18F4550 - Does strange things on D ports
Results 1 to 8 of 8
Threaded View
  1. #4
    To exclude the PIC I changed to a 18F4455 because this one i have in stock:
    When programming the following code:
    '*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 20-10-2009                                        *
    Include     "modedefs.bas"
    Define  OSC             20
    DEFINE  DEBUG_REG       PORTB
    DEFINE  DEBUG_BIT       6
    DEFINE  DEBUG_BAUD      9600
    DEFINE  DEBUG_MODE      1
    DEFINE  LCD_DREG        PORTB
    DEFINE  LCD_RSREG       PORTC
    DEFINE  LCD_RSBIT       6
    DEFINE  LCD_EREG        PORTC
    DEFINE  LCD_EBIT        7
    DEFINE  LCD_BITS        4
    DEFINE  LCD_LINES       2
    DEFINE  LCD_COMMANDUS   2000
    StatusLED           VAR         PORTB.7    ' Status LEDs
    RS232_In            VAR         PORTB.5    ' RS232 From DIGI-ME Module
    DigiData            VAR         BYTE[74]   ' Array for rrecieved RS232 Data
    nt_1     VAR     BYTE[74]
    Aantal_Berichten    VAR         BYTE       ' Aantal aanwezige berichten
    Data_available      VAR         BIT        ' Nieuw bericht aanwezig
    Update_Debug        VAR         BIT        ' ververs de debug data
    Button_Temp1        VAR         BIT
    Button_Temp2        VAR         BIT
    x                   var         byte       ' Algemeen te gebruiken teller
    i                   VAR         Byte       ' Teller binnenkomende karakters
    Button1             VAR         PORTC.0
    Button2             VAR         PORTC.1
    Show_Bericht        VAR         BYTE
    TRISD = 0
    PORTD = 0
    PAUSE 500                                  ' Opstart pauze
    Init:
        Aantal_Berichten = 0
        Data_available   = 0
        Update_Debug     = 0
        x                = 0
        i                = 0
        debug "Startup Alarm systeem V1.01",13,10
        Lcdout $FE, $01, "Rekavo"
        Lcdout $FE, $C0, "Bericht systeem"
        PAUSE 500
        FOR x = 0 to 4
            High Statusled
            PAUSE 50
            LOW Statusled
            PAUSE 50
        NEXT x
    Goto Main
        If Update_Debug = 1 Then
            Debug "Aantal berichten in geheugen: ", DEC2 Aantal_Berichten,13,10
            Debug "Ontvangen bericht: ", DEC2 Aantal_Berichten,13,10
            For i = 0 to 74
                DEBUG DigiData[i]
            NEXT i
            DEBUG 13,10,13,10
            Update_Debug = 0
        GOSUB Check_RS232
    Goto Main
    ' Check RS232 Port for data
    Check_RS232:
        SERIN RS232_In,N9600,10,Main,DigiData[0]
        for i = 1 to 74
         SERIN RS232_In,N9600,1,Main,DigiData[i]
        next i
        IF (DigiData[0] = $02) AND (DigiData[74] = $03) Then
            Debug "Juiste string ontvangen",13,10
            Data_available = 1
            Aantal_Berichten = Aantal_Berichten + 1
            Update_Debug = 1
            ' Zet het ontvangen bericht in de juiste vrije plaats
            'GOSUB Plaats_In_Geheugen
            Debug "Onjuiste string ontvangen",13,10
    The microprocessor starts up sends the INIT text 2 times and hangs.
    In the attachment you find the configuration settings.
  1. Replies: 4
    Last Post: - 17th April 2009, 08:56
  2. Replies: 1
    Last Post: - 29th September 2007, 18:05
  3. 18F4550 to 18F2550
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 28th September 2007, 23:13
  4. USB Programmer for 18F4550 PICs
    By Kamikaze47 in forum USB
    Last Post: - 21st August 2007, 16:29
  5. How many serial ports can 1 PIC handle?
    Last Post: - 2nd March 2005, 04:34
