18F4550 - Does strange things on D ports
Results 1 to 8 of 8
    Thank you very much for the feedback from all of you.
    The Byte[74] I changed to [80] already but the biggest problem was the following:
    In the main routine I call the SUBROUTINE Check_RS232
    GOSUB Check_RS232
    In the subroutine when the 10ms counter ends and there is no data I don't do a Return but a hard goto Main. So I get unfinished GOSUBS
    SERIN RS232_In,N9600,10,Main,DigiData[0]
    After changing the code to check for serial data in the main routine and don't use the GOSUB the problem was solved.
    Dang, I should have seen that.
    Thanks for the update.
  1. Replies: 4
    Last Post: - 17th April 2009, 08:56
  2. Replies: 1
    Last Post: - 29th September 2007, 18:05
  3. 18F4550 to 18F2550
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 28th September 2007, 23:13
  4. USB Programmer for 18F4550 PICs
    By Kamikaze47 in forum USB
    Last Post: - 21st August 2007, 16:29
  5. How many serial ports can 1 PIC handle?
    Last Post: - 2nd March 2005, 04:34
