PBP projects for R/C models
Results 1 to 40 of 772
    California, USA
    Somehow I have to speed up my processing loop.
    Any suggestions?
    What oscillator speed are you running?
    8MHz on internal osc?
    I believe the 16F887 will run up to 20MHz with external crystal.
    That would speed things up a bunch.
    steve
    Another thing you could do, is ICD compile it in micro code studio (for something like a PIC16f876a) and run it to see where it is getting stuck. Of course, you would need a serial port, and a PIC16f876a laying around to test it that way.
    It would show you step by step, or animated, something like this:
    Walter
    Nov 2009
    Fitchburg, Mass
    Smile OKAY, I got one problem solved...
    You all suspected my usage of PULSIN.
    You were correct.
    To determine whether to take control itself or let the radio receiver do its thing, my PIC must read the PWM code from the radio receiver channel 3. That PWM comes in only fifty times per second.
    I was asking PULSIN to measure that pulse without setting an interrupt for when it sees a rising edge. What are the chances of my PULSIN moment (plus delay waiting according to pulsin_max) seeing something happening only 50 times per second. Answer, not good.
    What are the chances of my PIC seeing that pulse when the radio transmitter is not powered? None whatsoever!
    So: When testing my car up on blocks in my "lab" and not remembering to turn on my radio transmitter the poor thing spends 99% its time waiting for a pulse that never arrives.
    Yep. Turn on the transmitter (even with channel 3 in the autonomous control position) and my SRF05 blinkers flash like crazy. They are being continuously triggered.
    I still have a problem with response time, but it is not because the PIC is lacking sensor information.
    Ken
    Nov 2009
    Fitchburg, Mass
    Default Here's the code that's in the video
    I don't think I have changed anything other than remove confusing comments.
    Ken
    Nov 2009
    Fitchburg, Mass
    Default One more problem solved
    Part of the reason my car keeps hitting the wall is that it is responding too slowly for the speed it is traveling.
    Today I carefully calibrated my HPWM 2,xxx,50 commands.
    If xxx = 110 the car does not move.
    If xxx = 111 the car moves forward, but only on a non-carpeted floor.
    If xxx = 112 the car moves forward forcefully but not too fast
    xxx = 115 is too fast for my code.
    xxx = 125 is full speed which is very fast.
    Ken
    Nov 2009
    Fitchburg, Mass
    Smile The car is working much better...
    Here's a video of our car running a hall in our house.
    http://video.yahoo.com/watch/7164676/18657928
    I moved the front sonic sensors closer to the front of the car and I figured out how to slow down the wheels a bit.
    Next thing, I think, is to build a better looking and stronger prototype using a car with more room to attach stuff. What other kinds of sensors should I try and what other kinds of tasks will they help the PIC do?
    Again, thank you for all your interest and help.
    Ken
    Looking good Ken!
    Other sensors...
    IR - Probably not do much better than the sonic, but they can be setup to "see" light and dark colors. Line follower. Maybe see the white wall...
    Hall-effect - Have the car find and park or something on a metal plate, magnetic.
    Solar cell or photo diode - Light seeking. You mentioned this at the beginning.
    RFID - Place RFID tags along a path and have the car follow. (never done that myself)
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
