Alphanumeric leds&16f84
Results 1 to 4 of 4
    Feb 2005
    GREECE
    Default Alphanumeric leds&16f84
    Hello,
    I am searching to drive Alphanumeric leds( not lcd display) with 16f84.I do not know if it is possible!!
    Does someone have an idea or any project?
    Nikos
    Here's a sample for 7 segments... should point you on a solution.
    http://www.picbasic.co.uk/forum/show...&threadid=1044
    Feb 2005
    GREECE
    Dear Steve
    Iam talking about Alphanumeric leds.See attachment.
    o.k. this can be done by the same method that i've post to you, for the same code example here's a link that provide you also the schematics. in this case, it will be a bit more easy to figure it out.
    What you have to do is to create a pattern with your PORT output to create every character you want to produce.
    Here's the link on the Melabs website. Choose Counter.zip
    http://www.melabs.com/resources/samples.htm#submitted
    you'll have to work a bit on that....
  1. Alphanumeric lcd display suppliers
    By Sphere in forum Off Topic
    Last Post: - 27th April 2008, 13:40
  2. Adressing a 16 x 1 Alphanumeric LCD Display
    By crhomberg in forum mel PIC BASIC Pro
    Last Post: - 8th June 2007, 16:06
  3. Use of Alphanumeric datas ?
    By F1CHF in forum mel PIC BASIC Pro
    Last Post: - 17th January 2007, 22:32
