HELLO AND THANK U EVERYONES IS HELPING ME I DID IT LAST NIGHT AND I TRYED SO IT WORKS GREAT NOW IM USING F84 AND 24C02 SO I WILL DP IT FOR THE DOORLOCK AND THE EEPROM WILL BE IN THE KEY HERE IS MY CODE I IDDED SOME SLEEP AND BUZ SO MAYBE SOMEONE WILL NEED THIS CODE IT WORKS GOOD FOR LOCKS ALL WAT IM LOOKIN FOR NOW IS HOW TO WAKE UP PIC WHEN IT GOES SLEEPEEPROM 24C02 SHOULD BE THE SAME ADDRESS AND DATA STORED THIS $14,$21,$47,$56,$02,$11,$22,$33 SO U CAN CHANGE THEM BOTH OR CHANGE THE ADRESS OR WATEVER IMNEW IN PBP . THANK U EVERYONES FOR HELPCode:Include "modedefs.bas" define osc 4 PORTA = 1 PORTB = 0 KEY VAR BIT [7] KEY1 VAR BIT [7] ADR VAR BYTE COD VAR BYTE SYMBOL SCLK = PORTB.0 SYMBOL SDAT = PORTB.1 SYMBOL BUZ = PORTB.2 SYMBOL LED1 = PORTB.4 SYMBOL RELY = PORTB.3 SYMBOL STRT = PORTA.0 SYMBOL UNLCK = PORTA.1 SYMBOL BLCK = PORTA.2 START: IF STRT = 0 THEN GOSUB SCAN IF BLCK = 0 THEN GOTO ANGRY IF STRT = 1 THEN HIGH LED1 PAUSE 100 LOW LED1 IF STRT = 0 THEN GOSUB SCAN IF BLCK = 0 THEN GOTO ANGRY PAUSE 100 ENDIF GOTO START SCAN: FOR ADR = 0 TO 7 I2CREAD SDAT,SCLK,$A0,ADR,[KEY] READ ADR,KEY1 IF KEY != KEY1 THEN GOSUB ERROR IF (KEY == KEY1) THEN COD = 1 IF RELY = 1 THEN SEROUT LED1,N2400,["ITS UNLOCKED HERO"] NEXT ADR PAUSE 10 RELY = COD PAUSE 2000 LOW RELY RETURN ANGRY: SOUND BUZ,[102,75] HIGH LED1 PAUSE 1000 SLEEP 30 NOP SOUND BUZ,[102,75] PAUSE 1000 GOTO START ERROR: LOW RELY SOUND BUZ,[102,75] PAUSE 1000 HIGH LED1 PAUSE 1000 LOW LED1 PAUSE 1000 SOUND BUZ,[102,75] HIGH LED1 SOUND BUZ,[102,75] SLEEP 10 GOTO START END DATA @0,$14,$21,$47,$56,$02,$11,$22,$33
