PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Default Why the check sum....
    I've got three cars: one older HPI Sprint model level, one brand new HPI Sprint model level, and one toy level. The two model levels work with PWM signals. The toy car requires DC current switching. Each has its own idiosyncrasies. My version control system sucks. My memory sucks. Checksums to differentiate just came to mind.
    Ken
    Default Version control code rat
    Unfortunately, I can relate to that.
    However, I did remember reading a version control system here, and I found it too! I never used it, so my version control still sucks. But you might find it a possible solution.
    http://www.picbasic.co.uk/forum/showthread.php?t=2641
    It still won't tell you what is in the car though
    http://www.scalerobotics.com
    Nov 2009
    Fitchburg, Mass
    Default Another question
    I wish to email my PBP code. I want the BOLD commands to remain BOLD as they do in Microcode Studio. I have a PC running XP. When I select, copy and paste the BOLDness disappears.
    Any suggestions?
    Ken
    Use the Save As *.RTF option.
    Nov 2009
    Fitchburg, Mass
    Smile My next project
    In order to get someone or something interested in helping make my robocar available to school kids I need a better quality video. I have two HPI Racing Sprint cars.
    I have access to an outdoor street hockey rink. Same size and shape as ice hockey only asphalt covered for in line skates. I'm going to see if I can race my cars. Both on the track at the same time hugging the right wall going around turning left. One lap. The probability of the sonars getting their echos interchanged is remote I hope.
    They can go up to thirty mph. Real speed - not scaled speed. My PIC may not be able to react fast enough. I create PWM signals using HPWM. The robocar's reactions seem slower than my fingers on the trigger of the radio transmitter. This is going to be VERY interesting. You guys got any suggestions to add to the excitement?
    Ken
    Nov 2009
    Fitchburg, Mass
    Red face OKAY - I need help..
    My first robocar includes a PICKIT 2 proto board. It has a built in potentiometer. I would like to use that pot to control my code's PWM signal from PORTC.0.
    Presently I preset the constant FORWARD to a number between 115 and 123. That number is one of the arguments to my HPWM command for PORTC.0. If 123, the car goes very fast. If 115, the car creeps. I would like to make FORWARD a variable which is set within these limits on-the-fly as a result of the position of the pot.
    This will force me to use ASM code which is good. This also forces me to think which can be a problem. I am not good SEARCHing this forum. Any pointers would be most welcome.
    Ken
    Nov 2009
    Fitchburg, Mass
    Default This code d id not work.
    Ken
    Here's my first shot. I compiled fine, but did not work at all. Assuming I got the PORTs and
    registers correct, am I on the correct path? I am trying to break the 256 possible values of
    the Pot reading down to seven that make sense to the Electronic Speed control.
    pot PORTA.0,127,Potread
    if Potread < 36 then
    Forward = 112
    if Potread => 36 and Potread < 73 then
    Forward = 113
    if Potread => 73 and Potread < 109 then
    Forward = 114
    if Potread =>109 and Potread < 146 then
    Forward = 115
    if Potread => 146 and Potread < 182 then
    Forward = 116
    if Potread => 182 and Potread < 219 then
    Forward = 117
    if Potread => 219 then
    Forward = 118
    write 2,word Forward
    write 4,word Potread
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
