It doesn't work because you're using a logical operator instead of the bitwise operator.
pincode1 = (PORTB & $0F) would return the right value.
Logical operators can only return true or false.
I have new coding problem, using TMR0 I do not understand........put simply
The inclusion of any code in the sub-routine at nowt: causes whole to fail?Code:loop1: if intcon.2 = 0 then loop1 intcon.2 = 0 clicks=clicks+1 if clicks >=1900 then clicks=0 high pin11:pause 100:low pin11 'Flash LED for 10th of second secs=secs+1 endif if secs>=5 then high pin10:pause 100:low pin10 gosub nowt secs=0 'Reset secs endif goto loop1 end nowt: return But fails if gosub nowt endif goto loop1 end nowt: secs=0 'Reset secs return
Can you post the whole code, using code tags, so we can see how everything is setup? TMRO is "normally" set to trigger an interrupt handler so I am not sure what you are doing with what I see posted.
Might just be running out of time???
Hello....All of the code is shown below......
Code:'**************************************************************** '* Name : TIMER01.INC * '* Author : Michael Denton * '* Notice : * '* Date : 27/03/2010 * '* Version : 1.0 * '* Notes : * '**************************************************************** cmcon = %00000111 'Make portA all digital I/O otherwise ADC intcon = %10110000 'R/W Reg Bit2 is T0IF TMRO overflow bit 'must be reset in software option_reg = %10010000 'prescaler for TMR0 set at 1:1 vrcon = %00000000 'Turn off reference voltage eecon1 = %00001111 'EEPROM data register '======================================================= PIN6 VAR PORTB.0 ' Rename all port names with physical PIN number PIN7 VAR PORTB.1 ' Makes it easier to wire up PIN8 VAR PORTB.2 PIN9 VAR PORTB.3 PIN10 VAR PORTB.4 PIN11 VAR PORTB.5 PIN12 VAR PORTB.6 PIN13 VAR PORTB.7 PIN17 VAR PORTA.0 PIN18 VAR PORTA.1 PIN1 VAR PORTA.2 PIN2 VAR PORTA.3 PIN3 VAR PORTA.4 '======================================================= INPUT PIN2 ' input pin6 ' input PIN7 ' input PIN8 ' input PIN9 ' input PIN12 ' input PIN13 ' output pin1 ' output pin3 ' output pin10 ' output PIN11 ' OUTPUT PIN17 ' OUTPUT PIN18 ' '================= Check functionality ========================== m var word :n var word clicks var word: secs var word ' =============================================================== pause 1000 'Do nothing for a while main: loop1: if intcon.2 = 0 then loop1 'TMR0 must be enabled to get out of this loop1 intcon.2 = 0 clicks=clicks+1 if clicks >=1900 then clicks=0 high pin11:pause 100:low pin11 'Flash LED for 10th of second secs=secs+1 endif if secs>=5 then high pin10:pause 100:low pin10 gosub nowt secs=0 'Reset secs endif goto loop1 end nowt: 'm=m+1 ' Why does this one extra instruction cause Pin11 High ' And cause progam to FAIL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! return
Maybe this will help. Scroll down to post #125 to start.
http://www.picbasic.co.uk/forum/show...t=12677&page=4
In your code, where does the value of "m" come from?
And... Look at using code tags when you post code. Makes it easier to read...
http://www.picbasic.co.uk/forum/misc.php?do=bbcode#code
