PBP projects for R/C models - Page 17
Page 17 of 20 FirstFirst ... 71314151617181920 LastLast
Results 641 to 680 of 772
  1. #641
    Nov 2009
    Fitchburg, Mass
    Default One last thought
    I have built four cars.
    Two 1/10 scale model level. My original and my new one. The new one is inherently much faster. They are both the same car from the same company.
    Two toy level:
    One 1/12 scale which is similar to Frits'.
    One 1/10 scale which you saw in my video.
    Maybe I should bring them all to the gym on a sunny day for a grand comparison.
    Ken
  2. #642
    Aug 2010
    Maryland, USA
    What I am really trying to do is get some numbers together for things like : at half speed, must turn by XX inches or we will crash/skid. Also after watching your video again, the wall tracking appears to be a combination of 2 things. too much time between sensor readings, and too much turn (over driving)
    'side note
    My personal feeling is to get all the driving out of the int and in the main, but it might not matter. Just good coding. Imagine on your next project, when an int occurs, you could not tolerate a 4ms delay from what ever you were doing.
    'end side note
    Back on topic: so why not try increasing the sonar to every 50ms for each? This would more than double the resolution of your readings. Then we need to address more choices for how much to turn. A couple pages back you had asked if the math could be done digital. the answer is yes of course, just type more if statements. maybe instead of 2 stage steering, how bout 10% increments? fom 0-100%
    something else picking at me is the timing. right now, every half sec, your int could take longer than 5ms. this is because of :2 servo updates could be 4 ms, plus at cnt=50*2 cnt2=4 so you have to ping sonar 2 also. Actually, come to think of it, sonar could last up to 30 ms!!!! so that is definantly too long for the 5 ms interupt.
    sample int handler:
    reload timer
    cnt=cnt+1
    cnt2=cnt2+1
    flags=0
    simular written in asm:
    movlw _preload.lowbyte
    movwf timer1L
    movlw _preload.highbyte
    movwf timer1H
    inc _cnt
    inc _cnt2
    movlw 0
    movwf _flags
    I would have to check your datasheet again to make sure the inc's are correct and I'm not sure about using your PBP variables like that, but I think its correct.
    I gave you the ASM equalviant so you could see what it is and if you want to use asm, you don't need to include PBP_include or whatever it is
    -Bert
  3. #643
    Nov 2009
    Fitchburg, Mass
    Default a couple of things then off to bed.
    Some time ago, I know not when, I purchased PIC MICROCONTROLLERS from MikroElektronika. Then I put it in a pile and forgot. It reappeared this morning. Looks like I have much of the ASM info I have been seeking.
    My old HPWM system uses a TRIGGER: subroutine for SONAR triggers. The leds on the SONARs blink many times per second. They are too fast to count accurately. Each SONAR blinks at least 55 times in ten seconds. My non-mathematical guess is fast's enough if the steering servo and the wheel motor are reacting 'instantly'. Which they are not.
    I think I have learned that there is no advantage keeping the PWM signal down to 50hz. All that is necessary is to calibrate the pulse widths as they appear in HPWM 2, xx, 50.
  4. #644
    Nov 2009
    Fitchburg, Mass
    Default envisioning my variables?
    A number of your suggestions push me to work quantitatively. I have been 'eying' my distances - measuring with outstretched hand tip of thumb to tip of little finger = about ten inches.
    I would have a better handle on the behavior of my robocar if the SONAR measurements were in decimal inches. Right now I have a system of translating the echo pulse size to inches that I derived empirically. It would make my life easier if when I do a READ of numbers I have stored in EEPROM Data they came out as digital. How with PBP do I do that?
  5. #645
    Aug 2010
    Maryland, USA
    Thats an easy one Ken sinec your result is measured in 10uS steps, according to the spec for your sonar, "If the pulse is measured in uS, then divide by 148 to get inches". So all you have to do is inchesright = rangeright/148. And inchesfront = rangefront/148.
    Now I am not sure you really need to convert it in your program. You could just look at the range results and use a calc so you can get a feel for it. your car won't care about the units.
    EDIT: heres what keeps haunting me. lets assume most of the time the front is >33.783 inches (5ms pulse divided by 148). that means your interupt will retrigger while in the interupt. Maybe thats ok, as long as you have stack space for all the saves and returns. Also, the reason for changing the servo pulses to interupt drivin from HPWM was to be able to more properly command the servos.
    -Bert
  6. #646
    Nov 2009
    Fitchburg, Mass
    Default What I have been thinking.
    I have been multiplying by .066 (in my head). Give or take a decimal point. I want to be able to READ the EEPROM and see inches. Not easy?? Is there a PBP routine that does this?
