DTMF and PIC for Remote Control
Results 1 to 20 of 20
Threaded View
  1. #10
    Sep 2009
    Default DTMF decoder
    Hello....All of the code is shown below......
    '*  Name    : TIMER01.INC                                          *
    '*  Author  : Michael Denton                                        *
    '*  Notice  :                                    *
    '*  Date    : 27/03/2010                                                *
    '*  Version : 1.0                                                          *
    '*  Notes   :        *
    cmcon = %00000111 'Make portA all digital I/O otherwise ADC
    intcon = %10110000 'R/W Reg Bit2 is T0IF TMRO overflow bit
                       'must be reset in software
    option_reg = %10010000 'prescaler for TMR0 set at 1:1
    vrcon = %00000000 'Turn off reference voltage
    eecon1 = %00001111 'EEPROM data register
    PIN6  VAR PORTB.0   ' Rename all port names with physical PIN number
    PIN7  VAR PORTB.1   ' Makes it easier to wire up
    PIN8  VAR PORTB.2
    PIN9  VAR PORTB.3
    PIN10 VAR PORTB.4
    PIN11 VAR PORTB.5
    PIN12 VAR PORTB.6
    PIN13 VAR PORTB.7
    PIN17 VAR PORTA.0
    PIN18 VAR PORTA.1
    PIN1  VAR PORTA.2
    PIN2  VAR PORTA.3
    PIN3  VAR PORTA.4
    INPUT PIN2   '
    input pin6   '
    input PIN7   '
    input PIN8   '
    input PIN9   '
    input PIN12  '
    input PIN13  '
    output pin1   '
    output pin3   '
    output pin10  '
    output PIN11  '
    OUTPUT PIN17  '
    OUTPUT PIN18  '
    '=================  Check functionality      ==========================
      m var word :n var word
      clicks var word: secs var word
      pause 1000 'Do nothing for a while
      loop1:
      if intcon.2 = 0 then loop1  'TMR0 must be enabled to get out of this loop1
      intcon.2 = 0
      clicks=clicks+1
      if clicks >=1900 then
      clicks=0
      high pin11:pause 100:low pin11  'Flash LED for 10th of second
      secs=secs+1
      if secs>=5 then
      high pin10:pause 100:low pin10
      gosub nowt
      secs=0 'Reset secs
      goto loop1
      nowt: 'm=m+1 ' Why does this one extra instruction cause Pin11 High
    ' And cause progam to FAIL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  1. 8870/dtmf + Pic?
    By PIC_hobbyist in forum General
    Last Post: - 5th March 2013, 01:19
  2. PIC RS-232 to control Access database?
    By Angus Anderson in forum General
    Last Post: - 29th July 2007, 13:26
  3. Replies: 2
    Last Post: - 31st July 2006, 16:06
  4. Problems with DTMF Generatiom
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 21:12
  5. Shaping DTMF Signal out of PIC
    By charudatt in forum Schematics
    Last Post: - 8th October 2003, 10:09
