PBP projects for R/C models - Page 16
Page 16 of 20 FirstFirst ... 6121314151617181920 LastLast
Results 601 to 640 of 772
  1. #601
    How'd that work out for you?
    Worked well until I pulled up to the checkpoint doing it. Thought they were going to take me to secondary...
    Ken,
    Here is code using DT's INTs giving an interrupt at 200 Hz.
    All I did was tweak Darrel's blinky example.
    <font color="#008000"><b><i>'FL PIC16F887
    '16F887 DT INT RUPT
    '44 PIN DEMO BOARD
    'REMOVE THIS LINE IF NOT SETTING THE CONFIGS IN CODE SPACE
    </i></b>@ __config _CONFIG1, _INTRC_OSC_NOCLKOUT &amp; _WDT_ON &amp; _MCLRE_OFF &amp; _LVP_OFF &amp; _CP_OFF
    </font><font color="#0000FF"><b>OSCCON </b></font>= <font color="#800000"><b>%01100000 </b></font><font color="#008000"><b><i>'4 Mhz
    </i></b></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>OSC </b></font><font color="#800000"><b>4
    </b></font><font color="#0000FF"><b>LED1    </b></font><font color="#FF0000"><b>VAR </b></font><font color="#0000FF"><b>PORTD</b></font>.<font color="#800000"><b>4
    </b></font><font color="#0000FF"><b>wsave </b></font><font color="#FF0000"><b>VAR BYTE </b></font><font color="#800000"><b>$70 </b></font><font color="#0000FF"><b>SYSTEM
    </b></font><font color="#FF0000"><b>INCLUDE </b></font><b><i>&quot;DT_INTS-14.bas&quot;     </i></b><font color="#008000"><b><i>' Base Interrupt System
    </i></b></font><font color="#FF0000"><b>INCLUDE </b></font><b><i>&quot;ReEnterPBP.bas&quot;     </i></b><font color="#008000"><b><i>' Include if using PBP interrupts
    </i></b></font><font color="#FF0000"><b>ASM
    </b></font><font color="#008000">INT_LIST  macro    <b><i>; IntSource,        Label,  Type, ResetFlag?
            </i></b>INT_Handler   TMR1_INT,  _ToggleLED1,   PBP,  yes
        INT_CREATE               <b><i>; Creates the interrupt processor
    </i></b></font><font color="#FF0000"><b>ENDASM
    </b></font><font color="#008000"><b><i>'5.0 mSec OR 200 Hz INTERRUPTS
    </i></b></font><font color="#0000FF"><b>T1CON </b></font>= <font color="#800000"><b>%00000001         </b></font><font color="#008000"><b><i>'Prescaler = 1:1, TMR1ON
    'PRELOAD 60543
    </i></b></font><font color="#0000FF"><b>PreLoad     </b></font><font color="#FF0000"><b>VAR WORD
    </b></font><font color="#0000FF"><b>PreLoad </b></font>=  <font color="#800000"><b>60543
    </b></font><font color="#0000FF"><b>TMR1L </b></font>= <font color="#0000FF"><b>PreLoad</b></font>.<font color="#0000FF"><b>LowByte
    TMR1H </b></font>= <font color="#0000FF"><b>PreLoad</b></font>.<font color="#0000FF"><b>HighByte
    </b></font><font color="#008000">@ INT_ENABLE  TMR1_INT     <b><i>; enable Timer 1 interrupts
    </i></b></font><font color="#0000FF"><b>Main</b></font>:      <font color="#008000"><b><i>'DO WHATEVER YOU WANT HERE
      </i></b></font><font color="#FF0000"><b>PAUSE </b></font><font color="#800000"><b>1000
      </b></font><font color="#FF0000"><b>HIGH </b></font><font color="#0000FF"><b>PORTD</b></font>.<font color="#800000"><b>7
      </b></font><font color="#FF0000"><b>LOW </b></font><font color="#0000FF"><b>PORTD</b></font>.<font color="#800000"><b>7
    </b></font><font color="#FF0000"><b>GOTO </b></font><font color="#0000FF"><b>Main
    </b></font><font color="#008000"><b><i>'---[TMR1 - interrupt handler]--------------------------------------------------
    </i></b></font><font color="#0000FF"><b>ToggleLED1</b></font>:
         <font color="#FF0000"><b>TOGGLE </b></font><font color="#0000FF"><b>LED1
         </b></font><font color="#FF0000"><b>TOGGLE </b></font><font color="#0000FF"><b>PORTC</b></font>.<font color="#800000"><b>6    </b></font><font color="#008000"><b><i>'CONNECTED TO METER
         </i></b></font><font color="#0000FF"><b>TMR1L </b></font>= <font color="#0000FF"><b>PreLoad</b></font>.<font color="#0000FF"><b>LowByte   </b></font><font color="#008000"><b><i>' Load the timer with preload value.
