I do not understand why I need to attach a USB cable to the PIC32 card when the UART tool in PICkit2 looks like it is supposed to do the same thing. Do I need to push some of the buttons (PROG, RESET, USER) to get this thing started?
I can get this far here, but I do not have one to program, so I can't go to the next step. Can you get to this point, and then your errors come when you try to program it?
I am not sure if the warning is something to worry about or not. But right now you are having so many other errors, let's now worry about my warning yet.
You might be able to use the PicKit2 as your command-line transport. StickOS does allow either usb or serial command-line transports. If that is working for you, then very well. But it sounds like it is not. I have hooked up to a PIC32 with serial on different hardware. But I have never tried it through a Pickit2. The USB is the preferred method, and might give us a clearer indication if we are on the right track.
What did you try to do just prior to getting all those error messages?
1. Did the Pickit ide automatically select the right pic32 device, or did you select it manally?
2. Then did you hit the write button to get all the errors?
I have a pic32 device, so I will try loading it with the latest firmware as well, and see what happens. I might have to try it tonight, as I am late for work already!
Walter
