PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Default Yes, that is certainly true, but
    Yes, DC motors need the polarity changed to change direction. I was led to believe that there is something magical in this electronic speed control that made it work differently. Thank you for reminding me to question assumptions.
    Ken
    Nov 2009
    Fitchburg, Mass
    Default Maybe I need to use my dtdp switches
    If the electronic speed control does not reverse polarity as a function of pulse size, then I will need to use the technique Fritsl used in his wall hugging robot.
    http://letsmakerobots.com/node/928
    (which seems no longer available)
    He cross wired the motor with multiple DPDT relay switches controlled by his PIC. I was going to copy that idea, but then I started believing the story of the magical ESC.
    Hi Ken,
    This may or may not be helpful, I think diagram "A" on page #3 might be to your fancy.
    http://www.picbasic.co.uk/forum/atta...4&d=1228220843
    Wink
    I would like to pump PWM pulses out CCP1 that have a frequency of one every 20 msec (50 per second) and a pulse width that I can (by changing the code) vary from 1 msec to 2 msec. Am I correct in guessing that the frequency of the pulses is dictated by the PAUSE command. One pulse per loop through mainloop:
    CCP1 PWM @ 50 Hz ??? ... just read your Datasheet first !!!
    NOW ... triggering the CCP1 module ( in compare mode ) @ 50 Hz ( from a timer ) looks much better ...
    might be the PULSOUT could also do the trick for a CPU " locking time " of 2 ms ... if possible.
    Now, a good program flow allows many, many things for R/C systems without using interrupts or peripherals ...
    Nov 2009
    Fitchburg, Mass
    Default Here's a snip from FATUBA FAQ page.
    FATUBA manufactured the radio receiver in my RC car. It is the output of that box that I am trying to emulate coming out of my 16F887. They say here that reversing direction is done by controlling the PWM pulse size above or below 1.5ms. That is what I have been doing - I thought.
    Attached is a quote from Electronic Control for DC Motors Using Discrete Bridge Circuits. It seems to say that my ESC should accept servo type PWM signals.
    Is the output signal digital?
    Output signals are ANALOG. Receivers vary by design on how they RECEIVE and ENCODE signals. But all deliver very similar output pulse signals, which is used to drive the servo to the desired location. This output pulse ranges from 1000uS to 2000uS, with 1500uS typically being center.
    Is the output signal an on/off signal or does it have an internal regulator?
    The output signal for each channel is a pulsed signal. The pulse width (commonly 1000uS to 2000uS) is determined by the corresponding channel of the transmitter. When activated by one of the proportional channels (such as elevator, aileron, throttle, rudder, or knob control) the pulse width will vary. This controls the servo movement. Most servos will be centered when the pulse is at 1500uS. Channels that are controlled by a switch (such as the gear channel) will operate the pulse width from two set values such as 1100uS when in one position and 1900uS when set to the other position to activate servo movement.
    What signal does the receiver emit to differentiate forward or backward movement?
    Direction of movement is determined by the direction in which the respective pulse is shifted off of center (neutral). Center being 1500uS, if the pulse is shifted above 1500uS, the direction of travel is one direction. If the pulse is shifted below 1500uS, the direction of travel is in the opposite direction.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
