Real Time Clock
Results 1 to 8 of 8
Thread: Real Time Clock
    Sep 2010
    Las Vegas, NV
    Default Re: Real Time Clock
    Why won't DT interrupts work? I don't really understand all the code but it's fairly simple to plug in values to get any time base you'd like.
    Just my 2 pennies here but I'd use at least 100 Hz and count pulses until you get to a second. From what I've read that further reduces timing errors by averaging the error over time.
    Best regards
    May 2009
    egypt
    if you want very good accuracy you can use ds 1302 or ds1307 rtc time ic
    May 2009
    egypt
    but you can try this code
    ' LCD clock program using On Interrupt
    ' Uses TMR0 and prescaler. Watchdog Timer should be
    ' set to off at program time and Nap and Sleep should not be used.
    ' Buttons may be used to set hours and minutes
    Define LCD_DREG PORTD ' Define LCD connections
    Define LCD_DBIT 4
    Define LCD_RSREG PORTE
    Define LCD_RSBIT 0
    Define LCD_EREG PORTE
    Define LCD_EBIT 1
    hour var byte ' Define hour variable
    dhour var byte ' Define display hour variable
    minute var byte ' Define minute variable
    second var byte ' Define second variable
    ticks var byte ' Define pieces of seconds variable
    update var byte ' Define variable to indicate update of LCD
    i var byte ' Debounce loop variable
    ADCON1 = 7 ' PORTA and E digital
    Low PORTE.2 ' LCD R/W low = write
    Pause 100 ' Wait for LCD to startup
    hour = 0 ' Set initial time to 00:00:00
    minute = 0
    second = 0
    ticks = 0
    update = 1 ' Force first display
    ' Set TMR0 to interrupt every 16.384 milliseconds
    OPTION_REG = $55 ' Set TMR0 configuration and enable PORTB pullups
    INTCON = $a0 ' Enable TMR0 interrupts
    On Interrupt Goto tickint
    ' Main program loop - in this case, it only updates the LCD with the time
    mainloop:
    PORTB = 0 ' PORTB lines low to read buttons
    TRISB = $f0 ' Enable all buttons
    ' Check any button pressed to set time
    If PORTB.7 = 0 Then decmin
    If PORTB.6 = 0 Then incmin ' Last 2 buttons set minute
    If PORTB.5 = 0 Then dechr
    If PORTB.4 = 0 Then inchr ' First 2 buttons set hour
    ' Check for time to update screen
    chkup: If update = 1 Then
    Lcdout $fe, 1 ' Clear screen
    ' Display time as hh:mm:ss
    dhour = hour ' Change hour 0 to 12
    If (hour // 12) = 0 Then
    dhour = dhour + 12
    Endif
    ' Check for AM or PM
    If hour < 12 Then
    Lcdout dec2 dhour, ":", dec2 minute, ":", dec2 second, " AM"
    Else
    Lcdout dec2 (dhour - 12), ":", dec2 minute, ":", dec2 second, " PM"
    Endif
    update = 0 ' Screen updated
    Endif
    Goto mainloop ' Do it all forever
    ' Increment minutes
    incmin: minute = minute + 1
    If minute >= 60 Then
    minute = 0
    Endif
    Goto debounce
    ' Increment hours
    inchr: hour = hour + 1
    If hour >= 24 Then
    hour = 0
    Endif
    Goto debounce
    ' Decrement minutes
    decmin: minute = minute - 1
    minute = 59
    Endif
    Goto debounce
    ' Decrement hours
    dechr: hour = hour - 1
    If hour >= 24 Then
    hour = 23
    Endif
    ' Debounce and delay for 250ms
    debounce: For i = 1 to 25
    Pause 10 ' 10ms at a time so no interrupts are lost
    Next i
    update = 1 ' Set to update screen
    Goto chkup
    ' Interrupt routine to handle each timer tick
    disable ' Disable interrupts during interrupt handler
    tickint: ticks = ticks + 1 ' Count pieces of seconds
    If ticks < 61 Then tiexit ' 61 ticks per second (16.384ms per tick)
    ' One second elasped - update time
    ticks = 0
    second = second + 1
    If second >= 60 Then
    second = 0
    minute = minute + 1
    minute = 0
    hour = hour + 1
    If hour >= 24 Then
    hour = 0
    Endif
    Endif
    Endif
    update = 1 ' Set to update LCD
    tiexit: INTCON.2 = 0 ' Reset timer interrupt flag
    Resume
  1. real time clock
    By maria in forum Code Examples
    Last Post: - 1st March 2022, 13:13
  2. real time clock - PCF8583
    By maria in forum mel PIC BASIC Pro
    Last Post: - 15th April 2010, 16:41
  3. Real time clock ICs
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 20th October 2008, 17:05
  4. Real Time Clock
    Last Post: - 8th December 2006, 03:02
  5. Real time clock... what a headache!
    Last Post: - 8th June 2006, 22:56
