what's wrong 16F877A simple code?
Results 1 to 12 of 12
    Question ...
    Are the Brake and the Motor supposed to run at the same time?
    ;constants
    brake Con %00000011
    stmot con %00000000
    runmot con %00000001
    The only way I can see that your symptoms can happen is if the PIC gets reset at the point where it applies the brake.
    Possibly from over current (Brake+Motor).
    The code itself will not do that.
    Good point...I think you are correct. After I wrote my previous post, I was thinking about possibly a brown out condition where it would come up in reset mode. I will check it out and post back.
    Thanks!
    Nick
    Talking
    Darrel you are correct!! The brake was hosing the MCU....even though I have 1K resistors...strange I will need to dive more into the hardware.
    Thanks for your help!!!
    Nick
    Quote Originally Posted by Macgman2000 View Post
    Hmmm, must be one of those Canadian brakes (Hoser).
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. LCD Showes Some Wrong Letters
    By sbobowski in forum General
    Last Post: - 23rd September 2008, 20:15
  3. Making Program Code Space your playground...
  4. hopefully simple code
    By hoyles in forum General
    Last Post: - 9th September 2005, 00:24
  5. Problems with 16F877A code
    By NightHawk2 in forum mel PIC BASIC Pro
    Last Post: - 20th August 2003, 02:36
