what's wrong 16F877A simple code?
Results 1 to 12 of 12
    Wink Harware issue ??? forgotten action ???
    1) If your opto- transistor emitter has no load to ground , no chance it works properly.
    add to that you are supposed to have a HIGH level @ input when there's nothing between photodiode and and photo transistor.
    2)
    checkopt:
    if portb.2 = 1 then
    portc = runmot
    goto checkopt
    This is an endless loop that DOESN'T CHANGES ANYTHING !!!! if you reach required position ...
    I do not think you wanted that ... ( stopping motor is doing something ... don't you think ??? so ... )
    Question
    thanks for the feedback. Faulty ground on optical switch is not the problem. Like I said I can take out a portion of the code and the optical switch works well..... I rewrote the code yet again and see the same issue. I realize it is not elegant, and it should dwell in each loop until the correct cadence....but what I see is it vectors outside of the loop and enables the start switch which is deliberated left out of the normal loop....it is only used once upon start up to kick start the checkleaf and checkopt loops. see below.
    @ device pic16F877A, HS_OSC, LVP_OFF, WDT_OFF
    ; @ Device pic16F877A, HS_OSC, BOD_OFF, PWRT_ON, WDT_ON, PROTECT_OFF
    DEFINE OSC 20
    ;set ports to output
    TRISA = %00000000
    TRISB = %00000111
    TRISC = %00000000
    TRISD = %00000000
    ; analog portA direction
    ADCON1 = 7
    CMCON = 7
    ;constants
    brake  Con  %00000011
    stmot  con  %00000000
    runmot con  %00000001
    ;variables
    timeout  var byte
    ;initialization
    portc = stmot
    HomeStart:
           if portb.0 = 0 then
              portc = runmot
              goto checkleaf
           goto homestart
    checkleaf:
           if portb.1 = 0 then
              portc = brake
              portc = stmot
              goto checkopt
           goto checkleaf
    checkopt:
          if portb.2 = 1 then
             portc = runmot
             goto checkleaf
             goto checkopt
    Would you like some Marinara to go with that spaghetti?
    Welll, here's my interpretation of your program.
    HomeStart:
      Wait for button press on RB0
      When pressed, start motor
    checkleaf:
      Wait for Leaf switch on RB1
      When triggered, apply brake for .5 sec. then stop motor
    checkopt:
      Wait for Optical interrupter on RB2
      When triggered, start motor, and go back to checkleaf:
      Never ending loop
    Question
    Yes, not elegant at all but it should run. The never ending loop is supposed to tell me whether it got to this point and it should dwell there.
    It was supposed to go back originally to checkleaf but that seemed not to work either. The end result is still the same, It would get to the never ending loop and fall out going back to homestart which should never happen since I trap it in the lower loops.
    Just wondering if somehow it is being vectored back to the beginning of the code or what. I turn off analog channels, comps, interrupts are not used, watchdog is off....
    I guess I am having one of those days.
    Nick
    Why do you think it's somehow jumping where it shouldn't?
    Are you running it on a simulator?
    The only indication of what the program is doing is a motor running.
    And according to your program it's going to be doing a LOT of running, with no way to stop it.
    Question
    I know it jumps out and goes back to homestart because that button when pressed retriggers the sequence of loops over again when it shouldn't. If I am stuck in an endless loop at checkleaf, homestart shouldn't do anything after the first time it falls through the code upon startup correct?
    As far as motor running, the motor runs only when homestart is triggered, it goes through homestart (1 time upon start up of MCU), then when I hit checkleaf it works correctly (since it sits in a loop)....but after that the motor is off at checkopt and does not sit in that loop. The motor stays off until I hit homestart again (which should never happen except on power up).
    I may start from scratch....I don't know. Any reference code to get started would help since I seem to be stuck in a loop mentally
    Nick
    Question ...
    Are the Brake and the Motor supposed to run at the same time?
    ;constants
    brake Con %00000011
    stmot con %00000000
    The only way I can see that your symptoms can happen is if the PIC gets reset at the point where it applies the brake.
    Possibly from over current (Brake+Motor).
    The code itself will not do that.
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. LCD Showes Some Wrong Letters
    By sbobowski in forum General
    Last Post: - 23rd September 2008, 20:15
  3. Making Program Code Space your playground...
  4. hopefully simple code
    By hoyles in forum General
    Last Post: - 9th September 2005, 00:24
  5. Problems with 16F877A code
    By NightHawk2 in forum mel PIC BASIC Pro
    Last Post: - 20th August 2003, 02:36