    My interrupts are once every 5 millisec. I count 25 of them between each SONAR trigger. They are 125 millisec apart. The servos do work well with properly timed pulses, but they do not seem to react any quicker or with any finer precision. I have no accurate means of measuring this.
    Thank you for thinking along with me. My computer experience was all digital data communication. Ultimately I retired from CISCO. I know nothing about real time control systems.
    Ken
  7. #647
    Aug 2010
    Maryland, USA
    I think its this easy:
    write SomewhereInEEprom,inchesfront
    write SomewhereElseInEEprom,inchesright
    To get the result from EEprom:
    read SomewhereInEEprom,frontanswer
    read SomewhereElseInEEprom,rightanswer
    Ok, first I have demonstrated my inability to do simple math somewhere in some posts about your sonar timing. But no matter. Heres whats going on right now. you trigger every other sonar 125 mS apart, so if only talking about the right sonar for now, it is triggered every 250 mS, or 4 times per sec. I think that is just too slow!!!. your steering servo can and does react fast enough, but it gets the same signal 12 times before you have a new range to adjust with. So thats 6 missed opportunities to get a better correction.
    Ken
    its all fun for me, I am learning PBP far faster this way so its mutually benifical for both. And BTW, I switched majors in collage because I didn't want to learn the communication side of electronics. Something about "transform anaylases" just scared me
    -Bert
  8. #648
    Nov 2009
    Fitchburg, Mass
    Default My point is decimal
    I do write SONAR proximity results in EEPROM. I use the WRITE command. It comes out in HEX with reversed words. Here is an example:
    Address 00 contains BC
    Address 01 contains 02
    This reads as BC 02 when looking at the EEPROM readout.
    These are HEX and they are reversed. They represent:
    $02BC = 256x2 +16x11 + 12 = 512 + 176 + 12 = 700decimal
    Take 2/3 of 700 and get about 48 inches. I do that with in my head or with scratch paper.
    Your system of dividing 700 by 14.8 gets 47.29 inches. My brain can figure out "two thirds of" easier.
    I want addresses 00 and 01 to look like 4729, or preferably rounded down to 0047 or up to 0048. Can PBP do that?
    Ken
  9. #649
    This will write asci to your eeprom data. Your PicKit2 can be set to read data as asci with the little drop down box. By the way, I hope you are not writing to the eeprom each time a distance is measured, because you will wear your chip out pretty quick that way.
    distance var word
    inches var byte
    distance = 700
    distance = distance * 10
    distance = distance + 74        'add half of divisor (148) , this is not  needed, but will "round up" if you want to be a little more accurate
    inches = distance / 148
    write 0,61                      'For "=" (standard asci character set)
                                    'the + 48 changes it from dec to asci
    write 1, inches dig 2 + 48      'will be a "0" if inches = 47
    write 2, inches dig 1 + 48      'will be a "4" if inches = 47
    write 3, inches dig 0 + 48      'will be a "7" if inches = 47
    Then you can view it like this:
    http://www.scalerobotics.com
  10. #650
    Nov 2009
    Fitchburg, Mass
    Default New video. Model car races Toy car
    Today I brought both of my PIC controlled cars to the old gym to see how they fared together on the same track. Here's the video. Which do you think was the winner? Remember the TOY car is red. The MODEL car is blue. The TOY cost originally cost $50. The MODEL cost $200. Both have my kit.
    What do you think? Should I show it on Access Television?
    Ken
  11. #651
    They look pretty much equal to me.
    What if you took some paste board and made the corners a radius?
    Overall they look good!!
  12. #652
    Nov 2009
    Fitchburg, Mass
    Default Potential solution to bang-bang steering
    I have a new plan to control the much faster 1/10 scale toy car which is fast, but does not contain proportional controls. The trick is to turn the wheels only for a short period of time (150 msec at the moment) then 'kick' (supplement the springs) them back to neutral.
    If the neutral is well calibrated (the 1/10 cars have a knob that centers the wheels) this method makes the car turn with little swerve. I need this while wall following. Otherwise the car crashes into the wall before the code/DPDT relay/steering wheels can react.
    I'll make a video if this really works.
    Ken
  13. #653
    Aug 2010
    Maryland, USA
    Great Idea Ken
    -Bert
  14. #654
    Worked for me
    Originally Posted by mackrackit :
    I just drove home trying to simulate Ken's car. Pulsed the same degrees left or right, more pulses left or right for turns but always the same, say 5 degrees off center, and after each pulse returned to center.
  15. #655
    Aug 2010
    Maryland, USA
    GEE, I thought no one was listening - LOL
    -Bert
  16. #656
    Nov 2009
    Fitchburg, Mass
    Default Your full size scale car has toe in and caster....