         </i></b></font><font color="#0000FF"><b>TMR1H </b></font>= <font color="#0000FF"><b>PreLoad</b></font>.<font color="#0000FF"><b>HighByte
    </b></font><font color="#008000">@ INT_RETURN
    </font>
  2. #602
    Aug 2010
    Maryland, USA
    Hi Ken, Just looked over section 6. I always think about the prescaler like this:
    With no prescaler, timer increments as I posted earlier, Every 4 counts of the ocs will inc the timer by 1. If you have prescale set to 2, timer will inc every 8 counts, or half as fast. set to 4 it will inc every 16 counts or 1/4 speed, and set to 8, timer will inc every 32 counts or 1/8 speed. does this make sense?
    So in summary, the prescaler is really a clock divider for the timer.
    -Bert
  3. #603
    Aug 2010
    Maryland, USA
    Default Bravo dave
    Quick question, how did you determine the preload value? I mean to say, I understand what it represents, just how did you determine the offset?
    -Bert
  4. #604
  5. #605
    Nov 2009
    Fitchburg, Mass
    Default Two steps forward, One step backward
    Not much luck reading DT_INTS-14. I do not understand ASM and all the macros that have been written.
    Soooo I installed the two blinky programs and they both looked correct. I activated the LOGIC TOOL from PICKIT2 and looked carefully at the 20millisec square wave. Close enough for government work. Next I changed the
    TOGGLE PORTC.6 'CONNECTED TO METER
    command to
    PWM PORTD.7, 127, 1
    and hooked up Channel 2 of the LOGIC TOOL to PORTD.7.
    I expected to see a single pulse every 20millisec. I even hoped that the pulse would be 1.5millisec long.
    I see many pulses seemingly not related to the edges of the interrupt driven 50Hz square wave. I would show you all a picture, but my FastStone Capture is screwed up.
    Is there any PWM-like command that makes one pulse ranging from 1millisec to 2millisec in 256 gradations?
    Ken
  6. #606
    That is odd, I must have something off...
    The PULSOUT command might do the trick?
  7. #607
    Nov 2009
    Fitchburg, Mass
    Default Here's a snap shot.
    Here is what my LOGIC TOOL displays. The only change in the code is this substitution of a PWM command.
    ToggleLED1:
         TOGGLE LED1
         PWM PORTD.7,127,1
         TMR1L = PreLoad.LowByte   ' Load the timer with preload value.
         TMR1H = PreLoad.HighByte
    @ INT_RETURN
  8. #608
    Nov 2009
    Fitchburg, Mass
    Default Hard to explain...
    I do not understand this result. The gist is that the pulse generating command seems to influence
    the interrupt frequency. Here is exactly our same code with a PULSOUT PORTD.7, 50 inside the
    interrupt routine.
    OSCCON = %01100000 '4 Mhz
    LED1    VAR PORTD.4
    wsave VAR BYTE $70 SYSTEM
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    T1CON = %00000001         'Prescaler = 1:1, TMR1ON
    'PRELOAD 60543
    PreLoad     VAR WORD
    PreLoad =  60543
    Main:      'DO WHATEVER YOU WANT HERE
    '  PAUSE 1000
    '  HIGH PORTD.7
    '  PAUSE 1000
    '  LOW PORTD.7
    GOTO Main
    ToggleLED1:
         TOGGLE LED1
         pulsout PORTD.7,50
    '     PWM PORTD.7,127,1
    '     TOGGLE PORTC.6    'CONNECTED TO METER
    @ INT_RETURN
    And here's the LOGIC TOOL picture.
  9. #609
    Looks like the PULSOUT is taking longer than the interrupt. And of course I do not have the interrupt timed correctly.
    Hopefully someone will straighten me out on the math.
  10. #610
    Aug 2010
    Maryland, USA
    According to the manual, each "PWM cycle" takes about 5ms with a 4Mhz clock. My guess is the first example has the interupt routine taking longer than the time between interupts. And you are prolly getting lucky to ever leave the handler at all!
    The second example using pulseout, looks much better. Hard to count the lines, is it the correct timing?
    Now remember, you don't want the pulseout in the interupt handler.
    -Bert
  11. #611
    Nov 2009
    Fitchburg, Mass
    Default LOOKs correct now
    The correct picture is this one. PULSOUT is in the interrupt handler only after the RESET TIMER action. Why is this bad?
  12. #612
    Aug 2010
    Maryland, USA
    The general rule is to get in and out of an interupt as fast as possible. But in your case, the problem is a bit different. the pulse for the servo's should be every 20 msec. you have an interupt every 5 msec. so you are updating the servo 4 times as fast as you want to.
    -Bert
  13. #613
    Great job Ken. What you are doing is the best way to learn about the interrupts. You have to play with them. That is a great start.
