18F4550 - Does strange things on D ports
Results 1 to 8 of 8
    You aren't using PORTD in your program, so they are floating.
    Leakage currents could make them vary when other pins transition.
    Try adding...
    PORTD = 0
    TRISD = 0
    I have some more problems with the microprocessor.
    I only use the 18F4550 because of the memory 32KB memory and 2048 SRAM.
    I don't use any USB functions and only control a LCD and a few inputs and outputs for RS232 data.
    It looks like my include file is wrong or does some stramge settings.
    Can somebody please tell me how to configure the INCLUDE file so I disable all the USB functions and set the OSC to 20 MHz?
    To exclude the PIC I changed to a 18F4455 because this one i have in stock:
    When programming the following code:
    '*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 20-10-2009                                        *
    Include     "modedefs.bas"
    Define  OSC             20
    DEFINE  DEBUG_REG       PORTB
    DEFINE  DEBUG_BIT       6
    DEFINE  DEBUG_BAUD      9600
    DEFINE  DEBUG_MODE      1
    DEFINE  LCD_DREG        PORTB
    DEFINE  LCD_RSREG       PORTC
    DEFINE  LCD_RSBIT       6
    DEFINE  LCD_EREG        PORTC
    DEFINE  LCD_EBIT        7
    DEFINE  LCD_BITS        4
    DEFINE  LCD_LINES       2
    DEFINE  LCD_COMMANDUS   2000
    StatusLED           VAR         PORTB.7    ' Status LEDs
    RS232_In            VAR         PORTB.5    ' RS232 From DIGI-ME Module
    DigiData            VAR         BYTE[74]   ' Array for rrecieved RS232 Data
    nt_1     VAR     BYTE[74]
    Aantal_Berichten    VAR         BYTE       ' Aantal aanwezige berichten
    Data_available      VAR         BIT        ' Nieuw bericht aanwezig
    Update_Debug        VAR         BIT        ' ververs de debug data
    Button_Temp1        VAR         BIT
    Button_Temp2        VAR         BIT
    x                   var         byte       ' Algemeen te gebruiken teller
    i                   VAR         Byte       ' Teller binnenkomende karakters
    Button1             VAR         PORTC.0
    Button2             VAR         PORTC.1
    Show_Bericht        VAR         BYTE
    TRISD = 0
    PORTD = 0
    PAUSE 500                                  ' Opstart pauze
    Init:
        Aantal_Berichten = 0
        Data_available   = 0
        Update_Debug     = 0
        x                = 0
        i                = 0
        debug "Startup Alarm systeem V1.01",13,10
        Lcdout $FE, $01, "Rekavo"
        Lcdout $FE, $C0, "Bericht systeem"
        PAUSE 500
        FOR x = 0 to 4
            High Statusled
            PAUSE 50
            LOW Statusled
            PAUSE 50
        NEXT x
    Goto Main
        If Update_Debug = 1 Then
            Debug "Aantal berichten in geheugen: ", DEC2 Aantal_Berichten,13,10
            Debug "Ontvangen bericht: ", DEC2 Aantal_Berichten,13,10
            For i = 0 to 74
                DEBUG DigiData[i]
            NEXT i
            DEBUG 13,10,13,10
            Update_Debug = 0
        GOSUB Check_RS232
    Goto Main
    ' Check RS232 Port for data
    Check_RS232:
        SERIN RS232_In,N9600,10,Main,DigiData[0]
        for i = 1 to 74
         SERIN RS232_In,N9600,1,Main,DigiData[i]
        next i
        IF (DigiData[0] = $02) AND (DigiData[74] = $03) Then
            Debug "Juiste string ontvangen",13,10
            Data_available = 1
            Aantal_Berichten = Aantal_Berichten + 1
            Update_Debug = 1
            ' Zet het ontvangen bericht in de juiste vrije plaats
            'GOSUB Plaats_In_Geheugen
            Debug "Onjuiste string ontvangen",13,10
    The microprocessor starts up sends the INIT text 2 times and hangs.
    In the attachment you find the configuration settings.
    This might not be the only problem, but you define DigiData as an array of 74 bytes.
    But then later you do an i = 0 to 74 (that's 75 bytes), and after that you do a for i = 1 to 74.
    you should use:
    For i = 0 to 73
    with that variable define, or define as BYTE[75] so you can use for i = 0 to 74
    http://www.scalerobotics.com
    Quote Originally Posted by NL2TTL View Post
    Being I do not see the configs in your code I will assume you are changing the *.inc file.
    I may be wrong but I think you think the configs can be changed in MPLAB...Nope.
    Please post the inc.
    This is also helpful.
    Thank you very much for the feedback from all of you.
    The Byte[74] I changed to [80] already but the biggest problem was the following:
    In the main routine I call the SUBROUTINE Check_RS232
    GOSUB Check_RS232
    In the subroutine when the 10ms counter ends and there is no data I don't do a Return but a hard goto Main. So I get unfinished GOSUBS
    After changing the code to check for serial data in the main routine and don't use the GOSUB the problem was solved.
    Dang, I should have seen that.
    Thanks for the update.
  1. Replies: 4
    Last Post: - 17th April 2009, 09:56
  2. Replies: 1
    Last Post: - 29th September 2007, 19:05
  3. 18F4550 to 18F2550
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 29th September 2007, 00:13
  4. USB Programmer for 18F4550 PICs
    By Kamikaze47 in forum USB
    Last Post: - 21st August 2007, 17:29
  5. How many serial ports can 1 PIC handle?
    Last Post: - 2nd March 2005, 05:34
