PBP projects for R/C models
Results 1 to 40 of 772
    Default HDD spindle motor controller
    Hi all
    Thought this might be of some interest, the code is in C and there is no schematic , was just thing of 4 well synchronized hard drive spindle motors a an RC chasis , would be quite a fast car.
    Seems like a nice project though!
    http://bradthx.blogspot.com/2010/02/...le-motors.html
    Kind regards
    Dennis
    Ken,
    Just to be sure we are all doing the same thing...
    1-- Write and compile the code using MCS.
    2-- Generating the ASM file with MCS set for MPASAM use.
    3-- Open a project in MPLAB.
    4-- Use the ASM file generated by MCS as the source for the MPLAB project.
    5-- Everything is in the same project directory.
    Nov 2009
    Fitchburg, Mass
    Default Maybe we are not doing the same thing...
    Compile PIC BASIC PRO code using
    MicroCode Studio version 3.0.0.5
    PICBASICPRO 2.6.0
    Using MPASM per the following picture:
    Open the project in MPLAB IDE 8.43.00.00
    MPDebugger 3.10
    Looks like the only difference is you are using the latest software, I am still using PBP2.50 and MPLAB v8.00.
    So I am at a loss now.
    Nov 2009
    Fitchburg, Mass
    Default Waiting for the parts.
    Progress has been slow. It will be more fun when the SN7407's show up and I can make the car move.
    Ken
    Nov 2009
    Fitchburg, Mass
    Default The SN7407's have not arrived - yet
    It's been more than a week. They were supposed to have been shipped via USPS. The vendor is not answering its email. Does not look good.
    Meanwhile I might as well get back to the REAL project. I have not decided on the least intrusive means to generate PWM. Using the toy level car all I have is bang/bang control. Full speed forward, full speed backward, stopped. Full turn left, Full turn right, straight ahead.
    With PWM control I have CONTROL. Thing is, I do not know whether I really need this complication. Probably not. But I do need for the microprocessor to be doing things while the car is moving. PAUSE does not cut it.
    Gotta put back on my thinking cap.
    Ken
    Hey Ken,
    Don't know if you saw it, but some progress was made on the 12F683. It is decoding 5 channels, and encoding 4 channels. You could modify the servo output as you like in the main section, using PBP. The DT interrupts are done in assembly. (No pauses) All you would need is a $2.00 12f683, a capacitor, 3 diodes, and a breadboard.
    http://www.picbasic.co.uk/forum/showthread.php?t=12657
    Nov 2009
    Fitchburg, Mass
    Smile I think it will be easy
    The wall racer code contains subroutines that do all the bang/bang controls by switching DC current through relay DPDT switches
    The 16F887 has CCP1 and CCP2 each of which can be controlled by the HPWM Pic Basic Command. I could replace the six subroutines above with six that use HPWM. They would use these two outputs with three pulse widths each.
    If I were to add a parameter to each GOSUB command thereby giving more nuance to the pulse width I could command in between wheel speed and steering angle.
    Sounds like a piece of cake. What do you think?
    Ken
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
