PWM with 12F675
Results 1 to 6 of 6
Thread: PWM with 12F675
    Dec 2008
    Ploiesti, ROMANIA
    Default PWM with 12F675
    Hello everyone !
    Since I bought a lot of 12F675, I think to try another schematic : lighting LED using software PWM. I wrote this code ; when power on the PIC, the LED give 20 % of light ; if buton is pressed, the LED lights 40%, then 60%, then 80% and, finally, 100 %. In my dreams ...because in practice that don't work like I wish. I know that code is not good...so, please, help me with some suggestion. Thanks in advance.
    The variable used in the CASE is specified in the SELECT statement.
    The CASE itself only needs the value to compare ...
    select case counter
      case 1
        brightness=50
        pwm led,brightness,cycle
      case 2
        brightness=100
    ... etc.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You Mr. D ! It's no e-beer on www enough for You as a gift !
    Yes, indeed, I am wrong with sintax...but still don't work proper.
    Maybe because of my poor english...
    So :
    -power on, LED lighting 20% (till power off or push button)
    -push button, LED lighting 40 % (same as previous)
    -push button, LED lighting 60% (same as previous)
    -push button, LED lighting 80% (same as previous)
    -push button, LED lighting 100% (same as previous)
    -push button, LED off till power on again or push button.
    It is possible ?
    Don't worry about your English.
    It's the BASIC Language that's subject...
    Let's see ... power-on 20%, push a button 40% .. etc.. etc... off after 100%
    brightness = 51
        WHILE buton
        WEND
        if brightness != 255
            brightness = brightness + 51
            brightness = 0
        WHILE !buton
        WEND
    GOTO Main
    Last edited by Darrel Taylor; - 28th October 2009 at 16:52. Reason: modified to match the power-on request
    Dec 2008
    Ploiesti, ROMANIA
    Mr.Darrel, You are my guardian angel from far and away !!!
    Works verry good. Thank You from the bottom of my heart !
    P.S. : " if brightness != 255 then".
    You're welcome fratello,
    Oops, that's what I get for not compiling it.
    <br>
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. PWM 'channels ...what's that all about then!
    By HankMcSpank in forum General
    Last Post: - 23rd April 2009, 16:49
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 07:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 00:26
