PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Default Prototyping with the PICkit 2
    I have some Radio Shack solderless prototyping boards. With 22 guage solid wire I can create a fairly robust kit. I need to connect ten signal wires from the PICkit 2 to the solderless board. The Digi-Key S5752-12-ND header might work. The question is whether 22 gauge solid wire will fit and stay in this device. If not #22, then what gauge will work? Or is there a crimp-on male connector that will do the job.
    What did the Microchip engineers have in mind when they designed the PICkit 2 printed circuit board? Any ideas?
    Ken
    22 gauge will be snug and if you do your breadboarding like Darrel does it all should stay put.
    http://www.picbasic.co.uk/forum/atta...2&d=1278267329
    Default Seems to do what it is desinged for, and very well, I think.
    A compact USB device that programs all their MCU's, using 5 to 6 connections?
    But what do you mean Ken?
    On a tangent, here is what they were thinking for the pickit3:
    I think Ken was getting at the 44 pin dev board. It is kind of useless... Mine got the most use helping Ken get started. It is back to collecting dust.
    Nov 2009
    Fitchburg, Mass
    Default Back to the six wire steering mechanism
    This describes what I found when I took the "servo" apart. (I got it back together with much struggling so this is from memory.)
    It has 2 wires that go to the motor and 4 wires that go to some kind of rotating position sensor. On a small board are 2 etched concentric circles which are in contact with a 4-pronged device mated to the spinning gear. I think 2 of
    the 4 prongs touch the outer circle, the other two the inner circle.
    Have any of you come across such a device? Any idea its purpose and how I control it. Other cheap cars just go bang bang into the steering motor with a little spring plus the caster effect to bring it back to neutral.
    Ken
    Now I remember seeing one of those.
    It is a reversing/limit switch. The cheaper cars are either turn or no turn. Not much in between.
    If I remember correctly...
    Nov 2009
    Fitchburg, Mass
    Default We have hear a problem in communication
    My 16F887 is attached to a Microchip PC board. It is the PICkit #2. My problem is getting ten signal wires off that board an onto a solderless proto board like Darrel used. Are you all suggesting that I do the whole job on a solderless board? If I were to do that, where do I get the solderless header that fits my Microchip provided USB connector? I'm pretty sure my 44 pin square shaped PIC will not fit. I need the long rectangle shape.
    Ken
    I use these with bread boards and the PicKit2
    http://www.allelectronics.com/make-a...-ANGLE//1.html
    The long rectangular chips are what they call a PDIP package. Much easier to solder when you get to that point.
    I would develop the project on a bread board with PDIPs and that might be the way to go with the kit also. It would low the students to experiment...
    Nov 2009
    Fitchburg, Mass
    Default Is it so easy??
    Looks like all I need to connect to a PDIP 16F887 on a solderless board are the six wires from the USB device and two .1uf caps between Vcc and Gnd. The rest of the Microchip PICkit 2 schematic I do not use. (Some LED's would be nice.) Don't forget two isolated batteries. One for the DC motors the other for the logic.
    This is little considering the six Zettler relays, the SN7407, and a 5v regulator. Hmmmm
    Does this seem correct to you?
    Ken
    Glad to hear it. The bad news is that HPWM doesn't go down as low as 50 hertz, unless you use a really low osc speed. You have to go down to 0.5 mhz to get there. And, unfortunately you have to tell pbp that it is running at 4mhz. This will make a pause 2000 16 seconds. It can be compensated for, but a bit of a pain. And it limits you to 32 steps of speed. I think I talked about this back on post 199. Maybe that's why you tried to go back to PWM. But as you saw, PWM is effected by blocking commands, like pause.
    http://www.picbasic.co.uk/forum/show...5908#post85908
    I don't have a 16F887, but I just ordered a sample, so I can help test some options for you.
    Walter
    http://www.scalerobotics.com
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
