want to make pic goes sleep and wake it when i push abottom
To do that you need to re-wire your circuit and use portB.0 as your push-button detector. (now you are using portB.0 for I2C communication)
Once you have done that, you will need to learn how to use and activate the interrupt on portB.0, because this will wakeup your sleeping MCU.
I strongly suggest you to look at Darrel Taylor instant interrupt and experiment a while with it and then use it to improve your program.
Have a look @ http://darreltaylor.com/DT_INTS-14/hello.html
Al.
