PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Question Could use some suggestions
    I think the code is pretty solid. Now the problem is response time, size of maze passageways and RC car speed. A fraction of a second does not seem very long when the car is up on blocks, but it is enough time at speed to crash into a far wall when it should have detected a turning opportunity and done its thing.
    I think I need:
    1. Techniques using PICBASIC Pro for recording data in memory that can be read back into my PC for analysis. How do I do this? I have not the faintest idea what app to use.
    This is a tough one.
    If the trouble is speed and timing then using more MCU cycles might make it worse.
    You can look at writing data to the on-board EEPROM.
    http://melabs.com/resources/samples/pbp/eeword.htm
    I think I need:
    This thread might help:
    http://www.picbasic.co.uk/forum/arch...p/t-13317.html
    Anand
    Nov 2009
    Fitchburg, Mass
    Default I think the PIC is plenty fast enough
    Thanks for your attention and replies.
    I think the PIC is plenty fast enough. I think the SFR05's are responding quickly enough judging from their flashing LED's. My guesses are either SFR inconsistencies and/or weakness in my jury rigged PWM signal.
    The servo and the speed control want PWM pulses at 50 per second. I have not been able to do that with my PIC. I get the pulse width correct, but I can not get the rep rate down to once each 20 millisec.
    Ken
    Nov 2009
    Fitchburg, Mass
    Talking I think I've got it...
    The PIC KIT2 programmer has, at the bottom, reference to EEPROM. It has addresses 00 - FF.
    I think that if I use the PBP WRITE command at run time I can store data in the inchip EEPROM space. 00 to FF in size. I can then manually read this out with PIC KIT2 programmer.
    Sound correct??
    Ken
    Sound correct??
    Yup, that will work.
    Nov 2009
    Fitchburg, Mass
    Default A prototyping problem
    I need to be able to connect my PICkit 2 to three SRF05 sonar sensors. The easiest way would be to solder J or JR (or whatever - I do not know one connector from another) headers to the board.
    I looked carefully at the connectors that came with my radio control car. The pin separation does not match the hole separations in my PICkit 2 forty four pin demo board. Do any of you know the name of the connector header - if it exists - that would solder directly into that row of holes along the sides of my proto card? They are definitely not 1/10 inch centers. I have no means to measure their separation accurately.
    Ken
    Default Servo pwm passthrough using PCPWM
    The 18F2431 makes it slightly easier to perform servo PWM because it's PCPWM module can go down to 19 htz while maintaining fast OSC rates, unlike other PIC chips HPWM. Here is an example of using the PCPWM to output 3 servo signals. This specific example senses the pulses (up to 5 channels) by using the CCP1 capture pin. To get 5 channels into one pin for PW capture, channels 1, 3 and 5 are input using small signal diodes. Then, since this drops the signal down to under 3 volts, I used two 2n3904 transistors. One to boost up the voltage, and the other one to invert the signal back to normal. (It was all I had lying around). Somehow, you will need to boost your signal after the diodes for the CCP1 capture to sense the incoming pulses.
    Note: Because the PCPWM was used, this will not work on any chip outside of the 18F2431 family.
    ;This only works on a 18F2431 family device with Power Control PWM (PCPWM)
    ;By Scale Robotics Inc.
    ; The input signal should look something like this:-
    ;        |<------------------ 1 frame (~20mS) -------------->|
    ;        |<1~2mS>
    ;         ______        ______        ______                  ______
    ; _______|      |______|      |______|      |________________|      |____
    ;   gap    ch1    ch2    ch3    ch4    ch5      sync  gap      ch1    etc
    define OSC 40
    asm
        __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
        __CONFIG    _CONFIG2H, _WDTEN_OFF_2H & _WDPS_512_2H
        __CONFIG    _CONFIG4L, _LVP_OFF_4L
    endasm
    clear
    ADCON0 = %00000000
    ADCON1 = %00000000
    portb=0
    trisb = %11000000
    trisc = %00000110
    trisa = %00000000
    DTCON = %00000101   'dead time for complimentary ouputs
    PTCON0 = %00001101  '1:1 postscale, Fosc/4 1:64 prescale, Sincle Shot mode
    PTPERL = 255        '
    PTPERH = 251
    PWMCON0 =%01010000  'PWM[5:0] ouputs enabled
    PWMCON1 = 1         'updates enabled, overrides sync w/timebase
    PTCON1 = %10000000  'PWM timebase is on, counts up
    FLTCONFIG = %00000010 'disable fault A, cycle by cycle mode
    CCP1CON = %00000101    'Capture mode; every rising edge
    duty1 var word        'width of outgoing pulse1
    duty2 var word  'duty values 625 to 1250 = 1 to 2 ms pulse (Center at 625)
    duty3 var word
    risetime1 var word    'Rise Time for incoming pulse1
    risetime2 var word
    risetime3 var word
    falltime1 var word     'falltime for incoming pulse1