    I believe both pulsin and pulsout are blocking commands. While they run, nothing else can happen on your chip. Once they are finished, sure, things resume and the program takes over. For a single servo, this is fine. But once you start throwing in sonar, multiple servos, other things you have thought of, and some you haven't thought of yet ... then you start to run out of time to do all these things using blocking commands. Especially if you want to go 20 mph.
    As it stands, 20mph is half a foot for each 20ms (that is every chance you get to make an R/C correction). For your sonar, it takes a bit over 20ms, so if that is the only input, the best your chip can do is determine a correction every other 20 ms, or every foot.
    In fact, just listening to the echo pulse on your sonar takes up to 25 ms, so that alone screws up everything if we use blocking commands like pulsin. (and double the screwed if you are listening to two of these!)
    So, in the long run I think it is best to use interrupts for listening to your sonars, as well as outputting to your servo's. I can't remember how you are switching your transmitter for R/C control vs pic control, but that too might as well go on interrupts.
    If you do, you have all kinds of time. You can be listening for two sonars at the same time, chewing on some math to determine the amount of turn, etc. If you want speed, it is most definitely the way to go.
    That said, exactly what you are currently doing to learn is what I would recommend. Use the commands you know with interrupts to make things happen, and see how they work, and how to adjust them. Later on, when you feel comfortable with them, try adding in another interrupt timer to control a servo pulse.
    http://www.scalerobotics.com
  14. #614
    Aug 2010
    Maryland, USA
    Hi Walter, I love what you are saying about using int instead of pulsein/out. I am having trouble visualizing how to do that.
    In my head, something has to be the overall clock, thats where my suggestion of 5msec came from. when I think about what you are saying, all I seem to be able to see is all these events started waiting for an int to make them stop. so I see like 6 different timers going all at once.
    Or maybe you have 1 timer going for the 20ms, then do everything else sequencially using a different timer.
    EDIT: The slow sonars are gonna definitly limit the top speed! Maybe as an upgrade once it works slowly, infra red emitters and detectors. This way they could also be used at the same time by sending different signals on each.
    -Bert
  15. #615
    That's a great question Bert. Well, you being an asm guy will probably get a few laughs at my first real attempt at using more than 20 lines of asm in my program. But I will show you anyway. This uses Timer1 for PWM measurement (read servo channels in). Basically, Timer1 runs non-stop, and when a state change interrupt is detected, the timer value is read. The start timer value is subtracted from the stop timer value to get the pulse width. This is done for all channels. After all channels are read, it is time to output pulses to the servos. So I do not have a 20 ms timer, it cheats and uses the R/C receiver as the 20ms timer. If all channels have been read, it must be 20 ms. The second interrupt is timer0. That is used for pulse duration on the output. I made the pulse base 1ms, then the timer gets set for a second interrupt to complete the pulse.
    Here is an example of reading 5 R/C channels, and outputting 4 R/C channels using two timers: http://www.scalerobotics.com/PWMpassthrough.html
    Something like that could be used. And in addition to detecting servo pulse in, and interrupt on change could time a pulse from two sonars at the same time. This could also read timer1 start and end times, so no additional timers would be needed. If you did not want to use the R/C receiver as the 20 ms timer, then timer2 could be used. But that is the last timer on this chip. But then, you can still throw more on those two other timers, if you wish.
  16. #616
    Aug 2010
    Maryland, USA
    Walter I never find things to laugh about in code that works! Besides, 20 lines of asm isn't really much. Thats one of the reasons I wanted to convert to a high level language. Fewer lines to type
    Ken is worried about firing both sonars at the same time cuz he may not know who the source is when it comes back.
    -Bert
  17. #617
    Ken was thinking smarter than I. Good point. Maybe keep your sonar for front view, and for side view something like this: http://www.acroname.com/robotics/parts/gp2y0a21yk_e.pdf . Or use infra sensors for both, since you can get updates every 20 ms to keep up with the fastest that you can change your servos. Besides, they are cheaper than sonar! You do need to pick your distance range though. The one I gave a link to was 4 inches to 30 inches, which seemed ok for following a wall. If its 30 inches or more, get closer....
  18. #618
    Nov 2009
    Fitchburg, Mass
    Default Blocking commands
    Yes, "blocking commands" is exactly the word. I figured that out while lying in bed with the LOGIC TOOL image in my head. I could see that the length of the pulse was being added to the interrupt time. I could not find any information on that in any of my documents. Please tell me where in which .INC file is the ASM code which is activated by PULSOUT. Without access to those details, PBP is just guess work.
    My plan is to insert counters into the interrupt service routine. Every four interrupts (20millisec) do a PULSOUT. Every 25 interrupts, TRIGGER one SONAR or the other alternatively. My TRIGGER is built of HIGH and LOW commands totaling 10 microseconds (or so). These are not blocking.
    I'll give this a try and see how the car reacts (if at all.....)
