You could simplify this a great deal if your PIC has Timer1 available, and Compare,
Capture, PWM .. by just using the Compare peripheral.
Here's an example:
    Match VAR WORD
    Match   = 20000         ' 20,000 * 1uS = 20mS until compare match
    CCPR1H  = Match.HighByte' Load compare register high
    CCPR1L  = Match.LowByte ' Load compare register low
    CCP1CON = %00001011     ' Compare mode, auto reset Timer1
    '/ TRIS & Port Setup
    PORTB.0=1
    TRISB = $FE  ' PORTB.0 output, rest inputs
    '/ disable interrupts
    INTCON.7 = 0 ' Disable global ints
    INTCON.6 = 0 ' Disable peripheral ints
    PIE1.0   = 0 ' Disable Timer1 int
    PIE1.2   = 0 ' Disable CCP1 int
    T1CON = %00000000 ' Timer1 off, internal clock, 1:1 prescale
    TMR1H = 0         ' Clear Timer1 high
    TMR1L = 0         ' Clear Timer1 low
    T1CON.0 = 1  ' Turn on Timer1
LOOPS: ' NOTE: PIR1.2 is the CCP1IF compare interrupt flag bit.
       ' this bit is set when Timer1 reaches the value in
       ' CCPR1L & CCPR1H
    IF PIR1.2 = 1 THEN   ' If CCP1 to TMR1 compare match occured
       PORTB = PORTB ^ 1 ' Toggle PORTB.0
       PIR1.2 = 0        ' Clear compare interrupt flag bit
    GOTO LOOPS
Just 1 single interrupt could take care of your 20mS timing VS a bunch to accumulate the
total 20mS time period.
A single interrupt every 20mS & no reloading anything. Timer1 is automatically cleared on
match, and the CCPR1L/CCPR1H registers contain the value loaded into them until you
change it.