    falltime2 var word
    falltime3 var word
    pulsewidth1 var word    'pulse width for incoming pulse1
    pulsewidth2 var word
    pulsewidth3 var word
    pulsewidth4 var word
    pulsewidth5 var word
    pulseNumber var byte
    pulseNumber = 1         'tells which pulse we are reading
    CCP1CON.0  = 1
    timerone var word
    timerone = 60315 ;
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
            INT_Handler   TMR5_INT,   _PulseOut,   ASM,  yes
            INT_Handler   CCP1_INT,   _PulseMeasure,   ASM,  yes
            INT_Handler   TMR0_INT,   _TimeOut, ASM, yes
    T1CON = %00110001            ;Timer1 used by CCP1 capture
    T5CON = $01                  ;used as pulseout timer
    T0CON = %11000111              ; Prescaler = 8, TMR1ON
    @   INT_ENABLE  TMR5_INT     ; Enable Timer 1 Interrupts
    @   INT_ENABLE  CCP1_INT      ; Enable Capture Compare for pulse width measurement
    @   INT_ENABLE  TMR0_INT    ; deadtime (sync gap) indicator for lull between pulses
            pause 10
            'do something to these values if you want to filter, center, etc
            'Below we are just passing values through
            duty1 = pulsewidth1 >>1  'send channel 1 out PCPWM on PortB.1
            duty2 = pulsewidth3 >>1  'send channel 3 out PCPWM on PortB.3
            duty3 = pulsewidth5 >>1  'send channel 5 out PCPWM on PortB.4
    GOTO Main
    '---[TMR5_INT - interrupt handler]------------------------------------------
    PulseOut: 'set up pulse width values for pulseout and reset single shot bit
        TMR5L = timerone.byte0
        TMR5H = timerone.byte1
        PDC0L = duty1.lowbyte
        PDC0H = duty1.highbyte
        PDC1L = duty2.lowbyte
        PDC1H = duty2.highbyte
        PDC2L = duty3.lowbyte
        PDC2H = duty3.highbyte
        PTCON1.7=1  'resets single shot PTEN bit
    @    INT_RETURN
    '---[CCP1_INT - interrupt handler]------------------------------------------
    PulseMeasure:
    if CCP1CON.0  = 1 then ; Check CCP1M0 for rising edge watch
        select case pulseNumber
            case 1
                TMR0L = 0    'reset timeout timer0
                TMR0H = 0
                risetime1.lowbyte = CCPR1L
                risetime1.highbyte = CCPR1H
            case 2
                TMR0H = 0
                risetime2.lowbyte = CCPR1L
                risetime2.highbyte = CCPR1H
            case 3
                TMR0H = 0
                risetime3.lowbyte = CCPR1L
                risetime3.highbyte = CCPR1H
        End select
        @ BCF     CCP1CON, CCP1M0 ; Now capture the trailing edge
    Else     'check for falling edge time
        @ BSF     CCP1CON, CCP1M0 ; Re-set for trailing edge capture
        select case pulsenumber
            case 1
                falltime1.lowbyte = CCPR1L
                falltime1.highbyte = CCPR1H
                pulsewidth1 = falltime1 - risetime1
            case 2
                falltime2.lowbyte = CCPR1L
                falltime2.highbyte = CCPR1H
                pulsewidth2 = risetime2 - falltime1
                pulsewidth3 = falltime2 - risetime2
            case 3
                falltime3.lowbyte = CCPR1L
                falltime3.highbyte = CCPR1H
                pulsewidth4 = risetime3 - falltime2
                pulsewidth5 = falltime3 - risetime3
        end select
        pulsenumber = pulsenumber + 1 'get ready for next channel
    @    INT_RETURN
    '---[TMR0_INT - interrupt handler]------------------------------------------
    TimeOut:
        pulsenumber = 1 'if pause between pulse in exceeds about 7 ms, get ready
        'to receive pulse 1 (senses dead time between pulse bursts)
    @   INT_RETURN
    To see a similar project, but using SPWM, look here: http://www.picbasic.co.uk/forum/showthread.php?t=12657
    Nov 2009
    Fitchburg, Mass
    Default Thank you, Dave
    Yes, the 18F2431 looks like a winner for my PWM construction. It is included in my PICkit2 programmer.
    It comes in a 40 pin package. It would easily replace my 40 pin 16F887 on the solderless protoboard. To use it effectively I need to master ASM coding. I have not succeeded in cracking that nut.
    Here is my latest stumbling block. I have an arrangement with some folks who are willing to contribute brand new HPI Racing Sprint cars to my project. I received my first new car last week. HPI has drastically changed the Electronic Speed Control. This is the package that translates incoming PWM signals (from the radio receiver or from my PIC) into outgoing DC current for the motor that drives the wheels. I am not doing well with the HPI WEB site getting technical information about this SC-15 WITH REVERSE SPORT CONTROL.
    Ken
    Hey Ken,
    Congratulations on getting the donation! It is a great idea you have, and I am glad you have stuck with it. As for your newest stumbling block, what code are you currently using? You might be running into the same problem of not having a standard R/C output pulse going to the controller. And MIBAM will not work, because it is meant for lighting, and will confuse your speed controller even more.