    Thanks again for the support.
    Ken
  19. #619
    I would approach it a different way, and avoid that pain. Especially since interrupts may grow on you, and you may get rid of your pulsin/out someday ! Say you want an interrupt every 20 ms and have a single servo to control, but you want to use pulsout since you are still learning interrupts. Since we can be a little off on our 20 ms, as Bert mentioned, the easy way is to say the average servo pulse is 1.5ms, so I need to interrupt every 18.5 seconds. If you add in the time of your pulsout, it will be very close to 20 ms, and your servo will be happy and grateful.
  20. #620
    If that plan is just for testing, it sounds like a great plan. But if you plan to use it while doing 20 mph, you will be doing a "ping" every 3.66 feet, or 8 times per second. If your reflexes are quick, you might be able to blink your eyes quickly at about 8 times per second. While your R/C car is doing 20 mph around a turn, try blinking your eyes as fast as you can, while steering your R/C car. I think your results might be similar to the ones we saw in the video.
  21. #621
    Aug 2010
    Maryland, USA
    see, this is one of the reasons I love this stuff. To do what Walter describes, with the same resources (1 interupt and pulsout), I would set my timer for 20 ms. My int handler would set a flag, and I would get out. Then in my Main, if the flag is set, hit my pulseout routine and clear the flag. This way I would get a new pulse every 20 ms on the dot. But mostly cuz I just always want to get out of the handler. I seem to feel like by name "Interupt" I was busy doing something before I went there. Maybe it was important and I need to get back to it.
    As for PBP being guess work, I don't think thats the case. Pulseout/in serout/in and the rest of them, take exactly as long as you think. if you PULSEOUT for 1 ms, thats how long it will take.
    -Bert
  22. #622
    Aug 2010
    Maryland, USA
    Walter, I like your idea of the 18.5 ms plus servo out to make up the 20ms loop. I need just that for my project. I will want to use 1 timer to control the loop and the pulse, so that seems the best idea to me.
    -Bert
  23. #623
    Nov 2009
    Fitchburg, Mass
    Red face I've come to a screeching halt
    "Verification of Program Memory failed at address 0x00000000"
    I tried some old code that I KNOW loaded. Not today.
    I swapped out the PIC. That was not the problem. I reseated all the patch wires. That made no difference.
    I restarted the PICKIT2 programmer. That did not help.
    I tried with a PICKIT2 board - the one on which I ran the blinkys - no problem. It liked to load and blink.
    Where do I start?
    Ken
  24. #624
    Nov 2009
    Fitchburg, Mass
    Smile Fixed it!!
    It was a wire I had added to give the LOGIC TOOL more information. I do not understand why the PICKIT objected. But all is well.
    The interrupt driven system sort of works. We'll see more tomorrow.
    Thanks again for your help and support.
    Ken
  25. #625
    Nov 2009
    Fitchburg, Mass
    Default Works as good as before
    I've got the system working interrupt driven. I do not have proportional controls implemented - yet.
    On the bench the car seems as responsive as before. We'll see when I take it to the gym.
    One thing I have not figured. How, now, to I disable interrupts when the radio transmitter has been
    turned ON? At the very end of this code pack is my old WHILE loop that worked - in the day.
    symbol trigright = PORTB.0 ' Define output pin for Trigger pulse
    symbol trigfront = PORTB.1 ' Define output pin for Trigger pulse
    symbol trigleft  = PORTB.3 ' Define output pin for TRigger pulse
    symbol echoright = PORTC.6 ' Define input pin for Echo pulse
    symbol echofront = PORTC.5 ' Define input pin for Echo pulse
    symbol echoleft  = PORTC.7 ' Define input pin for Echo pulse
    SYMBOL channel3  = PORTC.4 ' Define input pin for Channel 3 PWM
    ' PORTC.0 'High is R/C.  Low is PIC control
    TRISC = %11110000
    DATA $C0,$0C 'his version's checksum goes here.
    define ADC_BITS 8
    TRISA.0 = 1 'PORTA.0 as analog input for POT
    ANSEL.0 = 1
    ADCON1 = %00000000  'left justified
    ' We use low eight bits.  0 -> 255.
    ADCON0 = %01000001  'divide 4Mhz clock by 8.
    LED1    VAR PORTD.4
    'PRELOAD 60543
    PreLoad     VAR WORD
    PreLoad =  60543
    '@ INT_ENABLE  TMR1_INT     ; enable Timer 1 interrupts
    WHEELS VAR WORD
    STEERING VAR WORD
    'The following may be a big part of the wall hugging probllem
    Potread var word
    Forward var word ' was fixed 122. Now sweeps 7 steps. See Checkpot
    HalfForward VAR WORD ' Potread/2 +x + 1. See Checkpot
    Back VAR WORD 'See Checkpot
    HalfBack VAR WORD 'See Checkpot
    Brake con 100 'Only used just before Main.
