PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Smile My 32bit Whackers arrived today
    I received two 32bit Whackers today.
    Can I attach them to my PICkit 2 Programmer?
    Will the following get me started?
    http://www.schmalzhaus.com/UBW32/
    New project. 1/10 scale toy car bang-bang controls. Follow the bright light code. Three PHILMORE 10807 photo cells sticking out the top where the taxi sign belongs aimed - depending on the10807's reception pattern - forward, leftish and rightish. (I image 45 to 60 degrees from straight ahead.)
    If the car can see the light at all, then it can follow it. If the car can not see the light it must turn a 360 until it finds it.
    I see this as the HELLO WORLD of a teach-the-teacher robocar professional development seminar. Maybe I'll use the new Whacker because it has embedded development code. Maybe the PIC16F887.
    Your thoughts?
    Ken
    Yes, jumper J5 will accept your PicKit2, so you can program the device. You should only have to do this about once. All other upgrades of firmware can be handled though the StickOS, using the USB cable.
    I hadn't noticed before, but it looks like it is preloaded with some other "language". I think you are better off with StickOS though. So I would dowload it from here: http://www.cpustick.com/downloads/St...v1.80c.elf.hex and load it into the UBW32 with your PicKit2.
    And follow the StickOS documentation, located here: http://www.cpustick.com/downloads/stickos.v1.80.2p.pdf
    All above located on this site: http://www.cpustick.com/downloads.htm
    http://www.scalerobotics.com
    Nov 2009
    Fitchburg, Mass
    Thumbs down Help
    scalerobotics, I thought that you suggested that J5 will work with the PICKIT USB connector.
    I can not find J5 on the board. I can find J6 but not J5. I downloaded the .pdf file which is a picture of the board. It is sooo messy that I can not find J5 on it either.
    HELP.....
    KEn
    Nov 2009
    Fitchburg, Mass
    Default I found it
    J5 is the tail end of the board...
    Hmmm.
    KEn
    Nov 2009
    Fitchburg, Mass
    Default Now what??
    My PICkit2 Programmer makes the blue LED glow. When I ask for a READ it presents me with a GUI that claims voltage error and the LED goes out.
    Is there a similar document to the MICROCHIP explanation of the PICkit 2 hardware?
    The documentation for this PIC32 chip is 631 pages. That is more than the 500 pages of documentation referenced by the young guy in the video.
    What now, coaches?
    Ken
    Nov 2009
    Fitchburg, Mass
    Unhappy Are you all referring to the PICkit2 hardware only?
    The six pin USB connector that I am using is called a PICkit2.
    Are you all saying that you use that connector, but then use MPLAB IDE programmer for to talk to the PIC32 Whacker? I assumed you were using the PICkit2 Programmer.
    Confusion reigns.
    Ken
    Nov 2009
    Fitchburg, Mass
    Default Not so confused now.....
    I rediscovered in PICkit2 Programmer the DEVICE FAMILY pull down. There is an entry for the PIC32MX460. I selected that. Low and behold....
    Ain't life grande.
    Ken
    Ken, I am sorry. I gave you the wrong firmware file. That one was meant for a UBW32 with HID Bootloader which apparently came with the UBw32 before we wrote over it.
    Soooooooooo
    Here is what I can only believe to be the right file. If this does not work, we will have to ask for higher help.
    I wish I had the same hardware here, and would not have led you astray.
    Here is the file:
    Nov 2009
    Fitchburg, Mass
    Default I have a second PICWhacker
    In the world of Hi-Tech I always purchase a second one - just in case.
    If I were to switch, what do you suggest be my actions?
    Ken
    Ken
    That's right, I sort of forgot about the second one...
    But it does not sound like you tried the firmware I just sent you. As one last try, I would have you stick with the one were working on, and try the firmware I just sent in the previous reply.
    But your right, if that does not work:
    Switch to the untouched one. Download the microchip driver here: http://www.sparkfun.com/datasheets/D...C/UBW32inf.zip and install it into your PC. And only plug the usb cable into it. See if you get a "new hardware detected" message.
    Run the HID Bootloader executable from microchip http://www.cpustick.com/downloads/HIDBootLoader.exe , and see if it can find your UBW32. Then select the first firmware I sent you. This one: StickOS for Microchip PIC32MX4-F512L UBW32 Board Bootloader (v1.80) (.HEX, UBW32 HID bootloader image) with the long name. Let the microchip bootloader try to load the firmware into the untouched one (not even using your PicKit2).
    Let me know how it goes.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
