program of Melanie
Results 1 to 6 of 6
    Hi Jonas
    I've not looked at your program yet through lack of time...
    If you want to store in EEPROM, then the best and easiest is to save in the same (BCD) format as you are reading from the RTC. That way, you will remember that all operations, be they EEPROM or RTC are always in the same format.
    Only convert to a human readable format when you want interaction by a human (ie Display or Setting).
    Now, if you are saving to EEPROM, this raises another question - how often are you saving? Always remember that some EEPROMs only have a 100,000 WRITE lifetime... if you are saving every second, it won't be that long before you reach that limit.
    france
    Default rtc
    Good evening
    It is a program to test how backups are the data in the eeprom.
    And as can see the data is written partly in Hexa and others in Decimal
    I need your help
    Thank you
    May 2008
    Italy
    The data are stored in external EEPROM.
    But when I reread the eeprom hour, minute and second
    Are written in hexadecimal, while others are in decimal.
    Should he make the conversion before saving?
    Whatever format you will use data in eeprom will be saved in binary format!
    17 = $11 will be saved as %00010001
    26 = $1A will be saved as %00011010
    9 = $9 will be saved as %00001001
    0 = $0 will be saved as %00000000
    number from 0 to 9 are the same in both format decimal and hex.
    Al.
    france
    Hello
    I agree with you, but if I use a terminal to receive
    Data stored in the eeprom.
    I wanted to do it this way:
    29 October 09, ten hours unit time, unit ten months .
    d_heure = hour / 16
    u_heure = hour - (d_heure * 16)
    d_heure = d_heure + 48
    u_heure = u_heure + 48
    d_minute = minute / 16
    u_minute = minute - (d_minute * 16)
    d_minute = d_minute + 48
    u_minute = u_minute + 48
    thank you for your help
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