    Straight con 150 '?
    Right CON 130     '?
    HalfRight con 135 '?
    QuarterRight CON 140 '?
    Left con 170     '?
    HalfLeft con 165 '?
    QuarterLeft con 160 '?
    frontdanger var word
    stopreversing var word
    frontfree var word
    desiredtrack var word
    outertrack var word
    'some of the following are not used.
    CNT  VAR BYTE 'counts interrupts for TRIGGERS
    cnt = 0
    CNT2  var byte ' counts interrups for wheels and steering
    CNT2 = 0
    b0 VAR word
    rangeright var word
    rangeright = 100  'about 6 inches preset
    rangefront var word
    oldrangeright var word
    oldrangefront var word
    reversing VAR WORD
    reversing = 0
    switchtoPIC VAR WORD
    switchtoPIC = 1
    radiocontrol var word
    radiocontrol = 0
    steeringleft var word
    steeringleft = 0
    steeringright var word
    steeringright = 0
    Checkpot:
    ' I think Potread goes from 0 to 6.
    adcin PORTA.0, Potread
    Potread = Potread/37
    Forward = 160+Potread
    HalfForward = 155+(Potread/2)  'seems to work.
    Back = 140-Potread
    HalfBack = 145-(Potread/2)
    frontdanger = 210 + Potread*55 '210-540, 14-36 inches
    stopreversing = 180 + Potread*25 '180-330, 12-22 inches
    frontfree = 700 + Potread*60 '700-1060, 48-70 inches
    desiredtrack = 180 + Potread*20 '180-300, 12-20 inches
    outertrack = 360 + Potread*15 '360-450, 24-30 inches
    write 2, word Potread
    write 4, word frontdanger
    write 6, word stopreversing
    write 8, word frontfree
    write 10, WORD desiredtrack
    write 12, word outertrack
    low PORTC.0
    'hpwm 1,Straight,50
    STEERING = Straight
    'hpwm 2,Brake,50
    WHEELS = Brake
    'pause 4000 'Wait so I can put the car down and get out of the way.
    CheckIfInDanger:
    if rangefront < frontdanger then
    STEERING = Straight
    WHEELS = back
    reversing = 1
    goto reverseoutoftrouble
    ' loop till this is secured
    tryleftturn:
    if rangefront < frontfree then
    'something ahead - turn hard left.
    STEERING = left
    WHEELS = halfforward
      steeringleft = 1
     goto main 'loop till this is secured
    goingforward:
    STEERING = straight
    WHEELS = forward
    keepgoingforward: '----Compare to right wall
    if rangeright > outertrack then
      STEERING = quarterright
    if rangeright < desiredtrack and oldrangeright < rangeright then
      STEERING = STRAIGHT
    if rangeright > desiredtrack and oldrangeright > rangeright then
      STEERING = STRAIGHT
    if rangeright > desiredtrack and oldrangeright < rangeright then
      STEERING = QUARTERRIGHT
    if rangeright < desiredtrack and oldrangeright >= rangeright then
      STEERING = QUARTERLEFT
    reverseoutoftrouble:
    while rangefront < stopreversing
      STEERING = RIGHT
      WHEELS = RIGHT
    wend
    if rangeright > outertrack or rangeright < desiredtrack then
      STEERING = LEFT
      steeringleft = 1
      WHEELS = HALFFORWARD
    '***********INTERRUPT HANDLER************
    ToggleLED1:
    TOGGLE LED1
    ' Trigger SONAR alternatively every 25 interrupts
    if CNT=25 then
     pulsr:
     oldrangeright = rangeright
    ' produce 10uS trigger pulse (must be minimum of 10uS)
     low trigright
     HIGH trigright
     high trigright
     high trigright
     LOW trigright
    'zero could be legal below
     pulsin echoright,1,rangeright 'measures the range in 10uS steps
    if CNT=50 then
     pulsf:
     oldrangefront = rangefront
     low trigfront
     hIGH trigfront
     high trigfront
     high trigfront
     LOW trigfront
     pulsin echofront,1,rangefront ' measures the range in 10uS steps
     CNT=0
     CNT=CNT+1
    if cnt2=4  then
    ' PWM pulses are between 1 and 2 millisec.
        low PORTC.1
        low PORTC.2
        pulsout PORTC.1,WHEELS
        PULSOUT PORTC.2,STEERING
        CNT2=0
    CNT2=CNT2+1
    @ INT_RETURN
    checkchannel3:
    'works with four AA batteries pack. Radio receiver puts pulses
    'on this line whenever the transmitter is turned ON.
     switchtoPIC = 2
     while switchtoPIC >= 2
        count channel3,65,switchtoPIC
        high portc.0
     wend
       low portc.0
    Aug 2010
    Maryland, USA
    that line turns the interupt on, or enables it. there must be a simular line like INT_DISABLE maybe to turn it off.
    turn it off when the while loop is true, or when under Tx control. then turn it back on when Tx control is over.
