PBP projects for R/C models
Results 1 to 40 of 772
    Default Why is the pulse width jumping all over?
    I had earlier success in getting a servo pulse width to be smooth on a Pic18F2520. But I am now trying to make DT_INTS servo pulse width for a PIC12F683. I have it sweeping from about .95ms to 1.9 ms, but it is not smooth at all. In fact, on the scope, it sometimes switches direction (starts to get wider instead of narrower for a fraction of a second). It is pretty darn ugly in fact.
    Any ideas what I might have done (or not done) to cause this?
    PIC12f683
    </i></font><b>DEFINE </b>OSC 8
    <b>INCLUDE </b><font color="#FF0000">&quot;DT_INTS-14.bas&quot; </font><font color="#000080"><i>;interrupt routines
    </i></font><b>INCLUDE </b><font color="#FF0000">&quot;sub16.inc&quot;       </font><font color="#000080"><i>; subtract 16 bit macro
    </i></font><b>DEFINE </b>DEBUG_REG	GPIO
    <b>DEFINE </b>DEBUG_BIT	0
    <b>DEFINE </b>DEBUGIN_BIT	1
    <b>DEFINE </b>DEBUG_BAUD	38400
    <b>DEFINE </b>DEBUG_MODE	0
    INTCON = %10101000 <font color="#000080"><i>'internal oscillator
    </i></font>OSCCON = %01110000 <font color="#000080"><i>'set for 8mhz internal
    </i></font>CMCON0 = 7 <font color="#000080"><i>'TURN COMPARITORS OFF
    </i></font>TRISIO = %010000 <font color="#000080"><i>'Set GSIO 4 INPUT, others to OUTPUT
    </i></font>OPTION_REG = %11000010
    T1CON = %01000001
    T2CON = %01001110
    servo <b>VAR </b>GPIO.2
    servo = 0
    pulse <b>VAR BYTE
    </b>pulse = 0
    bittest <b>VAR BIT
    </b><font color="#008000">INT_LIST  macro    </font><font color="#000080"><i>; IntSource,        Label,  Type, ResetFlag?
            </i></font><font color="#008000">INT_Handler   TMR0_INT,   PulseOut,   ASM,  yes
            INT_Handler   TMR2_INT,   period,     ASM,  yes
            INT_Handler   TMR1_INT,   test,       ASM,  yes
        INT_CREATE               </font><font color="#000080"><i>; Creates the interrupt processor
        </i></font><font color="#008000">INT_ENABLE  TMR0_INT     </font><font color="#000080"><i>; Enable pulseout interrupts
        </i></font><font color="#008000">INT_ENABLE  TMR2_INT     </font><font color="#000080"><i>; enable period interrupt (20ms)
        </i></font><font color="#008000">INT_ENABLE  TMR1_INT     </font><font color="#000080"><i>; enable interrupt to increment pulse width (test)
    </i></font><b>ENDASM
    </b>Main:
        nop
    <b>GOTO </b>Main
    <font color="#000080"><i>'---[TMR0_INT - interrupt handler]------------------------------------------
    </i></font><b>ASM
    </b><font color="#008000">PulseOut
        btfsc _bittest      </font><font color="#000080"><i>;test status of bittest bit
        </i></font><font color="#008000">goto $+7            </font><font color="#000080"><i>;if high skip 7 lines
        </i></font><font color="#008000">bcf OPTION_REG,5    </font><font color="#000080"><i>;stop timer
        </i></font><font color="#008000">movf _pulse,w       </font><font color="#000080"><i>;load TMR0 with value of pulse variable
        </i></font><font color="#008000">movwf TMR0
        bsf _bittest        </font><font color="#000080"><i>;set bittest bit, indicating we are on second half
        </i></font><font color="#008000">bsf OPTION_REG,5    </font><font color="#000080"><i>;start timer again for second interrupt
        </i></font><font color="#008000">goto $+3            </font><font color="#000080"><i>;skip to return from interrupt
        </i></font><font color="#008000">bcf _servo          </font><font color="#000080"><i>;bring servo pin low for end of pulse width
        </i></font><font color="#008000">INT_RETURN
    </font><b>ENDASM
    </b><font color="#000080"><i>'---[TMR2_INT - interrupt handler]------------------------------------------
    </i></font><b>ASM
    </b><font color="#008000">period
        bsf _servo          </font><font color="#000080"><i>;set servo pin high (begin pulse width)
        </i></font><font color="#008000">movlw d'0'          </font><font color="#000080"><i>;set timer0 to 0 (full length of timer)
        bsf OPTION_REG,5    </font><font color="#000080"><i>;start timer0, now PulseOut interrupt will occur
        </i></font><font color="#008000">bcf _bittest        </font><font color="#000080"><i>;clear bittest bit
    </font><b>ENDASM
    </b><font color="#000080"><i>'---[TMR1_INT - interrupt handler]------------------------------------------
    </i></font><b>ASM
    </b><font color="#008000">test
        incf _pulse
        INT_RETURN
    </font><b>ENDASM
    </b></code></pre><!--EndFragment--></body>
    </html>
    Wink one idea
    I remember some batches of 12F683 did not like the duty value to be changed " on the fly " and needed to stop and restart the CCP module.
    Was written on the µChip datasheet ( prior to D release )...
    I think some lines about it exist on this forum.
    But you don't use the CCP module ...
    What I see more is you want to stop Timer0
    bcf OPTION_REG,5    ;stop timer
    Option.5 is the TOCS bit ... and that's not a good thing to switch clock to TockI pin ...
    Thanks Alain, that was it!
    I changed those to:
    bsf INTCON,5        ;enable timer0 interrupt
    and
    bcf INTCON,5        ;disable timer0 interrupt
    and now the pulse runs smoothly. Only I don't get the initial set timer0 to 0, then add the second half of pulse width. I only get the second half where TMR0=pulse. So pulse width is between 0 and 1ms.
    But I will work on that!
    Thanks again,
    Walter
    Nov 2009
    Fitchburg, Mass
    Default ds33014K is it!!
    Thank you for setting me straight on which document is which.
    DS33014K is just what I have been looking for.
    Tuesday Darrel Taylor's site said that it was under construction and that it would not accept new membership.
    I have coded in C and in Assembly. More recently in shell and tcl. I never had a reason to use Basic as none of my professional work used a PC.
    I think this 33014 will get me started.
    Scalerobotics, if you get a chance see if you can record the radio receiver output signals for the other channels. In particular one which is just ON-OFF from the point of view of the transmitter.
    Ken - thanks gang.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