    My toy car has neither toe in nor caster. But it should be able to react. It does not. If you are in a helping mood here is both a (disappointing) video, and a pointer to my code.
    http://www.employees.org/~kjones/ToyCarKickTurn3.htm
    Could the PIC be resetting? Am in a looping loop? The whole thing is only 503 words compiled. My guess is that I am not seeing something that right in front of my eyes...
    Ken
  17. #657
    Wondering if the part in RED is causing the trouble? If it were eliminated and sent to
    CheckIfInDanger:
    after
    keepreversing:
    was satisfied???
     keepreversing:
    WHILE rangefront < stopreversing
    ' We have not reversed far enough
      HIGH stopgo  'go
      LOW forrev   'back
      GOSUB triggers
    WEND
    'done reversing.  Go straight or turn left depending on right
    'ping. If > outertrack then out in the middle.  If < desiredtrack
    'then stuck on wall.
    IF rangeright > desiredtrack THEN
    'steer left
      LOW turnon   'steer
      HIGH steerto  'left
      steeringstate = 1
      HIGH stopgo   'go
      HIGH forrev   'forward
      PAUSE 500
    'hpwm 2,Forward,50  --Already going Forward
    GOTO main
  18. #658
    Nov 2009
    Fitchburg, Mass
    Default Seems to work OKAY on the bench
    Went to bed last night puzzled.
    Checked the car (untouched since disastrous demo yesterday) on the bench. Seemed to react correctly and quickly. The stimuli are my hands moving as quickly as I can make them.
    Hmmmm.....
  19. #659
    Nov 2009
    Fitchburg, Mass
    Default This must be the looping triggers section
    Could it be that somehow this tight loop eliminates the ability to react to the front SONAR. The video shows the car stuck against the wall in total silence with the front LED constantly on. This WHILE loop could cause that if somehow the two drive motor instructions were being short changed. Maybe I need a PAUSE in here. It would do no harm.
     keepreversing:
      HIGH stopgo  'go
      LOW forrev   'back
      GOSUB triggers
    WEND
  20. #660
    Nov 2009
    Fitchburg, Mass
    Smile Success!!
    Take a look at:
    Please tell me what you think.
    Ken
  21. #661
    Aug 2010
    Maryland, USA
    Ken that is just stunning!!!!!
    Please share with us the change that made it happen, or was it multiple changes? Looks like now you can tweek the distances to get closer to the wall.
    -Bert
  22. #662
    COOL!!!!
    What did you do??
  23. #663
    Nov 2009
    Fitchburg, Mass
    Default I'll share the code in a bit
    The changes were of two types.
    1. Instead of "braking" by turning off the DC voltage to the wheels (thereby relying on reverse polarity created by the rolling momentum of the wheels in the DC motor) I now use the DPDT relays to reverse the polarity for a few hundred milliseconds.
    2. I put some PAUSE commands in to make sure wheel and steering related commands had time to actually do what I had expected.
    Thanks...
    Ken
  24. #664
    Nov 2009
    Fitchburg, Mass
    Default The break through was in fact a break -er it was broke!
    I put the car up on blocks and found that when going forward it only turned left in my patented incremental way. It also flashed the SONARs at about 1/2 the usual rate.
    The Vcc wire for the right side SONAR had become disconnected.
    Soooo with the front SONAR working and the right SONAR always saying zero distance to the wall, the car turns left in little bits except when it approaches a wall head on. Then it brakes and swerves left.
    That's exactly what my video shows.
    Given that information, what if anything should I fix?
    Ken
  25. #665
    Well now you know exactly where the problem is. Connect the side scan and start tweaking that part of the code.
  26. #666
    Nov 2009
    Fitchburg, Mass
    Smile It is beginning to dawn.....
    The issue is controlling the steering. It is bang-bang but I can modify the length of time and the frequency of each 'bang'. The plastic wheels slide easily. This is true of turning as well as forward or reverse drive.
    I hope not to introduce an adjustment POT. It appears that the plastic mechanical parts are not consistent. Kicking the steering wheels back from full reach seems not to be symmetric. Hmmmm.
    Ken
  27. #667
    Nov 2009
    Fitchburg, Mass
    Red face I've been too simplistic
    The car turns left when the right SONAR says it is further away from the wall than "desiredtrack". The car then moves a bit more as it rotates (turning right) its distance to the wall increases as a function of its rotation.
    So it decides to keep turning right. Wrong!!
    I need to think more about this.