    -Bert
  27. #627
    Nov 2009
    Fitchburg, Mass
    Default That's what I tried.
    For some reason disabling interrupt during the WHILE loop did not work. I could have done
    something stupid.
    What I want to know is where is the list of "blocking" commands. I do not see such a list in
    my PBP book. For example, is COUNT a blocker?
    Here is what I coded immediately after main:
    checkchannel3:
    'worked with four AA batteries pack. Radio receiver puts pulses
    switchtoPIC = 2
    @ INT_DISABLE TMR1_INT
    high portc.0
    wend
    low portc.0
    Ken
  28. #628
    Ken, can you give us a bigger snippet?
  29. #629
    Nov 2009
    Fitchburg, Mass
    Smile Seems litte different than the HPWM technique
    I took my interrupt driven car to the gym this morning. It behaved about the same as my old HPWM design. When going slowly it just barely made the left turns at the corners. It did seem to go straight with less wiggle, but it still hit the wall occasionally.
    It appears that the problem is reaction time. My delving into an interrupt driven system was motivated by the guess that randomly (in time) changing the HPWM command might be confusing the electronic speed control. On this account I detect little difference.
    Another reason for regularly timed SONAR triggers was to take advantage of PID control. I have not coded that experiment. I am not convinced quicker reaction time will result.
    I partially solved the TOGGLE problem by inserting the following code right after 'main:'. This system does not toggle control between PIC and RC, but it does stop (Brake) the car when the radio transmitter is turned ON. It is not a nice picture - a 75 year old man running around a gymnasium trying to tackle an out-of-control RC car.
    The code samples channel3. This is the steering PWM signal from the car's radio receiver. There are pulses on that line as soon as the transmitter is activated.
    switchtoPIC = 2
    WHILE switchtoPIC >= 2
    COUNT channel3, 65, switchtoPIC
    WHEELS = Brake
    WEND
    I am not sure what to do now. The reaction time seems quick enough on the bench.
  30. #630
    Nov 2009
    Fitchburg, Mass
    Default Serious problem...
    In order to make sense of interrupt driven controls I need to know which PBP commands are 'blocking'. Why? During the blocking time no PWM pulses and no SONAR triggers are being emitted.
    Ken
  31. #631
    Nov 2009
    Fitchburg, Mass
    Default Infrared distance detector?
    Back a couple weeks one of you mentioned using infrared distance detector instead of a sonar detector. How do I find that posting? What was he product's name? How does it work? Or am I mistaken.
    Ken
  32. #632
    Ken, the one I suggested earlier http://www.acroname.com/robotics/parts/gp2y0a21yk_e.pdf... well, I just read the timing chart on page 4, and believe it or not, this infra red sensor is slower than your sonar! But, the good part is, you wouldn't have to wait for one to finish, before sensing the other. It would be nice to find a faster response sensor, if possible though, to allow your car to measure under 20 ms (at least for the side).
    Here's a little bit about how they work http://www.societyofrobots.com/robot...p?topic=7991.0
  33. #633
    Interrupts are the way around blocking commands. With interrupts, you can be listening for 4 separate pulses in, while pulsing 4 separate pulses out, while listening for the sonar ping, and blinking a few led's, etc, etc. With PicBasic commands alone, you are still stuck at pulsin, listening for a single pin for x duration. Don't get me wrong, blocking sounds so bad, but what it really does, is give the user a simple way do some complex things, with a single line of code. And without having to read about 50 extra pages of the data sheet. This is one of the best features of PicBasic. But there is a time for interrupts. Pulsin, Pulsout, PWM, serin, serout, freqout, count, debug, debugout are a few blocking commands.
    That said, they will not block an interrupt. An interrupt, does what it does best. It butts in an interrupts, gets out, and then whatever PicBasic command it was in the middle of completes.
  34. #634
    Up to this moment I have not seen any specifications of the cars.
    What speed they reach, how fast thay accelerate and how fast do they stop.
    If youhave this figures then you may do the calculations about reaction time and maximum speed to reach in order to hit the brakes in time, before crashing on the walls.
    Looking back at one of the examples you gave of this idea (from kind of the beginning), Wall Racers used no interrupts. It was all done using basic statements, and blocking commands. These cars seem to go a bit slower than yours though, if I were to guestimate. Is the accuracy and speed they have in this video what you are aiming for? I think I saw them hit a wall here and there ... maybe. I am guessing around 4 to 5mph in the video?
    Here is the code they used in PicAxe Basic.
