PBP projects for R/C models
Results 1 to 40 of 772
    Here is the result. It changes from off through the percentage points to all the way on, but the period remains constant at about 1.023ms. (I finally got my oscilloscope USB driver to work today!)
    Nov 2009
    Fitchburg, Mass
    Default PAUSE has no effect it would seem
    Thank you soooo much. What a great tool..
    Two things for me to consider.
    1. PAUSE seems to not have the affect I expected.
    2. The PR2 constant must mean something to PBP, but I can not figure out what.
    Lastly, which version of oscilloscope software do you use? Is it freeware or did it cost money. If so, how much?
    Ken
    Nov 2009
    Fitchburg, Mass
    Default Success!!!
    The following code makes the car go full speed backwards, then stop, then full speed forwards, then stop etc. Using the RC system I can control the motor continuously though varying speed. I have not yet figured what HPWM parameters produce various speeds to the ESC. It may be that the over-specification fast pulse frequency is overriding that nuance.
    To really discover what this is doing I need to study and understand the ASM code. I think HPWM is interrupt driven. I am concerned because page 87 of the PBP Manual seems to say that the slowest pulse frequency is 245 hz. I want 50 hz.
    '*  Name    : HPWMcommand.BAS                                   *
    '*  Author  : Ken Jones                                         *
    '*  Notice  : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 1/27/2010                                         *
    '*  Notes   : PBP has a HPWM command.  Let's try it.                                                  *
    ' Don't forget. The duty cycle is 0 to 256 resolution
    MAINLOOP:
      HPWM 1,110,50     ' Neutral discovered by experiment.
      PAUSE 5000
      HPWM 1,64,50      ' Full backwards
      PAUSE 2000
      HPWM 1,110,50
      PAUSE 5000
      HPWM 1,164,50     ' Full forward
      PAUSE 2000
     goto mainloop
    Ken
    May 2007
    ....I am concerned because page 87 of the PBP Manual seems to say that the slowest pulse frequency is 245 hz. I want 50 hz.
    Period = [(PR2) + 1] * 4 * TOSC *(TMR2 Prescale Value)
    Frequency = 1/Period
    Therefore with a 4MHz clock, the lowest frequency is 244Hz.
    Nov 2009
    Fitchburg, Mass
    Default I a not happy
    I think I am being told that HPWM can not do the job that I need done. Who has a suggestion?
    Did you just open the floor to my broken record again?! Here is my view, but I agree, you (we all) need to hear more viewpoints than mine.
    Darrel Taylor Interrupts using TMR0 for pulse width, and TMR2 for 20ms period, and receiver pulse width sensing with CCP1_INT and TMR1. Your chip has them, just need to utilize them.
    If you always have an RC receiver on, then you can use that as your time base for 20ms. So, you could use the CCP1_INT to read the pulse width coming from the receiver. (This will use TMR1). Then you could use TMR0, or TMR2 for the pulse width. Every time you calculated the pulse from your CCP1_INT, you would send out your servo pulse on whatever pin you like, or control multiple pins, using the same timer.
    You really just need to start playing around with these timers and interrupts, and pulse some pins to get your head around it. But without a scope, it will be pretty difficult in my opinion.
    Here some scope info that you asked me about. It is a stand alone, but has a USB port and free software that comes with it. It cost just under $300.00. http://picbasic.co.uk/forum/showthread.php?t=12483
    May 2007
    Ken,
    Can you do a LED blinky without using PAUSE (or any other delay commands)? Try to do a 1 second blinky using a timer. When you can do that, you will be well on your way to solving your motor ESC problem.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
