PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Smile Bruce, SUCCESS
    Not only does your code work (with a couple of adjustments specific to my PICkit 2 setup) but it also makes my car go not-so-fast, faster, and fastest.
    It also successfully drives the steering servo left, center and right. This validates the rumors that I was getting from the RC people about the shape and timing of their PWM signals.
    GREAT!! Now on to bigger and better stuff like light sensing and proximity sensing. First I need to write some car control routines
    FORWARD speed,duration
    BACKWARD speed, duration
    STEER_RIGHT ?
    STEER_LEFT ?
    Ken
    Nov 2009
    Fitchburg, Mass
    Question Maybe not so fast...
    Am I correct in thinking that PAUSEUS stops the PIC.
    To run my car the PIC must control steering and wheel rotating. It also monitors whether channel 3 from the RC receiver is calling for a return to RC control.
    Meanwhile the car must be able to sense and react to light, ultra sound proximity, and other timers. It has to find its way to a destination.
    The PWM pulses are generated at 50 per second. That is 20ms between clock matching interrupts. The longest PAUSEUS is 1.75ms which is 8.75% of total time. Steering concurrent with wheel rotation could consume 17.5% of compute time.
    Is this a problem? I just don't know enough about real time PIC coding to know the answer. What do you all think?
    Ken
    PAUSE puts the code into a loop for a certain amount of instructions. It does not stop the hardware interrupts.
    This is what a PAUSE in ASM looks like. Just a routine to eat some time.
    ; Delay = 0.1 seconds
    ; Clock frequency = 4 MHz
    ; Actual delay = 0.1 seconds = 100000 cycles
    ; Error = 0 %
    Delay	;99993 cycles
    	movlw	0x1E
    	movwf	d1
    	movlw	0x4F
    	movwf	d2
    Delay_0
    	decfsz	d1, f
    	goto	$+2
    	decfsz	d2, f
    	goto	Delay_0	;3 cycles
    	goto	$+1
    	nop		;4 cycles (including call)
    If you have hardware interrupts enabled, it will jump out of any code routine, execute whatever code you have in your interrupt handler, then return to where it was prior to the interrupt.
    Note I wasn't recommending you use this routine to control your motors, I was just curious if it worked. Once you know what you'll need to do to handle all the other things you need to like light sensing, ultrasonic, etc, then you'll have some idea of how to incorporate all your routines (or most) into a single interrupt handler.
    Your particular type of application could also benefit from a few dedicated application specific ICs like maybe some 8-pin PICs programmed to do nothing but generate your motor control signals by just monitoring a few inputs, and using these inputs to determine speed, direction, etc. Then you main controller could control motors by just taking a pin or 2 high or low.
    A lot of robotics applications use distributed processing like this to take some of the repetitive tasks off of the primary controller.
    Example: Instead of using a sonar sensor, you could build this into your main controller. But then your main controller wastes a ton of time doing what the external sonar sensor does.
    So - most people will just buy & use a sonar sensor rather than design it into the main circuit. Just take that a step further, and make your own 8-pin servo controllers.
    If you have a lot of things going on, motors, sensors, measurements, etc, etc, you can take a huge burden off the main controller by just creating a few of your own litle application specific PICs with a few I/O-pins on the primary controller telling them what to do.
    You could have a whole herd of little 8-pin PICs interfaced & controlled by the primary controller, and it only takes a few pins on the primary to control them, and just a few instruction cycles to make that happen.
    Or you could shove it all into just one with some crafty interrupt handler to sort it all out. Just an idea. Sounds like a fun project.
    Microchip has a new 8-pin PICs coming shortly with a hardware USART & other goodies that could make some really interesting little peripheral controllers.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Wink
    Hi, Bruce ...
    Could you give some little details ... please ??? a number ???
    I have been DREAMING of it for so long !!!
    PS: 1822 ???
    Hi Alain,
    Yes. It's the 8-pin PIC12F1822.
     Enhanced Mid-range Core with 49 Instruction, 16 Stack Levels
     Flash Program Memory with self read/write capability
     Internal 32MHz oscillator
     Integrated Capacitive mTouch Sensing Module
     Data Signal Modulator Module
     MI2C, SPI, EUSART w/auto baud
     ECCP (Enhanced/Capture Compare PWM) Module
     Comparator with selectable Voltage Reference
     4 Channel 10b ADC with Voltage Reference
     25mA Source/Sink current I/O
     Two 8-bit Timers (TMR0/TMR2)
     One 16-bit Timer (TMR1)
     Extended Watchdog Timer (EWDT)
     Enhanced Power-On/Off-Reset
     Brown-Out Reset (BOR)
     In Circuit Serial Programming (ICSP)
     On Board In-Circuit Debug
     Wide Operating Voltage (1.8V – 5.5V)
     Low Power PIC12LF182x variants (1.8V – 3.6V)
     Standby Current (PIC12LF182X):  30 nA @ 1.8V, typical
    -Bruce
    tech at rentron.com
    Nov 2009
    Fitchburg, Mass
    Red face Feeling a bit overwhelmed
    Guys and Gals,
    I might take a side trip to a scenic view along this road.
    Here is a pointer to a BASIC (which BASIC I do not know) program that controls a toy level RC car. Toy levels have no Electronic Speed Control. The DC motor and servo are driven by direct current controlled by four DPDT switches. (Bang-Bang: full speed forward, full stop, full speed back.) This project has only autonomous control. The radio receiver has been eliminated. These simplifications plus the fact that the details are on the WEB make this diversion very tempting.
    http://letsmakerobots.com/files/wall_racers.bas
    and
    http://letsmakerobots.com/node/928
    I have an appropriate RC car.
    I have a spare PICkit2.
    I need to translate wall_racers.bas into PBP.
    I need to adapt the resulting ASM to my 16F887.
    I think I have enough proto. parts for both projects.
    My ego needs a boost.
    Ken:
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