    ' WALLRACERS By Frits Lyneborg
    ' Right turns on the track must be gentle (this code does not skid/slide on them), left can be hard (skid/slide is build in)
    ' <"left"> opposite just <left> in the remarks means that wheels are turning left, but direction is backwards, so "left" is actually moving right
    symbol trigright = 0 ‘ Define output pin for Trigger pulse
    symbol trigfront = 1 ‘ Define output pin for Trigger pulse
    symbol echoright = 7 ‘ Define input pin for Echo pulse
    symbol echofront = 6 ‘ Define input pin for Echo pulse
    symbol rangeright = w1 ‘ 16 bit word variable for range
    symbol rangefront = w2 ‘ 16 bit word variable for range
    symbol oldrangeright = w3 ‘ 16 bit word variable for range
    symbol differencerangeright = w4 ‘ used to calculate how hard a turn is
    symbol frontfreetostopreverse = w5
    symbol turnon = 7 ' the relay that if on makes the car turn to one side
    symbol steerto = 6 ' the relay that if on turning is on, then decides the direction
    symbol stopon = 5 ' the relay that if on makes the car stop
    symbol forrev = 4 ' the relay that if on and is not on stop makes the car reverse
    symbol frontdanger = 200 ' At what point should we realize we are getting too close? (note that breaking takes a lot, so this should be much higher than the real distance)
    symbol frontfreetostopreversesetup = 201' must be higher than "frontdanger" - higher value means more backing out after close encounters
    symbol frontfree = 350' set higher to turn earlier when something is in front, and get less skid-turning, but more likeliness to miss sharp right turns
    symbol desiredtrack = 100
    'symbol innertrack = 50
    symbol outertrack = 150
    high stopon
    wait 5
    low stopon
    gosub puls
    gosub skidandreverse
    if rangefront < frontfree then 'turn left as there is something ahead in front
    high turnon low steerto
    goto main 'this is second priority above all loop till this is secured
    end if
    '' Normal drive to the right - we are too far away from the lane, so turn. This code contains no right-slide-turn for cool long right turns without slides to give more of a race-feeling oposed to zig-zag and robot-behaviour, so space must on thr track be higher than turning-radius in front of right turns - or the car vill turn left and miss the right turn.
    if rangeright > outertrack then 'turn right as we are too far away
    high turnon  high steerto
    end if
    ' Now we know that there is nothing closer than (frontdanger and) frontfree - and we are on track - so let's keep on track
    ' First check if we are on the right path and have a positive development.
    ' If so, then keep us there by straightening up wheels that might be turned
    low turnon  low steerto  ' drive straight forward as we are on the wrong side of desired track, but we are moving the right direction
    end if
    end if
    ' Then see if we are moving away from the good path and do something about it if so.
    high turnon  high steerto  'turn right as we are in the outer lane and getting away
    end if
    if rangeright < desiredtrack and oldrangeright > rangeright then
    high turnon  low steerto  'turn left as we are in the inner lane and getting closer
    end if
    yankright:' there was an empty space to the right. Skid right to be sure we are turning if it is a turn in the track
    '''''''''' Skidsecure start
    pause 25' wait short for the car to give a small yank to the left before reversing.. all to start a skid turn to the right side
    '''''''''' Skidsecure end
    high forrev  'set in reverse gear
    Skidright:
    b0 = 0
    do
    gosub puls
    b0 = b0 +1
    loop while rangefront > frontfreetostopreverse and rangeright > outertrack and b0 < 20
    'dildo:
    'high stopon goto dildo
    low forrev  'set in forward gear
    pause 300
    rev:
    frontfreetostopreverse = frontfreetostopreversesetup
    keepreversing:
    frontfreetostopreverse = frontfreetostopreverse - 3' making sure we are not backing and reversing and going nowhere, as we have a wall behind us
    if frontfreetostopreverse < 50 then
    gosub stuckerror
    end if
    gosub puls
    if rangefront < frontfreetostopreversesetup then
        if rangeright < desiredtrack and oldrangeright < rangeright and rangefront > frontdanger then
        low turnon  low steerto  ' drive ahead as we are on the wrong side, but we are moving the right direction and we are not too close
        end if
        if rangeright > desiredtrack and oldrangeright > rangeright and rangefront > frontdanger then
        end if
        if rangeright > desiredtrack and oldrangeright < rangeright and rangefront > frontdanger then
        high turnon  low steerto  'turn left (reversed) as we are in the inner lane and getting closer
        end if
        high turnon  high steerto  'turn right (reversed) as we are in the outer lane and getting away
        end if
        goto keepreversing
    end if
    high turnon low steerto  'turn "left"
    skidandreverse:
    if rangefront < frontdanger then ' too close, reverse out of trouble!
    gosub reverseoutoftrouble
    goto main ' this is first priority above all - loop till this is secured
    end if
    puls:
    pulsout trigright,2 ‘ produce 20uS trigger pulse (must be minimum of 10uS)
    pulsin echoright,1,rangeright ‘ measures the range in 10uS steps
    pulsf:
    pulsout trigfront,2 ‘ produce 20uS trigger pulse (must be minimum of 10uS)
    pulsin echofront,1,rangefront ‘ measures the range in 10uS steps
    pause 10 ‘ recharge period after ranging completes
    stuckerror:
    high stopon
    low forrev
    low steerto
    low turnon
    dadaa:
    goto dadaa
  36. #636
    Nov 2009
    Fitchburg, Mass
    Default Good thinking....
