Ok I am missing something......you posted a couple of posts ago the following....
So I came back with my design for a FET transistor supplying power as long as it takes to transmit an off command when you let go of the button. This should solve your issue. Especially since you have two different voltage sources, your N-channel FET would go between your common grounds, to essentially switch ground on or off. Just imagine it as a switch that cuts your circuit off at the ground side.Problem is that the Tx only gets power while the button is pressed once button is released, power is also removed from the pic. Is there any way I can achieve my goal using an capacitor or somthing at the output in the hardware as I dont seem to figure out an solution with software (Unless someone comes up with somthing I can try on my exsisting setup). I already tried using an 470uF at the output pin + replacing 1K wih an diode. I am having problem with timings now BUT flickering seems to have been absorbed by the capacitor. If possible any sugesstion about the cap values I can try to have instant responses by the receiver PIC?
If you use a 100uF cap at the + side make sure that there is a resistor in parallel with the cap that will discharge it when the FET cuts off ground.
Nick
