Your code will go back to Main after first blink, and then wait again for a command as it see Serin, which wait forever until you send him data.
look into adding a background timer if you want the led to blink, or use a timeout so the Serin will end if no new char is received.
also, some indent in code help to see more clearly
Code:main: serin serial,T2400,[1],b0 for b1=0 to b0 high led pause 200 low led pause 200 next b1 pause 2000 goto main