    You are right about the specs on the RC cars. I do not know that they officially exist. My car weights exactly four pounds. Has good rubber tires with plenty of friction against the gymnasium floor. I have been told that it is good for at least twenty miles per hour, but I have no means to verify it. The car is a HPI-Racing 1/10 Scale, 4 wheel drive, Sprint model.
    Regarding the blocking commands. All I want to know is which ones block TMR1 and hence TMR1 based interrupts? Judging from my LOGIC TOOL images PULSIN blocks. True?
    Ken
  37. #637
    I thought I read somewhere that most of the commands which involve time, like Pulsin, Pulsout, etc, use timer1. But I can't find anything documenting that. Maybe someone can correct this for me? I did a little testing, and if you put your 20 ms timer on Timer2, it will be unaffected by pulsout, and I expect pulsin as well. These blocking commands DO NOT block an interrupt. For instance, you can have a pause 10000 in your main, while an interrupt gives you a heartbeat LED indication every second. But they will interfere if they are trying to load the same timer with a value.
    EDIT: Turns out I was way off base here. Here Darrel corrects me:
    The only PicBasic command that uses a timer is HPWM, which uses Timer2.
    No PBP commands use Timer1 unless you tell it to.
    And all PBP commands are blocking (while they execute).
    They might interface with harware peripherals that are doing other things at the same time, but the statements themselves are blocking.
    As you pointed out though, they don't block interrupts.
    And it's the commands that do software based timing that get disturbed by the interrupts.
    PAUSE, PULSIN/OUT, RCTIME, SEROUT/IN(2) etc.
    They stop keeping time while the interrupt code executes, so all that time gets lost.
    When using interrupts, you should use Hardware Timers to do things like PAUSE or PULSIN, and the USART instead if SEROUT/IN(2).
    And when not using interrupts, use the easier versions (PBP), or still use the hardware which are the NON-BLOCKED functions.
    You can do PULSIN with the CCP module at the same time you're sending serial data to a PC without any interrupts.
  38. #638
    Nov 2009
    Fitchburg, Mass
    Default Yes, Frits' code was not interrupt driven
    You are correct. I got the whole idea from Frits. I have learned some since then.
    1. His cars were 1/12 scale toy level cars. They are not fast by RC standards. They have only bang bang steering and wheel control. They are small. They do not have enough room for much electronics to be added. Frits removed the RC receiver. I tried the Frits thing on a 1/10. I was not successful. The 1/10 car is much faster than the 1/12 car. This video shows the difference.
    I have been asking for suggestions for a 'game' that can be played with the 1/10 Toy level cars. They are $50 each vs $200 for a model level car.
    I thought up the 'swarm the teacher with the light bulb' game to be played with multiple light sensing diodes on the roofs of the cars. I have been diverted by this idea of interrupt driven model level control.
    Thanks for everything.
    KEn
  39. #639
    Aug 2010
    Maryland, USA
    Ken, Sorry, I'm not very good at thinking up games. Follow the light sounds like fun to me. I have a lot of things I want to comment about your current effort, but time won't let me right now. I will tonight. Let me say this though, I think you are on the right path.
    I wonder if you can do some testing for us. I want to help you get better control over the car, but need some parameters.
    1. How close can you get to a wall at top speed and still be able to execute a turn?
    2. How close do you want to be to the right wall?
    3. At what percentage of speed can you still make a hard left without the car skiding?
    4. If the Tx is NOT on, will there be any pulse from the RX?
    Maybe you can put some tape lines on the floor and film that section of the floor to capture speed and distance from the wall. Of course this will be under manual control, So we will also get to see your reflexes-lol
    I for 1 believe you can get the car to go much faster and be WAY more accurate!!
    -Bert
  40. #640
    Nov 2009
    Fitchburg, Mass
    Default Can't get to the gym for a couple of days.
    My gymnasium has no electricity. Need bright sunny day to take video. Tomorrow is Thanksgiving and the following day is occupied by family stuff.
    The model car does not skid. The toy car does.
    In my older model level car, the receiver created no pulses on channel3 input when the transmitter was off. My newer model level car, somehow has noise on that line. The circuits are the same. I have not been able to figure out the difference.
    I started trying to code my 1/10 toy car to do a skid turn then I realized that it's real problem is the subtle issue of staying parallel to the wall. I think you have a real good idea asking me to see whether I can control that car with its RC inside my gym.
    Thanks for the encouragement. I have been bumping my head for a while.
    Ken
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
