PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Cool Video of model level and toy level cars
    I think the model level car is getting close to understandable. Not so the toy. This video shows one under control, not the other.
    One more step for the model level - get it more up to speed. This needs a bigger room. I've got that, but it needs cleaning. The toy level needs my understanding of the servo that drives the steering. Presently the car does not easily go straight hugging the wall. It just goes left or right. I will clean up and post my code.
    Ken
    It looks like your sensors are not detecting long distance and that is why it hits the walls.
    Can you make a test program and see with RS232 or LCD the distance it actually measures? And then use both sensors as it may interefere each other.
    Nov 2009
    Fitchburg, Mass
    Default No success at speed....
    I took the car to an old gymnasium this morning. I had adjusted the "frontfree" distance from four feet to five feet.
    That's the proximity response from the front sonars which triggers the code to turn sharply left.
    I left the potentiometer at the speed that was too fast for my garage. In the gym it negotiated the corners fine, but could not hug the wall.
    I may need to recalibrate the steering, but more likely I need to restructure the wall hugging code.
    Here's a link to the code I am presently running. The only difference between the toy car code and the model car code is the servo and DC motor driving commands. For the model code I use the HPWM PicBasic command. For the toy level I command certain pins to be HIGH or LOW.
    http://www.employees.org/~kjones/HPI2_left_SyRen02.htm
    Ken
    Nov 2009
    Fitchburg, Mass
    Smile STEM for middle school It works - now what??
    I made a video today of my model level robocar going about 1/2 speed inside an old deserted gymnasium. It largely works. I am now pretty much at the end of my road. YOUR IDEAS???
    1. The kit fits underneath the body skin. It is reasonably robust.
    2. The kit costs less than $80. The model car costs ~$200 assuming we do not have to purchase the HPI ESC-15 and we can swap in the SyRen ESC.
    3. PICBASIC code is not too difficult for middle school students.
    4. A potentiometer controls the speed. No need to go back to the USB port for that adjustment.
    5. Pulse Width Modulation is necessary ( and understandable).
    6. Each car needs PWM calibration of its steering.
    7. The characteristics of sound (sonar) must be understood.
    8. This is a good example of 'how things work' in the 21str Century
    http://video.yahoo.com/watch/8324343/22230090
    Ken
    Do not forget the cost of PBP.
    Nov 2009
    Fitchburg, Mass
    Smile That's a one of...
    Yes, the PBP is not freeware. But from the point of view of a middle school club or group project it is a 'one of'.
    I did not anticipate the complexity of upping the speed of this car and only asking it to follow the wall. This has been a good lesson for me.
    Ken
    You may want to read the back cover of your manual.
    Something like this came up before, no group license.
    That is why I get kids started with some basic ASM and/or what they can do with the demo version.
    Nov 2009
    Fitchburg, Mass
    Default Oops!!
    I just read the above mentioned Software License.
    I'd rather use LOGO. But that does not seem forthcoming. Hmmm...
    Ken
    Hmm, have a look at the videos at YouTube about line followers with and without PID control of the robot.
    Behaviour of non PID is similar to your nervous car. The same robot with PID control slides smooth on the line (or in your case follow the wall in a steady distance).
    Why not give it a try?
    Here is the same robot with and without.
    http://members.jcom.home.ne.jp/felm/ltc_p.mpg
    http://members.jcom.home.ne.jp/felm/ltc_pd.mpg
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