    Ken
  28. #668
    Nov 2009
    Fitchburg, Mass
    Red face Wrong
    I typo'd. The car turns left when the right hand SONAR says it is too close to the wall - ie less than "desiredtrack". It then crosses the imaginary "desiredtrack" line which is parallel to the wall.
    Now it starts to turn right - as it should. As the right turn aims the front of the car more at the wall, the right SONAR finds that same wall farther away. It exceeds the "desiredtrack" distance and therefore keeps turning right.
    CRASH
  29. #669
    CRASH
    Sounds like you need to limit your angle as you turn into the wall.
    When adjusting right to get to your imaginary line (closer to the wall), if front distance < 3 * side distance, then turn left (until front distance > 3 * side distance). Something like this should help keep from making too big of a right turn, but still get you closer to the wall.
    Changing the 3 would change the angle you would allow.
  30. #670
    malc-c's Avatar
    malc-c Guest
    Take a look at:
    Ken
    Ken,
    Not been following this thread for a while, but simply based on that video my guess is that due to the wheels having limited grip it slides / wheelspins each time the controller nakes an adjustment. If you are able to change the tires for something that grips better you might find it has better control of it's destiny
  31. #671
    I am pretty sure this method will lead to oscillations. In fact in the Ken's video this really happens. The car "oscillates" around its desired path.
    With simple if-then commands this cannot be compensated. As discussed in previous post, a PID loop control can help.
    Nov 2009
    Fitchburg, Mass
    Smile I did as scalerobotics suggested and
    it worked better. Now it goes pretty straight but does not turn left hard enough when confronted with a corner. Watching and listening to my video I conclude that at this speed with this little friction the PIC needs more warning (I only gave it 53 inches) to turn sharply left. I'll change that and try again tomorrow. Also this sharp left turn should not be modulated. It should be bang.
    It is a bit of a drive to my deserted gym. It has no heat and no electricity. My laptop crashed a few weeks ago. So one fix on my desktop PC, one test.
    A question: Do you folks recommend any editor that automates my version control? I would like to start with version 1.0 then activate an editor that automatically adds each of my code changes one batch at a time. If I had that I could recreate any past version.
    Presently I am saving the versions identified by their checksum. That is clumsy.
    Ken
  33. #673
    Nov 2009
    Fitchburg, Mass
    Smile Post Script
    I like the sliding robocar. If I want solid control I would go back to the 1/10 scale hobby level car. There are many available rubber compounds for the hobby car wheels. They have caster, toe-in, four wheel drive and weigh four pounds.
    Sliding looks like dirt track racing. When I was a kid we had midget car racing with little four cylinder Offenhouser engines on a 1/4 mile dirt oval. I did not do it, but I sure did watch.
    Ken
  34. #674
    Versions..
    Might be kind of crude, but I just copy the *.bas file and paste it into the same directory. The the copy has Copy(x) added to the file name. Then the date and time stamp can be referenced.
  35. #675
    Nov 2009
    Fitchburg, Mass
    Question How do you keep track of the changes?
    How do you keep track of the details of each change? Comments grow and grow and grow...
  36. #676
    Again kind of crude.
    A large comment block at the end of the code. 'Notes
    And or a text file. Kind of like a daily log.
    I keep current project in DopBox so I can at least look at the code and take notes in the field on my phone if I do not have a computer with me.
    Evernote is pretty good also.
  37. #677
    Dave,
    do you keep the *.bas, *.pbp in the default directory? Does compiler have any problem with the path?
    I am considering to keep my files there too.
    Ioannis,
    I let PBP and MPLAB install to their default directories, but my actual code and related project files are kept here.
    C:\MAC\My Dropbox\PIC PROGS\"project name here"
    Cad/CNC files and such are in a sub directory of the above.
    Another benefit from having an off site backup... My CNC machine's PC is also DropBoxed so the machine always has the latest files automatically.
    No problems with the path, the path name is still under the length limit this way.
  39. #679
    OK, Thanks Dave.
    Nov 2009
    Fitchburg, Mass
    Red face Calling all Geeks......
    Ladies and gentlemen - I am bamboozled. My 1/10 toy level car seems to be a bit confused also. Garbage in. Garbage out. The old give-no-quarter rule of programming. Is the issue response time? Is the issue inconsistent friction? Is the issue - no it couldn't be - my PBP code? I believe the electronics are consistent and the hookup wires are stable ( I used Silicone household sealant)
    In the video I say, "As soon as it starts to turn right, it's in trouble." That now seems not to be the problem. After it successfully negotiates a corner-caused left turn and it is too close to the new wall, it turns left to get out to desiredtrack, but never straightens out.
    The code is at: http://www.employees.org/~kjones/ToyCarKickTurn4.htm
    Any insight would be greatly appreciated.
    Ken
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
