PBP projects for R/C models - Page 5
Results 161 to 200 of 772
Threaded View
  1. #24
    How does HPWM work when the pulses are set for 50 per second (20msec) period and the code loops more quickly than that. ie the next HPWM command happens before the last one got a chance to count out the 20 msec.
    Is it obvious if I study the ASM code? I wish I could find a compact library so I could read ASM easily.
    Ken
    I don't know if I understand the question. To set HPWM at 20ms, you need to slow your pic down to 0.5 Mhz (if you are using the hardware PWM). But then you only get about 32 different settings from 1ms to 2ms. Maybe you are asking what happens to the servo when you send the 1.5ms pulses quicker than 50 hertz?
    How are you doing it Ken?
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