    All analog servos (not the newer digital ones) use a standard protocol. A pulse width from about 0.9mS to 2.1mS or so, pulsed every 20 mS. Since this controller does not say digital on it, I would bet that it is analog, and works the same as all the servos in my house. Since it has reverse, as well as forward, I would bet that somewhere in between .9mS and 1.1 mS is neutral. Less is probably reverse, and more is forward.
    I don't think you need a manual for it. Just start feeding it some PWM that matches that protocol, and you will be good.
    Assembly is a tough nut to crack. It's just one of those things, the more you use it, the more you learn. But one of the things I learned this week from the forum, was that I could have an instant ASM interrupt without using any ASM. No, I didn't know that when I wrote some similar code for the 12f683. So in my example above, I only used two lines of assembly code. a BSF and a BCF. (Bit set and bit clear). So you can have almost no nuts with this code, or you can change them to PBP code if they drive you ... um ..... nuts.
    I think you already know this, but I just found the gif file, and I like it, so I'll post it here. - Walter
    Default Cool chip for R/C PWM: 18F2431 series
    After reading about some of Bruce's cool projects with the 18F2431 series chips, I have been playing around with them for a little while. One thing that caught my eye is that they can do Power Control PWM as low as 19 hertz (while running at 40 mhz). Something you have to bring other chips OSC down to 0.5 mhz to do. This, and a few more of it's features, make it pretty nifty for creating PWM servo output. I mocked up a quick test, and have been able to do about 10bit PWM 1 to 2ms pulses at the proper 50 hertz spacing on 3 pins with the 18F2431. The larger chips of this series can do 4 pin PCPWM. I will post a little code once I get it cleaned up a bit.
    Nov 2009
    Fitchburg, Mass
    Question The new Electronic Speed Control is messing with my head
    I received a brand new HPI Racing Sprint car. This is the same model which I have been using. It is just the most recent version.
    I am having a problem with the new Electronic Speed Control a SC-15. It has some kind of mind of its own. My old code which told my old car where to go is not working with this new ESC.
    Do any of you have the contacts to get me the specs on this "SC-15 ESC WITH REVERSE SPORT CONTROL".
    Does is have a PIC? Is it programmable? What are its design algorithms?
    Ken
    Since it doesn't have to be exact, you could simplify your code.
    Instead of:
    Checkpot:
    adcin PORTA.0, Potread
    write 4, word Potread
    select case Potread
    case Potread < 36
    Forward = 112
    case Potread => 36 and Potread < 73
    Forward = 113
    case Potread => 73 and Potread < 109
    Forward = 114
    case Potread =>109 and Potread < 146
    Forward = 115
    case Potread => 146 and Potread < 182
    Forward = 116
    case Potread => 182 and Potread < 219
    Forward = 117
    case Potread => 219
    Forward = 118
    end select
    write 2, word Forward
    something like:
    8 bit ADC:
    Checkpot:
    Potread = Potread/37
    Forward = Potread+112
    10 bit ADC:
    Checkpot:
    Forward = Potread/147 + 112
    http://www.scalerobotics.com
    Nov 2009
    Fitchburg, Mass
    Smile Beautiful!!
    I chose your first suggestion:
    It works beautifully. Tomorrow I shall make a video of my car on blocks in its "going forward" state with me making it go faster and slower by twisting the pot's knob. At least I intend to do that tomorrow.
    THANK YOU!!!
    Nov 2009
    Fitchburg, Mass
    Smile Did not work at all as planned....
    Sorry for the delay. I have been discouraged. The new HPI Sprint R/C car has an ESC-15 that thinks for itself. The HPI manufacturing/sales organization refuses to give me the behavioral specs. This is a STEM educational project. Not a by guess and by golly exercise in inductive reasoning.
    One solution is to make an ESC on my solderless proto board. (Complete with cooling fins?)
    My PIC (like the R/C receiver) makes appropriate PWM digital signals. The car wheels want appropriate PWM bi-directional current pulses. Have any of you seen a design I could copy?
    Ken
    Nov 2009
    Fitchburg, Mass
    Default How about no speed control
    My PIC already produces quality PWM signal streams. Why can't I put this signal directly to a MOSFET circuit thereby producing a current switched wheel motor driving signal. My pic could use two HPWM's for the wheels. One for forward, the other for backward. It could steer the correct MOSFET signal with a third 'direction' output. Only trouble is I do not know how to detail design what I just typed.
    Ken
    Here is some more info about StickOS with some youtube videos by the guy the wrote it. Pretty cool stuff.
    http://www.picbasic.co.uk/forum/show...9397#post89397
    Default Just for fun....
    Just for fun, here is a quad copter that does some pretty amazing stunts. I am fond of the one with velcro. I guess it helps if you have your speakers on. It doesn't sounds quite autonomous. The 20 cameras are static in the room.
    Sorry Ken, I just thought it was really cool. These students are older. (And they appear to have a much bigger budget!)
    And through moving hoops
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
