old chestnut, 18f2550, fuses, osc's leds...
Results 1 to 5 of 5
    Default old chestnut, 18f2550, fuses, osc's leds...
    Ok 4mhz crystal, 18f2550, led...
    basic program is simple enough
    define osc 16
    ADCON0 = 0
    CMCON = 7
    trisa=0
    loop:
    porta=255
    porta=0
    goto loop
    and these fuses are in a p18f2550fuses.inc
    	CONFIG PLLDIV = 1                 ; set for 4mhz to pll
    	CONFIG CPUDIV = OSC4_PLL6 ; set for 16mhz cpu core
            CONFIG USBDIV = 2               ; usb=pll/2
    	CONFIG FOSC = HSPLL_HS
    	CONFIG FCMEN = ON
    (other fuses omitted)
    thing is i can set the define osc to whatever i want, the speed the led flashes at is not changed, i thought the define osc was used to re-compile the delays etc in the pause routines? (amongst other things)
    why do i not see a speed change in the led when i change it, why do i not see one second on and one second off, its more like a 1/4 of that irrespective of setting of define osc
    I can set the fuses for the chip by hand at burn time, so i know the fuses are burned correctly as if i do set them by hand, same result, also if i set them wrong i can get faster flashing, but i cant get it to slow to 1hz irrespective of cpudiv/osc etc, i seem to get 2/4/8hz
    MPASM is case sensitive.
    change...
    define osc 16
    -- to --
    define OSC 16
    Omg...........
    isn't case sensitivity a swine at times...
    not as much as usb connectivity.....
    which i still have not mastered.
  1. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  2. 18F2550 config fuses, is my setup OK?
    By peu in forum mel PIC BASIC Pro
    Last Post: - 28th July 2006, 03:48
  3. controlling leds with the switches
    By ilteris in forum mel PIC BASIC Pro
    Last Post: - 12th October 2005, 21:02
