thanks again for the interest and support.
    Ken
    Aug 2010
    Maryland, USA
    Any way you can measure the current for the steering? Maybe it isn't real high and you can use 1 of the DIP H-bridge-on-a-chip. The stall current is what we are after here. Then you would still be able to easily proto board it. Leave the relay on the drive motors.
    I suspect if you can get the sterring under control, the drive will become less of a problem
    -Bert
    Nov 2009
    Fitchburg, Mass
    Default Radio Control cars are EVERYWHERE
    Today in the mail came two toy store Xmas catalogs. Both feature toy level R/C vehicles. All the more reason my autonomous car for introduction to STEM is a good idea. It may be that we need to teach-the-teachers first.
    On the subject of cost. In Fitchburg well over 50% of our public school students come from families that fall below the poverty line. In Massachusetts that means they are eligible for free or reduced price school lunches. If we were to use my cars to teach STEM to middle school kids, it would be nice if they could keep what they build. (Maybe in the context of an after-school program.) If we use my cars to guide teachers toward this corner of STEM through a college supported Professional Development course, again it would be nice if the students could keep what they build.
    Here's the question. What games can $50 1/10 scale TOY level cars play given the limitations of bang-bang controls and a 16F887 PIC. As a goal keep the total cost less than $100.
    Ken
    Nov 2009
    Fitchburg, Mass
    Smile Wall racers -er SONARs - are expensive.
    The point of my project is communicating "how things work" to pre-teens.
    Examples of today's difficulties: My Mom's natural gas powered oven was obvious. Ever try to explain a micro-wave? Souping up a car in my day included high lift cams, carborator changes, tuned straight through pipes. Today the first thing you do to hop up a car is change a computer.
    The dashboard on my 2004 GM car told me: "TIRE Pressure LR 23psi LOW". It also said, "TIRE Pressure RR 28psi OKAY". I pumped up my left rear tire. Then the car told me,"TIRE Pressure LR 23psi LOW" and "TIRE Pressure RR 33psi OKAY". WHAT??
    The garage mechanic told me each tire valve contains a pressure gauge and enough of a computer to maintain a connection to the car's internal wireless network. A previous owner of my car had rotated the tires. The mechanic also told me that my car, depending of accessories, carries some twenty computers.
    It seems to me that the first question in the mind of a future STEM professional is, "How does this thing work?"
    Ken
    Nov 2009
    Fitchburg, Mass
    Default success with the model level car.
    Today at the gym I got two speed levels to negotiate the wall racing. I have divided my POT's full motion into six steps, 0 - 5. 0 is slowest. 5 is fastest.
    Today speed 0 and 2 worked fine. Speed 5 crashed a bit. This evening I increased the proportionality multipliers relating POT position to distance thresholds.
    If I can get this car up to speed, imagine racing with more than one on the track.
    Ken
    Nov 2009
    Fitchburg, Mass
    Smile New video with some details
    I've added a new video to youtube.
    Check it out and please give me your advice. I think the car is not responding as fast as it can. I can list an abbreviated version on my code. I may have some fundamental incorrect.
    Ken
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
