PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Default I agree about the driver
    Does MICROCHIP make an auxiliary board that contains drivers for the PICkit 2 device? I am not capable of soldering onto that PICkit printed circuit board. I already have a good sized non-solder proto board carrying the four DPDT switches, two proximity sensors and a voltage regulator. I am trying to get this whole thing onto a 1/10 scale radio control car.
    The guy from whom this idea came used a PICAXE.
    Ken
    Nov 2009
    Fitchburg, Mass
    Question MOSFET suggestion please....
    There are more logic level MOSFET's than Carter has Liver Pills (an expression that easily shows my age).
    What I want to do must be very standard.
    Suggestions?
    Ken
    http://www.fairchildsemi.com/ds/FD%2FFDD8424H.pdf
    I find these handy. Mouser has them.
    California, USA
    Just to confuse the issue a tad more, one of the other options would be to use a buffer/driver IC like this:
    http://focus.ti.com/lit/ds/symlink/sn7407.pdf
    Digikey has 'em for under $2, and it gives you up to 6 outputs if you like. MAX current is 40mA.
    I did a quick search for nice little MOSFETS in a small through-hole style package (like to-92) and I've gotta say it's pretty depressing. 98% of the stuff out there these days is SMD.
    Dave, those little dual MOSFETS are cute. But I'll bet Ken would like something in through-hole...
    steve
    Nov 2009
    Fitchburg, Mass
    Smile SN7407 sounded familiar so....
    I grabbed my "TTL Integrated Circuits Catalog From Texas Instruments" dated 1 August 1969 and found specs on the SN7400, SN7401, SN7402, SN7403, SN7404, SN7405, and SN7410!!
    This SN7407 thingie must be one of those newfangled inventions. No wonder I did not recognize it
    Thank you all!!
    California, USA
    Cool
    Heh, you've got me beat for "vintage databooks".
    I've got some National Semiconductor "TTL" and " Analog" data books that go back to '74, and a Signetics data book from '76, but nothing that goes back to the 60's...
    Hey, It's 2010 and that means the NE/SE555 is celebrating it's 40th birthday!
    Am I the only one that finds that amazing? 40 years in production for an IC type..
    According to Wikipedia:
    "As of 2003, it is estimated that 1 billion units are manufactured every year." Wow!
    Sometimes technology doesn't change that much, it just gets... smaller.
    Oooh look, now available in a TSSOP8 package.
    http://www.st.com/stonline/products/...4077/ts555.pdf
    You're doing great Ken, and I'm looking forward to seeing photos of your car in action because I know you're going to get there. You're clearly a geek at heart with experiance behind you ...
    You just need some fresher data books to work from.
    You're doing great. Carry on.
    steve
    Quote Originally Posted by Byte_Butcher View Post
    Sends you on a nostalgic trip, doesnt it?
    My dad used to work in the avionics department of our national carrier, and I remember he showed it to me as an example of cutting edge technology.
    Of course, I could only appreciate the significance after he showed me the equivalent transistorised module it replaced.
    "What will they think of next..."
    Anand
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
